Question about Vivitar ViviCam 3935 Digital Camera
Card locked I have a vivitar vivicam 3845 and cannot unlock the card. Couldn't find the model in your list. Maybe you can help ?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
Unprotect a vivitar vivicam card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 08, 2012 | Vivitar ViviCam 8025 Digital Camera
Cant unlock any memory card in my vivicam 5024 camera help please
Nov 15, 2011 | Vivitar ViviCam 5024 Digital Camera
I need a battery for Vivitar ViviCam TO26
I couldn't find any batteries listed on the net by model number, but if you google the battery's part number, you may find it.
Otherwise, go to Best Buy and have them order one for you. Be sure to take the battery with you so they can verify the part number when ordering.
Good luck, and hope this helps.
May 26, 2011 | Vivitar ViviCam T026 Digital Camera
Why does my Vivitar vivicam x018 keep saying "card
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If this doesn't do it, try another card.
Feb 06, 2011 | Vivitar ViviCam 8025 Digital Camera
I got a new camra called vivitar vivicam 5024 and every time I try to take a picture it says card locked. How do I get the card unlocked?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 21, 2010 | Vivitar ViviCam 5100 Digital Camera
How do i unlock an sd card to delete images used in a vivitar vivicam 5018 camera
Jun 06, 2010 | Vivitar ViviCam 5018 Digital Camera
My daughter has a vivicam 5022 and when i put the memory card into it, it says card locked and wont take any pictures how do i unlock the card?
SD cards have a slide switch along one edge. The position nearest the contacts enables writing, the opposite position protects or locks it. Try sliding it fully to the locked position and then fully to the unlocked position. If that doesn't work, try a different card.
Jan 24, 2010 | Vivitar ViviCam 5022 Digital Camera
Card Locked Message
On the side of the SD card there is a slide button that has 2 positions, locked, or unlocked. Somehow it got slide to the locked position
Jan 22, 2009 | Vivitar ViviCam 5386 Digital Camera
Memory card locked
Check the side of the memory card
there is a lock on it.
Hope this helps
Regards
Richard.
Jan 13, 2009 | Vivitar ViviCam 3935 Digital Camera
Urgent please
There are 2 probable solutions. 1. The images are "protected" by the camera & will show "locked" when you try to erase them. 2. The SD card in the camera is locked. The solution to 1 is to unlock the images in the playback menu. See page 45 of the manual. Solution 2 is to remove the card from the camera & check the "lock" slider that you can see on the side (although no all cards have this). Set the lock off. You can download the manual from the first link on the following page: http://www.retrevo.com/s/Vivitar-4345-Digital-Cameras-review-manual/id/200bh831/t/1-2/
Aug 07, 2007 | Vivitar ViviCam 4345 Digital Camera
Vivitar ViviCam 3935 Digital Camera Logo
79 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
