Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
I have white and sometimes red lines and they move and I recently replaced the bulb
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Look to see if same issue with the audio and video inputs on rear, usually a problem with lines will not come and go but, it may be possible.
Also it is possible if you snap a good photo to post it here to be seen.
Posted on Dec 10, 2012
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Scan/copy issue: horizontal lines and bulb red
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
Jul 15, 2017 | Samsung CLX-3175FN Color Laser All-in-One...
When TV is turned on, there is no picture but a very, very faint verticle haze in the middle of the screen. At first, the power switch lamp is green and blinks slowly, then at a faster pace. At the same...
Yes,it will resolved ur tv picture issues.This tv the projection lamp has not been replaced at least 1 1/2 or 2 years right?The tv on an in used at 4 or 5 hours a day right? The projection lamp life span are over.Sometimes the Ballast board have to be replaced too.This Ballat board it to help to ignite the projection lamp.
Jun 26, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Strait-line
Yes. The lights represents the stud. As you move it over each light lights up.
May 30, 2010 | Strait-Line Strait Line 6041706 Stud...
VISABLE LINES IN PICTURE
Bulb replacement will only repair reduced brightness or contrast problem. Sometimes shadows or lines (usually curved or circular) appear in the image if the bulb is weak or faulty. This will show with the color turned off and a black and white image displayed.
Most visible color faults are caused by optical engine failure. Big cost, as the complete assembly has to be replaced.
Occasionally there are video processing or tuner problems that require serious troubleshooting to determine what board has to be replaced.
If the fault is not visible on the customer menu and appears only with input signal viewed, you may have a cable box or other signal input problem. Check various input signals to see if the problem is visible with all inputs.
Running the channel scan with vhf input signals sometimes clears up a lot of problems. Your cable company may have changed or adjusted rf modulators or other equipment and the tv needs to be aligned to the changed signal. Auto tuner scans will take care of these problems.
easyab
Apr 22, 2010 | Panasonic PT-50LC14 50" Rear Projection...
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
I have a Mitsubishi 65" HD-1080 big screen tv. Today when I turned it on it had a red shadow all over it and the red tube was off by about an inch. The TV has an automatic convergence function that I...
Convergence ICs need to be replaced. post the model number and I will list which ICs you need and where you can get replacements with free installation instructions.
Apr 26, 2008 | Televison & Video
Red and Green Lines in TV
The optics block has failed and it will have to be replaced. Contact Sony for an auth. service center in your area as the optics block in this unit has a 2 year mnfg. warranty.
Feb 16, 2008 | Sony KDF-E42A10 42 in. LCD Television
Thin horizontal line across picture
I really dont understand the problem Could we see a picture of this please?
Jun 14, 2006 | Toshiba 35A44 35" TV
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
