Question about Samsung NP-RV515-A01US RV515-A01 Notebook PC - AMD E-350 1.6 GHz Proce
My default gateway is not available
Where do I go to add my default gateway and what is it pop3 is that it
  • 2,878 Answers
Go to Start > Search (Run in XP) and type cmd and hit ENTER. In the command prompt type ipconfig and hit ENTER. That is you local gateway.
However, if you are configuring an email account for POP3, then it may refer to your email gateway like yahoo.com or gmail.com, witch is part of your Post Office Protocol. Examples would be mail.yahoo.com or pop.yahoo.com. So just change the domain part of the example for your setup.
Posted on Dec 10, 2012
Xerox WC 3220 scan to e-mail problem with external smtp server(ISP). I am trying to configure the scanner to send mail. I follow up the instructions in the manual. When I try to test it I got smtp error ...
You can always find answers to your Xerox questions at www.xerox.com/support .
The 3220 does NOT support SSL, please verify if your email service is requiring SSL transmission. (Port 445 or 587 are indicators of SSL email requirements.) There are free email providers that will still send on port 25 without SSL. Xerox does not provide a list however so you will need to research these yourself.
Instructions for setup scan to email below:
Configure the Machine for Scan to E-mail
IMPORTANT: Obtain the following information from your e-mail service provider before configuring the machine for Scan to E-Mail.
  1. What is the host name or IP address of the SMTP server?
  2. What port number does that SMTP server require?
  3. Does the server require authentication login? If so, what format does the server expect the login? (Does the server require the full e-mail address or just the part before the @ sign?)
  4. Does the e-mail server require POP3 before SMTP authentication? If so, obtain the POP3 settings (POP3 host name or IP address, port number, and login name/password).
  5. Does the server require SSL or TLS encryption? If so, ask your e-mail provider to provide you with an e-mail server that does not use SSL or TLS encryption as the printer does not support SSL/TLS encryption for e-mail authentication.
    NOTES:
    • If you are provided with a new e-mail server to use, questions 1 - 7 will need to be answered again.
    • Xerox does not provide a list of e-mail providers that do not require SSL/TLS encryption for e-mail authentication.
    • If unable to find an e-mail service that does not require SSL or TLS encryption, See theRelated Items below for information on how to Install the Network Scan program for a Windows OS or how to Install the USB Scan Driver for a Macintosh OS. Once the scanned file is stored on your computer, it can then be e-mailed from your computer as an attached item/file in a new e-mail.
  6. What is the attachment size limit on the account on that server?
  7. What 'From' address will the printer use for Scan to E-mail? The From address should be a valid e-mail address for the e-mail server that the printer will use. Ask the e-mail provider if authentication is required if the login name (above) is allowed to be used for the From address the printer will use.
    If you do not know the answer to the questions above, contact the people that control the e-mail server you want the machine to use for Scan to E-mail. The following parties can provide you with additional assistance:
    • If the e-mail server is inside your company's network, contact the E-mail Server Administrator to obtain the required settings.
    • If the e-mail server is outside your company, contact the Technical Support for that e-mail service to obtain the required settings. This may be your Internet Service Provider (ISP), or a 3rd party E-mail Service Provider.
Configure the Machine's E-mail Settings Using CentreWare Internet Services (CWIS)
After you have obtained the above information, configure the machine's e-mail settings using CWIS.
  1. Access CWIS. See the Related Items below for additional information.
  2. Click on the [Properties] link.
  3. In the Properties section on the left side of the window, click on the [+] symbol next to theProtocols folder to expand the list of options.
  4. Click on the [SMTP Server] link.
  5. Click on the [IP Address] or [Host Name] radio button.
  6. Enter the IP address or domain (host) name of the SMTP (e-mail) server in the field provided.
    NOTE: If you use an IP address for the SMTP server, verify that the IP address for the server will not change. If the SMTP's server IP address changes, the machine will be unable to Scan to E-mail until the machine's SMTP Server address entry is edited with the new SMTP server IP address. If necessary, contact your E-mail Administrator to verify how the IP address has been assigned to the SMTP server.
    NOTE: If using the domain (host) name, make sure DNS is enabled on the machine. By default, DNS is disabled. To enable and configure DNS settings, click on the Properties tab, click on the TCP/IP link under the Protocols folder, enter the required DNS settings for your network in the DNS/DDNS field, and then click on [Save Changes]. Contact your Network Administrator to obtain the correct DNS settings.
