Question about Protron PLTV-26 26 in. HD-Ready LCD Television
Connection exactally how do I hook this up to directv?
  • 3 Answers
Is it a hdtv receiver box or a regular one?
Posted on Jan 13, 2009
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV GenieĀ® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your GenieĀ® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Feb 08, 2016 | Televison & Video
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
jlopez.jagsat@sbcglobal.net
Mar 02, 2009 | Daewoo DV-T47N VCR
How to i hook-up a directv dvr plus to two tv's?
plug one tv using coax (screw in cable). plug the other using composite video cables( yellow, red, white). It will be easy to connect the tv that's the farthest with coax, its cheaper to purchase 50ft of coax vs 50ft of composite video.
Jan 03, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Initial set up w/directv
First, I hope you got an extended warranty with that. Otherwise it's a disposable T.V. after your warranty is up.NO PARTS are available. Hope it lasts more than a year..if your lucky. You need to change the channels on the direct tv box. Don't scan the t.v. You need the t.v. on channel 3 or video input that the box is connected to. Do you have hdmi cables? How did you hook the box to the T.V.? Did you read your book that came with the T.V. about hooking it up with a cable box??? Same thing as Direct T.V. box. That should show exactly how to connect. More info will help dtermind your problem.
Dec 05, 2008 | Dynex DX-LCD37 TV
Hook up dvd
Found this on http://www.satelliteguys.us/directv-forum/118015-hooking-up-dvd-player.html,
The Directv box should have at least two sets of out puts. You did not say what receiver you have and if the dvd is a player only of a recorder so its hard to say how to connect it.
If you have a dvd player only then take the output from the dvd player and connect it to you tv's second input, HDMI or component or what ever is a match between the two unites.
If you have a DVD-Recorder that you want to record programs from the directv receiver then take the second output from the receiver and connect it to the input on the DVD-Recorder and connect the output as above.
Hope this helps.
Sep 19, 2008 | Memorex MVD2042 DVD Player
Directv D10 receiver
I guess the obvious question is, do you have a DirecTV dish installed on your house? If you do, then most likely the cable you have plugged into the Satellite Input on the back of the receiver isn't connected to the dish. I would recommend calling DirecTV and having them send a tech out to double check the system.
Aug 09, 2008 | Directv D10 DTV Receiver
Coby dvd 755 home theatre system hook to directv
The composite output (red, white and yellow) on the directv receiver should connect to the audio in (red and white) on the coby ht system. Then you have to select the correct input on the coby til you here the audio from the DTV receiver
Feb 10, 2008 | Coby DVD-755 System
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
