Question about Dell Inspiron E6550 Notebook
How do i reformat my dell computer with windows vista on it when the OS was preinstalled and the hard drive wont even load windows anymore?
I would like to reformat it myself or at least get my personal documents and pictures off before I send it to someone else to fix so if anyone has any suggestions please let me know I really don't want to send it to someone else to fix if I can't get my personal documents and things off first, I know there is a way I just don't know how. Thank you,
  • Dell Master
  • 2,878 Answers
You could try installing Windows on top of it's self, or onto another partition. It can even loaded on same drive where it renames the old Windows folder and creates a new one. However, these options are susceptible to data loss.
A safer way is to remove the hard drive, and attached as a secondary drive on another computer. You have the choice of internal or external. External (easiest) can be done with an universal adapter and connected to a USB port.
I'm using something like this right now.how do i reformat my dell computer with windows vi - 12_10_2012_3_29_21_am.jpg
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002
Your other option is the reverse, attaching another drive to your PC and using DOS commands to copy files over to the attached USB storage device. This method is cheap and fairly easy, but you must know some basic DOS prompt commands.
GL
Posted on Dec 10, 2012
  • Dell Master
  • 27,725 Answers
You have to format a hard drive with a third party disk unless its a usb data drive Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios. Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system. Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd\dvd. Hope this helps.
Happy2Help
  • 59 Answers
SOURCE: Internal wireless card has been disabled. How do you fix this?
Hi car7924,
First, make sure that the wireless switch on the left side of the computer is turned on (this should make the WIFI light go on -- beneath the lower right corner of the screen). If it doesn't work, then try going to Start Menu > Control Panel > Network and Internet Connections > Network Connections.
You should see the Wireless Network Adapter in the window that comes up. If you don't, you need to download the driver for that adapter. The most common adapter in the D820 is the Dell 1390 WLAN MiniCard, and the driver for it can be downloaded at the following web address:
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/Dell-Latitude-D530-Wireless-1390-WLAN-MiniCard-Driver-A17.shtml
If, on the other hand, you do see the Wireless Network Adapter, but it says "Disabled" underneath the name, then right-click it and select "Enable." This should make it work.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Posted on Dec 13, 2008
PlatoAu
  • 67 Answers
SOURCE: Dell 1501 Inspiron w/Vista won't boot up -- virus?
Hi Erika,
have you tried pressing F8 when it starts booting (keep pressing it before dell bios screen fully loads)
you should get a black screen with options,
scroll up to with arrow keys>> "last known good configeration"
let me know if that works?
also have you installed any programs or hardware befor this happened?
Posted on Apr 13, 2009
ebay312
  • 118 Answers
SOURCE: Windows Failed to load because Kernel file is missing, or corrupt
Are you talking about two problems on one computer? If so, the first problem doesn't matter until the second one is fixed. If you are talking about two different computers, then the problems can be each addressed.
For the hard drive that is not recognized, where did it come from? If you purchased it used, you may be out of luck. It sounds like you have a pretty good idea how computers work, and it also sounds like this hard drive does not work at all.
If these are both the same computer, then replacing the hard drive with a known working hard drive will most likely provide you with a solution.
I wish I had better news for you.
Posted on May 17, 2009
SOURCE: Dell Inspiron 1525 Blue screen & windows error messages/reformat
If the ram passed memtest then the problems are likely to by corrupt system files. rather than do a complete reinstall and have to worry about backing up the data try ReImage. They c will remotely fix the system files, leaving your data intact
ReImage
Posted on Jul 18, 2009
shadow83
  • 496 Answers
SOURCE: Will pass bios but then will not load windows
step 1. open up the case and locate your hard drive
step 2. carefully remove the cables and power to the hard drive and remove it
step 3. goto your local office depot, staples, walmart or radio shack and buy a nice new hard drive somewhere around 250 gigs should be plenty for you,
step 4. now that yopu have a nice new hard drive put it in the spot where your old hard drive was in the conputer and plug both cables back into the new hard drive, after this is done put your case back on and start the computer up with your windows cd in the cd rom drive and reinstall windows. :) hope this helps
Posted on Oct 14, 2009
Laptop: Sony Vaio Serial Tag: C3LRMD7Q Model: PCG7133L Need information for recovery disks for the foremention laptop. The OS is Windows VISTA Home Premiun.