  7. Enter the port number used by the e-mail server, from 1 to 65535, in the field provided. The default port number is 25. If you use an IP address for the SMTP server, verify that the IP address for the server will not change.
  8. If authentication is required, insert a check mark in the SMTP Requires Authentication check box.
  9. In the SMTP Server Login Name field, enter the SMTP login name.
  10. In the SMTP Server Password field, enter the SMTP password and then retype the same password in the Verify Password field.
  11. If the E-mail server requires POP3 before SMTP authentication, continue with step 13. Otherwise skip to step 17.
  12. If POP3 before SMTP authentication is required, insert a check mark in the SMTP requires POP3 Before SMTP Authentication check box.
  13. In the POP3 Server and Port field, enter the IP address or domain (host) name of the SMTP (e-mail) server and the port number. The default port number is 110.
  14. In the POP3 Server Login Name field, enter the POP3 login name.
  15. In the POP3 Server Password enter the POP3 password and then retype the same password in the Verify Password field.
  16. Click on the [Save Changes] button.
  17. In the Properties section on the left side of the window, click on the [+] symbol next to the E-mailfolder to expand the list of options.
  18. Click on the [E-mail] link.
  19. Click on the [E-mail Setup] link.
  20. In the Default [From:] Address field, enter the from E-mail address that the printer will use for sending E-mail.
    NOTE: If you do not want the from address that the printer will use to send E-mail to be automatically copied on any E-mail that is sent from the printer, make sure that the check box next to Always prompt for file format setup before scanning is not checked. Additionally, the following default settings can be set for Scan to E-mail:
    • Default Original Type - Available options are: Text, Text/Photo, and Photo
    • Default Scan Resolution - Available options are: 100 dpi, 200 dpi, and 300 dpi
    • Default Attachment Type - Available options are: PDF, TIFF - Multi Page, and TIFF - Single Page
    • Default Scan Color - Available options are: Mono, Gray, and Color
    • File Format Setup Prompt - Leave this box unchecked if you do not want to be prompted for the file format each time you Scan to E-mail.
    • Conformation Sheet - Available options are: On Errors Only, Always, and Off
  21. Click on the [Save Changes] button.NOTE: See the Related Items below for information on how to Scan to E-mail. When Scan to E-mail is successful, it is recommended to print a copy of the SMTP Server settings and E-mail Setup settings from CWIS for your records. If Scan to E-mail fails in the future, refer to these settings.
Configure Additional E-mail Security Settings (Optional)
For additional security when sending e-mails, the machine can be configured to require the sender to be authorized prior to using the machine's Scan to E-mail service. This is an optional security feature for Scan to E-mail and is disabled by default.
Authorized users for Scan to E-mail can be configured using CWIS. Up to 2,000 users can be registered.
  3. In the Properties section on the left side of the window, click on the [+] symbol next to the E-mailfolder to expand the list of options.
  4. Click on the [User Authentication] link.
  5. Insert a check mark in the Enable Auth User check box to enable user authentication.
  6. If necessary, insert a check mark in the Enable Guest Account check box to allow guest access. If this option is enabled, enter a login name and password for the guest account in the fields provided.
  7. Click on the [Add] button to add new accounts.
  8. Enter a username, an authentication ID, a password and an e-mail address in the fields provided.
  9. Click on the [Save Changes] button. The user will be added to the User Authentication List.
Nov 04, 2013 | Xerox WorkCentre M20i All-In-One Laser...
Remove back of gateway model zx6971
in this link you can find and download the manual that can help, you http://support.gateway.com/product/default.aspx?modelId=3931
Jan 18, 2013 | Gateway Computers & Internet
Hi. I am having bsnl type 2 modem "WA3002G4" to which I was able to communicate few hours back by opening link of 192.168.1.1. But now I am not able to open this link. Please help.
if you use windows xp os, simple do this following,
right click connection icon from your monitor at left side, then status, when you see the local area connection status, click support. now, you can see the default gateway right?
copy the numbers of the default gateway, then open IE browser,(Internet Explorer) then paste the numbers from default gateway, then enter. done.
you can add (http://) if necessary for ex. http://192.168.1.1
Apr 16, 2011 | Computers & Internet
I own a samsung GT I 9000. Have been trying to synchronize with my corporate mail server without success in spite of following the screen tips. Could you please help me or atleast guide me to a custormer...
Check the security settings of your mail server to ensure you're not being blocked.
Here are some 'standard' settings that may work with your system.
