Question about Frigidaire Affinity AEQ6000WH Dryer
Fridgidaire affinity dryer making very loud vibrating noise when running
Getting progressively worse
  • Official Brand Answer
  • 4,342 Answers
Hello - From what you have described it sounds like you either have a problem with the belt, front and/or rear bearing, or a loose connection with the motor or drum. I recommend contacting a professional to accurately diagnose the issue, the part(s) may have to be replace depending if they are worn, damaged or loose.
Posted on Dec 12, 2012
  • 2468 Answers
SOURCE: Affinity aeq6000es2. After two cycles of the
sounds like your heating element opened up,as it was running and when the element broke it arced and these were the sparks you saw,you will need a new heater element
Posted on Jul 19, 2010
Testimonial: "Exactly what my husband thought. Thank you so much."
heatman101
  • 43501 Answers
SOURCE: Vibrating and noise after cleaning
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ioipuio
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Gas Dryer making loud humming noise and vibrating.
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Nov 04, 2010
  • 3074 Answers
SOURCE: Frigidaire dryer FERB5700DS0 loud vibrating
drum glides, drum rollers or idler assemblage which is next to motor. This website will explain how to open dryer and the glide/rollers, Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Posted on Nov 28, 2010
rohdd
  • 294 Answers
SOURCE: My Frigidaire Affinity AEQ7000EGO dryer
Could be one of 4 problems:
  1. Worn or loose drum drive belt (Looks like a large fan belt) (New belt cost $12)
  2. The rear bearing(s) is bad and needs replacing (part cost $18)
  3. The front bearing guide(Sleeve) is worn (Part cost 2@$18.00
  4. Possible that the fan is loose from the motor and hitting housing.
All of the above are easy do at home repairs if you re handy. You should be able to get a good idea of what is wrong just by turning the dryer drum by hand. If the problem is the front bearing or guides, you will hear a grinding noise in the front at the top of the door.
Below is a link to diagrams and parts for your dryer. - J
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5156927
Thanks for using FixYa - a 4 THUMBS rating and POSITIVEComment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Posted on Mar 07, 2011
My Onkyo TX NR609 is not coming on and immediately shuts off and is progressively getting worse it is hooked to a harmony smart hub
Hi Liz, I am sorry about your issue. Please remove the HDMI cable from the receiver that is connected to the TV as a test. Check and see if the receiver stays on. If it does not the receiver would need to be serviced. Thank you, Onkyo USA
Oct 29, 2016 | Onkyo Audio Players & Recorders
1999 durango has a light clicking coming from the left front wheel stops when you apply brakes or turn but gets progressively worse as you drive
Could be a front wheel bearing. Jack the car up and grab the top and bottom of the wheel and try to pull in and out. If any slop is felt replace the bearing.
Dec 03, 2011 | 1999 Dodge Durango
Vibration at highway speeds loud humming noise,
Possibly a wheel bearing issue, does it `get progressively worse as speed increases or better as it decreases? does it stop when applying the brakes or get worse?
Oct 30, 2011 | 2006 Ford Escape
I have a 2004 Jetta gl 2.0 and I have had problems with lifting the trunk open. It has been progressively getting worse, and I see that the left side of trunk is lifting up now. Is this a common problem...
Check the trunk stays,(these are the small shock absorber type devices that hold the trunk open)
If it has progressively getting worse than I would say that one has slowly been leaking & placing a lot more strain on the other to the point now were they both have failed,Run your hand over the silver shaft wer it slides back into the black casing,if it is all oily the the seal has failed & the fluid has leaked out.These boot stays are reasonably cheap & take 2 seconds to replace.Also apply some lubricant to the boot hinges as over time these can get rusty & also lead to the premature failure of the boot stays.
Jan 09, 2011 | Volkswagen Jetta Cars & Trucks
1998 Holden Rodeo TR series 5-speed manual 2WD
run the fault codes
look for ambient temp sensor or baro sensor problems
Jun 30, 2017 | 1992 Isuzu Rodeo
Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Oct 07, 2007 | Toshiba 42H83 42" Rear Projection...
Frigidaire Affinity AEQ6000WH Dryer Logo
625 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
