Question about JDSU Test-um Validator-nt 905 Gigabit Ethernet Cerfifier Cable Network Tester
When testing a cable it shows a larger distance that it realy is. If the cable is of 100ft.. the meter shows 150 ft.
I calibrated the unit using but it continues to do the same problem.
    Master:
  • 683 Answers
Who calibrated it? if you are sure that reading are differen send it back for calibration
Posted on Oct 14, 2013
2003. 2wheel dr 150 p.u. I. Put smaller tire on because back problems getting in .now at 60 mph dash odometer reads 69 mph . Is there something I can do . So odometer would be correct.
there are different speedo gears in the transmission available that will allow for some ratio changes in the diff so check with a dealer spares to see if any are available for your vehicle
when you say smaller tire , is it a smaller diameter rim that was fitted
if that is the case by fitting a larger tire case may get back closer to the correct reading
by that I mean for example a 195 25 r14 case can be replaced by a 195 95 r14 case as the difference is in the 25 to 95 measurement
the 25 measurement makes for the rim almost touching the ground where the 95 dimension stands the rim well up off the road and because of that the distance covered in 1 revolution is far different to the distance covered in 1 revolution by the 25 size tire
that solution may put the car back too high for your back problem so if the gears replacement is not possible , then a last solution may be to find an instrument repair shop and have the gauge re- calibrated to the correct reading according to the speedo gears in the transmission
if it is auto with a VSS unit that signals the speedo there may be changes in that area that are possible
Jul 31, 2016 | 2003 Ford F-150
How do you calibrate a laser distance meter?
Calibrating a laser distance meter is not all that complicated. eHow.com has a really good guide. How to Calibrate Laser Distance Meter eHow
Jan 22, 2014 | Measuring Tools & Sensors
What gauge speaker wire use for yamaha R-v905 Receiver
The usual gauges range from 18 to 16 with one limiting factor being the ability of the receiver and speaker terminals to handle larger gauge wire
Jan 28, 2013 | Yamaha R-V905 Receiver
Distance for unrepeatered T-1 span out of a flm 150\
Depends the media (cable) used. Example CAT 5 or 6 coppper cable is 300ft.
Dec 14, 2012 | Fujitsu FC9612SAM1-I03 Flm-150 Hs Switch...
I need to wire lan to about 350 meters distance what do i need to do rick
The maximum length of LAN cable you can use is 100 meters (328 ft. For greater lengths you need a repeater.
Fordetails and specs, go to this WEB site.
http://en.wikipedia.org/wiki/Category_5_cable
Aug 12, 2011 | Computers & Internet
1. convert 10,000 Square meters to meters. 2. what will be the size of a room that can accommodate 300,000 cubic feet of fresh produce. 3. Thank you
  1. You cannot convert square meters (m²) to meters (m). The first unit measures an area, the second a length. You might as well ask, "what is the weight of two hours".
  2. There is no single answer without further constraints given. Even assuming a box-shaped room, it might be, for example 1ft x 1ft x 300,000ft or 100ft x 100ft x 30ft. Infinite more combinations are possible.
  3. My pleasure ;-)
Jan 26, 2011 | Office Equipment & Supplies
LCD TV IS CONNECTED TO CABLE USING SATELITE. CABLE IS RUN APPROX 150 FT FROM SAT DISH TO TV. RECEPTION IS VERY GRAINY,,,IS IT THE LENGTH OF CABLE? THE CABLE IS 100FT CONNECTED TO 50FT CONNECTED TO TV....
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
Conversion
One foot is 0.3048 meters. One square foot is 0.3048^2 meters = 0,9290304m^2. Multiply that by the area in square feet which is 100ft*150ft = 15000 ft^2.
The result is 1393.5456m^2
Jan 24, 2009 | Texas Instruments TI-83 Plus Calculator
CLP-510 SPL-C Error message
SPL stands for "Samsung Printer Language". You are using an USB cable that is either too long (above 6 ft.) or too thin (cheap cables).
The reason why the test page prints is because it is a very simple and small page (thinking on kbyte terms). But larger streams of data do not arrive correctly due to attenuation and the error page prints instead.
If it is absolutely necessary to connect beyong 6 ft, you need either a good quality USB cable (try the Belkin brand found at OfficeMax), or connect using a parallel cable.
Nov 01, 2007 | Samsung CLP-510 Laser Printer
JDSU Test-um Validator-nt 905 Gigabit Ethernet Cerfifier Cable Network Tester Logo
111 people viewed this question
Top JDSU Measuring Tools & Sensors Experts
ray gallant
Vuk B
JonSnell Electronic
JonSnell Electronic
Are you a JDSU Measuring Tool and Sensor Expert? Answer questions, earn points and help others