Gmail Incoming Outgoing
Access Type Web & POP3 Web & POP3
Email Address Format username@gmail.com username@gmail.com
Account Username Format
Full email address Full email address
Server Address pop.gmail.com
Use SSL: yes Port:995 smtp.gmail.com
Use SSL: yes Port:465
Hotmail Incoming Outgoing
Email Address Format username@hotmail.co.uk username@hotmail.co.uk
Server Address pop3.live.com smtp.live.com
ic24 Incoming Outgoing
Email Address Format username@ic24.net username@ic24.net
Server Address mail.totalise.co.uk smtp.tiscali.co.uk
UKGateway Incoming Outgoing
Email Address Format username@ukgateway.net username@ukgateway.net
Server Address pop.ukgateway.net smtp.ukgateway.net
UK Online Incoming Outgoing
Email Address Format username@ukonline.co.uk username@ukonline.co.uk
Username@ukonline.co.uk Username@ukonline.co.uk
Server Address pop3.ukonline.co.uk smtp.ukonline.co.uk
Vippowerent Incoming Outgoing
Email Address Format username@vppn.com username@vppn.com
Server Address pop.vppn.com
Virgin.net Incoming Outgoing
Email Address Format username@virgin.net username@virgin.net
Username Username
Server Address mail.virgin.net mail.virgin.net
Wanadoo Incoming Outgoing
Email Address Format username@ name.wanadoo.co.uk username@ name.wanadoo.co.uk
name.wanadoo.co.uk name.wanadoo.co.uk
Server Address pop.wanadoo.co.uk smtp.wanadooasdl.co.uk
World Online Incoming Outgoing
Email Address Format username@ worldonline.co.uk username@ worldonline.co.uk
Server Address pop.
tiscali.co.uk smtp.
tiscali.co.uk
Yahoo.co.uk Incoming Outgoing
Email Address Format username@yahoo.co.uk username@yahoo.co.uk
Username Username
Server Address pop.mail.yahoo.co.uk smtp.mail.yahoo.co.uk
Yahoo.com Incoming Outgoing
Email Address Format username@yahoo.com username@yahoo.com
Username Username
Server Address pop.mail.yahoo.com smtp.mail.yahoo.com
Settings - E-mail
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The following settings are if you use O2 Email as your ISP (Internet Service Provider).
If you require different settings eg Yahoo, Gmail etc please click here
1. Tap the Application tab on the bottom of the screen
2. Tap Email
3. Tap Next on the Welcome to Email setup screen
4. Tap on the Email address text box and enter your Email address then tap Done
5. Tap on the Password text box and enter your Password for your Email account then tap Done
6. Tap Next
7. Your phone will now try and download your setting to your phone and set up your account, if this can not be done you will see the message, Setup could not finish. Unable to open connection to server. Tap Edit details to continue.
8. Tap Manual setup
9. Tap the Username text box and enter your full Email address then tap Done
10. Tap POP3 account
11. Highlight POP3 server and tap the text box and enter mail.o2.co.uk
12. Check that Port is default set at 110
13. Highlight Next and tap
14. The phone will now check your settings
15. Tap the SMTP server text box and enter smtp.o2.co.uk
16. Highlight Next and tap
17. The phone will now check your settings
18. Tap Next on the Account options screen
19. You now have the options to add a name for your new account plus add your name to outgoing messages
20. Tap Done
Jan 02, 2011 | Samsung Computers & Internet
I get this message on my computer that says 'Your Microsoft Exchange Server is Unavailable." How do I make it available?
By the sounds of it you are using Outlook 2007 or 2010
to download your email from sites like hotmail and Yahoo you need POP3 not Exchange. Exchange is a Microsoft Email server used by companies.
to remove the exchange section in outlook you need to go to the "Configuration Panel" then click on "Mail" in there you will have a profile called "Outlook" click on "Email acounts" and remove the item that says "Exchange" then click "Add " tick the box "Manually selct settings" select POP3 and add the details for your email as per their instructions
Aug 01, 2010 | Microsoft Windows XP Home Edition
How to hook n40 on a network
just add it to one of the router's lan ports..and after that access the tcp/ip protocol into the network card ...of the printer ..and choose to get an ip address automatically ..
This will add it into the network ..and all the other devices will be able to send jobs to its IP ..or just find it when you hit search for printer inside default gateway ..
