Question about Refrigerators
Fridge not cooling
We just notice that the fridge is not cooling but the freezer is staying cold.. We cleaned out the bottom of fridge and let unplugged for a little bit but nothing.. The fridge is only 2-3 years old any suggestions that may work.. My husband said the compresser felt hot..
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Do you see any ice buildup on the back wall of the freezer or behind it?
Posted on Dec 10, 2012
  • 14 more comments
  • atomber
    atomber Dec 10, 2012
    no have not seen any ice build up in freezer
  • Richard Roth
    Richard Roth Dec 10, 2012
    The freezer should be cold since the refrigerator section draws it's temp from the freezer. Are you sure the freezer is not cold?
  • atomber
    The freezer works no problem it is still freezing and working like should the fridge is not cooling at all
  • Richard Roth
    OK, I'm clear now. What is the model number?
  • atomber
    Sorry don't have it with me
  • Richard Roth
    OK, post it when you get it.
  • atomber
    It is mff2258veb3
  • Richard Roth
    OK, sounds like the damper is not working in the bottom of the refrigerator section. Check to see if you have good air flow there. If not, replace the damper. Here is that part to order. http://bit.ly/TZaNpn
  • atomber
    Thank you I will try
  • Richard Roth
    Keep me posted!
  • atomber
    atomber Dec 11, 2012
    where is the damper at in the fridge please is in in the fridge or in behind the bottom
  • Richard Roth
    Richard Roth Dec 11, 2012
    In the frig under the cover near the light.
  • atomber
    We left unplugged for about 24 hours and there was water in bottom of freezer plugged back in now the water in freezer is frozen and seems like fridge is getting cold again would that have to do with the damper
  • Richard Roth
    The damper clod have been frozen over or the coils in the freezer were iced up. Let it run for a few dats and see what happens.
  • atomber
    Thank you
  • atomber
    atomber May 04, 2013
    We replaced the damper and started working some but now ice is starting to form in the back of the fridge again and causing the fridge not to cool again any suggestions..
SOURCE: Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Posted on Dec 10, 2007
  • 2920 Answers
SOURCE: fridge left open all night and wont cool but the freezer still works.
time for a new fridge
Posted on Aug 27, 2008
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
lenwest
  • 150 Answers
SOURCE: refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 27, 2009
Hotpoint HTR17BBRFRWW top freezer does real cold but bottom fridge stays at 52 or above. Coils clean and gaskets good, unit level and compressor runs quiet. What is obstruction between freezer and f
http://www.partselect.com/Schematics/GE/00113789i02.gif
look at number 304. Ice more than likely has formed and not letting air flow from the freezer to the fridge.
Jun 03, 2012 | Hotpoint Refrigerators
Freezer stays frozen, but refrigerator doesn't stay cold
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Sep 13, 2011 | Magic Chef Refrigerators
Top fridge will not keep cold,and no air flow is present when compressor is running.The bottom freezer chest stays cold. I cleaned the coils....what should I try next?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 01, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