The VAIO Model VGN-NR498E/S is shipped with Recovery partition in the hard drive. It is required to create the recovery discs as soon as you get the notebook. Using either recovery discs or the recovery center you can reinstall the preinstalled OS in the computer. But, it depends if you has changed the preinstalled OS, the recovery partition will be erased and no longer be accessible.
However, in your case, if you not made any changes to the preinstalled OS, restart the computer and press and hold the F10 key. this will launch the recovery tools. On the next screen, press Enter key. Then you will be able to view options such as "Restore C Drive", "System Restore" etc. There select "Restore C Drive" to reinstall the preinstalled Vista OS in the Computer.
If you have changed the preinstalled OS in the computer, then it is requires to purchase the recovery discs from Sony's parts center:
https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=partSearch&searchText=Y8318272A&sessionId=pfBoWO6gh7vj_fseXl4oiMI
The above part is no longer available with them However, you can use the part #Y8318272A to search for the recovery discs with online retailers and others.
Thanks!!!!
Dec 16, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
I have a dell vostro 1310 laptop that will not boot. It first tried to recover but couldn't and would just shut down. Now I cannot even enter anything with a command prompt. I think my hard drive is fried...
Dell site should have info regarding the removal of old drive. Then install new drive in its place and install the recovery disks that you got or made. Hopefully the new drive will come with the software to prepare the drive for loading although some of the newer OS disks will do it for you.
Jul 22, 2017 | Dell Vostro 1310 Laptop Computer PC...
Iomga eGo drive data back-up for Vista need transfer to Windows 7
try to connect it to another computer that runs vista, reformatting is never a good thing. the portable hould be read on any other computer, but if you connect to another computer that have vista take it off and keep it on the other computer for a little (like someone elses computer) and put it back on to the computer with windows 7, reformat it and try to put our stuff back on then try again.
Jun 19, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
My hard drive has broken. I want to buy a used, loaded hard drive for my Dell Inspiron 1525. Which other Dell hard drives would be compatable?
what do you mean loaded? preinstalled wih everything? for that you would probably have to go to dell and they probably charge a lot. you can just get another "2.5 sata hard drive and do it yourself if you have a copy of windows. you can even borrow a copy as long as it is the same version that is on the sticker on the bottom of your computer. you just use your product key. then you can go to dell.com and get the drivers you need.
Apr 21, 2010 | Dell Inspiron 1525 Notebook
try pressing f8 when you load vista and then select start normally
if that doest not work and gives you the same error then restart and press F12 as soon as you see the dell logo, put in the vista installation disk that you got with the laptop and select boot with disk option.
try and repair or the recovery option .
NOTE : IT IS RECOMMENDED TO TAKE BACK UP OF YOUR FILES BEFORE USING THE RECOVERY OPTION .
May 17, 2009 | Dell Inspiron 1521 Notebook
Installing win xp and vista together on dell 1537 studio
you will not be able to put os in the same hdd on a computer.also if vista is installed on one hdd & the other partition is on the same hdd so please try not to install 2 windows on same hdd,its not possible...
Apr 24, 2009 | Dell Studio 1537 Laptop
Make preinstalled vista
If not, the guys who sold yhe pc should install it for you, since a part of the computers price is for the OS, or at least they should provide you a recovery DVD.
Oct 16, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Installing Windows Server 2003 on a preinstalled Vista OS
The reason it is showing "no hard disk" is because you have a SATA hard drive, and there is no SATA support on the WS2003 software, so it doesn't even "see" the drive when trying to install.
What you can do is download SATA drivers for your hard drive to your machine. Once downloaded and/or extracted, restart the installation but choose F6 to load "SCSI or 3rd party drivers", then point to the downloaded drivers.
Your installation will then load the SATA drivers, thereby recognizing the hard drive and you'll be able to successfully install Windows.
Hope this helps - remember to rate :)
Oct 06, 2008 | Microsoft Windows Server Standard 2003 for...
Dell Inspiron E6550 Notebook Logo
55 people viewed this question
Alun Cox