If this do not work ..than you will have to configure the Ip and subnet mask ..and default gateway manually like this ..
the Ip will be the router's Ip +the number of the port ...so if the router is ..192.168.1.1...than the printer in number 3 port will be ..192.168.1.4 and the subnetmask will be :255.255.255.0 and the default gateway will be the router itself..192.168.1.1
the dns servers will either be configured automatically and in this case will take the network's ones from the router ..or insert the ISP dns same as in the router ..
May 30, 2010 | Xerox DocuColor 12 Printer
How can I use my Windows mail account as an smtp outgoing mail server?
Go to internet accounts then add your email accounts in windows mail.
Add your e‑mail address and password.The type of e‑mail server your e‑mail service uses.The address of the incoming and outgoing e‑mail servers used by your e‑mail provider.
Add your pop3 and smtp server name and port numpber.
Pop3 and smtp provide by your email service provider.
If you use google then login into your google account then click on account settings .
Then click on Forwarding and pop/IMAP
Then you can see IMAP Access in below click on configure instruction so then click on windows mail so you can get all info of pop3 and smtp server and how to configure it.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 17, 2010 | Vivotek IP7138 Network Camera
Hi There, I have changed to a different computer and i cannot get my E-Mail through Outlook Express going. PLEASE can you help. Rosanna
Hi Rosanna,
If you have access to the other computer you can go to the Outlook Express (OE) menu - under Tools (I think) you will find the accounts option,
Open that and select your email acount and then select modify / Edit depends on your version.
Copy down the settings like pop3 server address and SMTP, your username and password and
then enter those details on the new computer's OE accounts section click on Add New Email Account
If you do not have access then try this.
Go to OE Tools->Accounts (may be under different menu)
Click add new Account
Enter the details it asks for
pop3 and SMTP servers are usually standardised
So if your email address is rosanna@here.com
pop3 will either be mail@here.com or pop3@here.com
the SMTP server will either be mail@here.com
or smtp@here.com
If you are connecting to hotmail then you will not get access to your email via OE anymore - you need to use Windows Live Mail or MS Outlook with the Outlook Mail Connector - available from MS.
Remember to vote if this helped
Oct 06, 2009 | Microsoft Outlook Express
Switch from WEP to WPA wireless protocol
First have a computer directly plugged into the 2wire
Using windows xp: click on start> then run> then type "cmd" and hit enter.
Type "ipconfig" and hit enter.
You are looking for a default gateway address, usually "192.168.1.254" on 2wire gateways.
Skip the vista section if you are using xp
Using Windows Vista: click start> then click on the search bar and type "cmd" and hit enter.
Once you find the gateway address, you now have the website address you need to get to your 2wire. Open internet explorer and type that default gateway address in the address bar.
This should take you to a 2wire homepage. At the top click on the "home network" or "local network" tab at the top.
Once there, click on the wireless network link at the top. It will prompt for a password, if you do not know the password, click I forgot for a hint. Click I still cannot remember if the hint doesn't help, it will ask for a system key, which is a 10-digit number on the bottom of the 2wire.
After entering the password you will be in the wireless settings window where you can change the security type to any available that the 2wire has, if it doesn't have it available call the provider and see if they have a firmware upgrade available.
Nov 13, 2008 | Gateway Wireless-B Router (wbr-100)
I want to scan and email a document from my new HP DESKJET F4280 printer. I can scan it, and then I try to share it, but when I hit the send button it says there is no internet connection. Am I right in...
When you scan a document it must be scanned with OCR software. The default scanning method will scan a document as a picture, not a document with letters and words. The OCR software will recognize the letters and put the scanned document in the proper format to open it with MS Word. The software that you scan with should have a setting for OCR, read your instructions or help files to get the details if you can not find them very easy in the software you use for scanning. .
The problem with using Outlook may be that you have not set it up properly to get your emails from your email server. You do not need to use Outlook or Outlook express to send any documents, you can use your web based email server if you like, but you can use Outlook Express as well. You just need to add the document to send as an attachment to the email.
To set up Outlook Express to get your email, you must first find out what the POP3 and SMTP setting you must use. You can get that information from your email provider, it is different for every email provider. Then you go to the "File" menu at the top left of Outlook Express and select "Identities" and select "Add New Identity" and from there you will go thru a wizard to guide you thru the process of setting up your email client. Just make sure you have the POP3 and SMTP settings available for you to put into Outlook Express when prompted to in the wizard.
Dave
Nov 13, 2008 | HP Computers & Internet
Samsung NP-RV515-A01US RV515-A01 Notebook PC - AMD E-350 1.6 GHz Proce Logo
146 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
