Cooler Master 1000w Silent Pro M not compatible with MSI MS-7548 (Aspen) motherboard?
I just purchased a new PSU (Cooler Master 1000w Silent Pro M) and have run into a problem. After I installed the PSU my HP Pavillion Elite with a MSI MS-7548 (Aspen) mobo will not boot. The system fan will spin, the CPU fan spins for about a second then stops and the PC will not start. If I put the PSU in a another computer it boots up, if I put the old power supply back in this computer it boots up. Is this new PSU not compatible with this motherboard? Is there some jumper or setting on the mobo to fix this?
  • 5,660 Answers
Http://www.coolermaster-usa.com/product.php?product_id=2949
So you're using the same CPU 4+4 Pin x2 power cable on both rigs?
(One of them)
Yes, I see it's a modular cable design, and the CPU 4+4 Pin x2 power cable, can be used as a single 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps4plus4
ALL Yellow wires are 12 Volt (DC) wires.
ALL Black wires are Ground wires.
ALL 12 Volt wires go to ONE single 12 Volt power rail, in the Power Supply, BUT; there is nothing saying an individual Yellow wire may be bad.
This is why I wondered if you are using the SAME power cable CONNECTOR. Same power cable.
Yes?
Then suggest it has something to do with the Active PFC circuit.
http://www.hardwaresecrets.com/article/Anatomy-of-Switching-Power-Supplies/327/6
Not aware of any setting to change in BIOS Setup utility - Power.
BUT, I do not know everything! lol!
IMHO there is no reason it will not work, unless as said; something to do with the Active PFC circuit.
From here let's hope someone who really knows what is going on, will post.
Regards,
joecoolvette
Posted on Dec 10, 2012
Tip
How to connect power switch,led,reset switch to MSI MS 7548 (aspen) Motherboard...
MSI doesn't have information on the 7548, since it was made directly for HP. Here is a diagram of another MSI similiar and usually they have their pins on their jumpers pretty much the same. You would use JFP1, And Pin's 1&3 would be the hard drive, 2 & 4 would be the LED, 6 & 8 would be the power switch, and 5&7 would be the reset switch. I know your motherboard is setup slightly differnent, but your JFP1 should be in the right hand corner all by itself.
I'm attaching a diagram of the layout of a similiar board
Good Luck Everyone!!
on Apr 02, 2010 | Computers & Internet
Ms-7548 mobo no post beep and screen goes black after startup
this sounds like you have picked up a virus there are a few that will do this, you will need to reformat the hard drive. or use a backup disc if you have one made to install on computer. make sure you only go into computer in safe mode and use virus software to try and remove it. this virus attacks the startup file on the hard drive, and the reg files allocation. hope this helps failing this the hard drive has wiped its self when it has not shut down properly.
May 09, 2014 | HP MS-7548 System Board Motherboard...
Computer won't switch on
YOU SHOULD CHECK YOUR PSU.
Apr 17, 2013 | MSI K9A2 CF Motherboard
I just purchased a new Power Supply Unit (Cooler Master 1000w Silent Pro M) and have run into a problem. After I installed the PSU in my HP Pavillion Elite (Yes, I know it's a dinosaur of a case,
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Dec 10, 2012 | Computers & Internet
Power supply compatible for cooler master cac-t05-uw
Most brands like HEC, Gigabyte, FPS, Cooler Master, Enermax, Silver stone, Corsair, etc. Will fit in your casing but you must consider your hardware before buying a power supply.
Most power supplies that are priced below $30 generally do not meet the power requirements of the latest processors. To make matters worse, the components used in them are of inferior quality and more likely to fail over time. While they may power the computer system, inconsistencies in the power to the components will tend to cause instability and damage to the computer.
Consider the ff:
ATX12V Compliant
PC Power Supply Wattage
Silent PC Power Supplies
Power Efficiency
Having the right number of connectors
PSU Wattage Calculator Asus
PSU Wattage Calculator extreme
Hopefully this helps..
Thank you for posting..
Jul 08, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
Hi guys, i need some advice on setuping my new system. here is the spec of my new system: casing- collermaster HAF 912 motherboard- MSI P67A-GD55 processor- INTEL I5 3.1 GHZ ram- 4gb x 4 total...
YES THIS GRAPHIC CARD WILL BE ACCEPTED BY MSI P67A-GD55 BOARD..
BELOW SHOWN IMAGE IS A VIEW OF NVIDIA GEFORCE GTS 450
THIS CARD ONLY SUPPORTS TWO DISPLAYS AT A TIME
May 24, 2011 | MSI N450GTS-M2D1GD5/OC GeForce GTS 450...
PC dead. Replaced power supply. No lights. No nothing.
When that happens it is usually the motherboard.
To test parts you need a benchmark.
PSU can be tested using a multimeter.
Motherboard is tested using a tester like this one: PCI Test Card, PC Analyzer, Motherboard Test Card
Ram and CPU (CPU sometimes get damaged) are usually not damaged by this kind of problems, they can be tested mounting them on a working motherboard. For the RAM we also use a RAM tester that costs about $200.
Ensure also that the switch contacts to new motherboard are installed properly. A technician can test cabinet power switch using a multimeter, or carefully bridging with a screwdriver the switch on contacts on motherboard (do not do this unless you are sure about what you are doing)
Test the new PSU on a different socket, when a PSU blows , it may damage the main socket.
Also remember that new power supply units have two connectors. The big rectangular main one (24 pin) and a smaller 4 pins squared one.
As an home user you may not have access to testing equipment, therefore my suggestion is.
Ensure you are using the right PSU.
Ensure that the motherboard is connected to power switch.
Test the new PSU with a multimeter.
Examine the motherboard for blown or leaking components and burnt areas.
If you do not find anything, but the mainboard is still not working, then buy a motherboard-cpu bundle compatible with the PSU that you bought and assemble a new system inside the old cabinet.
Regards.
May 04, 2009 | MSI K8MM-V Motherboard
Power switch,reset switch,power led connections to motherboard?
Hi ramjet007;
This is strange because MSI doesn't have information on the 7548, since it was made directly for HP. Here is a diagram of another MSI similiar and usually they have their pins on their jumpers pretty much the same. You would use JFP1, And Pin's 1&3 would be the hard drive, 2 & 4 would be the LED, 6 & 8 would be the power switch, and 5&7 would be the reset switch. I know your motherboard is setup differnently, but your JFP1 should be in the right hand corner all by itself.
Front Panel Connectors: JFP1 & JFP2
Good Luck and don't forget to leave a rating.
Thanks Mark
Apr 25, 2009 | Computers & Internet
Micro star mainboard ms-6163
Hi
MS-6163 Pro Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports up to Ultra DMA 33 operation mode.
MS-6163 Pro - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=340&maincat_no=1
**** Other MS-6163 ****
MS-6163FC Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163FC - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=341&maincat_no=1
MS-6163VA - Systemboard IDE controller utilises VIA VT82C596B Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163VA - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=342&maincat_no=1
MS-BX Master Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-BX Master - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=319&maincat_no=1
Regards
Mike
Mar 27, 2008 | MSI MS-6163 Pro Motherboard
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
