Question about Brother MFC-8370DN-8370DN 5 in 1 Laser MFC Flatbed
Pdf on Brother MFC -8370DN
When I scan a document I can only have jpeg. , tif ,png and bmp files when I want to have pdf. What do I have to do to make this happen?
CarlGehrke
  • 169 Answers
SOURCE: Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
Posted on Dec 10, 2008
SOURCE: Printer / Scanner won't scan to pdf
Hello! I had this exact same issue or question, I guess you can call it. And unfortunately, the CD-ROM user guide was a lot more helpful for me than the Book guide. But anyway, to answer your question and anyone else who has this same question ...
What you need to do is locate the ControlCenter3 software on your computer for a little configuration. This automatically installs when you install the printer's complete Pro Suite drivers on your computer.
You might be able to find it somewhere on your start bar (left or right side of the start bar). It's a small blue icon with the acronyms "CC3" on it. Anyway, click to open the software. Once opened, you'll need to make some configurations so that when you scan to file, it'll be "PDF" by default.
So once you have this software open, "right-click" on the circle button that says "File" and choose the option that says "Control Center Configuration". Up pops a dialog box with two tabs - Software Button and Device Button.
Now in order to scan to pdf from your Brother MFC 9840 CDW, you simply need to change the "File Type" in the drop-down box to "PDF" under both tabs. You can optionally also change the "File Name" to a recognizable default file name of your choosing (I chose to change it to say "PDF File") and you can also set your default "Destination Folder" (otherwise your scanned PDF files will automatically be saved in your "Scan" folder). That's it! No need to mess with anything else.
Most importantly, you need to make sure that these exact same configurations are made under both the "Device Button" tab AND the "Software Button" tab as well.
Click "Okay" and now try to re-scan your document as a File. It should automatically scan it as a PDF file to your computer.
I hope this helps solve your problem if you haven't already been able to figure it out.
Posted on Jul 17, 2010
  • 700 Answers
SOURCE: Can I scan a document to PDF?
any scanner, indeed any document, picture format can be saved as pdf. i would suggest first scanning the document as text (for example to words, or openoffice or indeed whatever you use as your document management program) and then port it (sort of print operation) to any free available "translator" program which allow you to save file as pdf. alternatively you can scan your document as jpeg and then save it as pdf, but this tend to produce very messy outlook and results are usually horrible.
Posted on Jul 27, 2010
  • 903 Answers
SOURCE: I'm finding that the scanning
Hi, you can reduce the file size by decreasing the DPI (dots per inch) or resolution of the scanned image. This can typically either be done from the scanner's control panel or from the software installed on your computer. The less DPI you set it for, the smaller your file will be.
Some scanners will also allow you to compress files. If the MFC-7840W will let you, the option would be in the software program, and it should say "enable file compression" or "enable image compression" or something similar.
Posted on Sep 14, 2010
Geekman
  • 32281 Answers
SOURCE: My Brother MFC-7840W scans into
You need to install a PDF writer program first. There arequite a few freeware PDF writer programs on the Internet you can download onesuch as CutePDF.
Scan your document the click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. http://www.cutepdf.com/
Posted on Feb 21, 2011
There is no option to scan as pdf on my 4625 HP scanner (tif, jpg etc are available), how can I add pdf?
The HP SCANNER SPECS say: Scan file format Bitmap (.bmp), JPEG (.jpg), PNG (.png), TIFF (.tif), PDF (.pdf), Searchable PDF (.pdf), Text (.txt), Rich Text (.rtf).
That means it is supported. What you can try is to try and uninstall ("Programs and Features in Windows) the Adobe PDF program and get the free one to install again from: http://www.adobe.com/products/reader.html
If it still doesn't work (links itself into Windows and the HP software), try reinstalling the HP software or go to HP.COM and you can download the latest full-version file for your 4625 printer.
Dec 02, 2013 | HP DeskJet Office Equipment & Supplies
I am having trouble scanning text documents into pdf format. The pdf format type does not show up as an option to use. Also, scanned images are hugh files 8 -10 Mb. Help!
Good Day Agcarson!
It will be easy to provide you the answer if you mention the brand and model of your printer and your operating system.
Please post back.
Jul 01, 2011 | Office Equipment & Supplies
How do I scan more than one page at a time so I have a complete document of 6 pages instead of having 6 different document
you either select add a page, or use the document feeder. The document feeder will try to scan all pages into one file.
Mar 02, 2011 | Brother MFC 420CN All-In-One InkJet...
My Brother MFC-7840W scans into TIF files as individual pages. At my former job, we scanned directly into multi-page PDFs. What am I doing wrong?
Feb 21, 2011 | Brother MFC 7840W Printer
Jul 27, 2010 | Brother MFC 8440 All-In-One Laser Printer
Why doesn't the HP Deskjet F4280 scan documents to PDF
to get pdf files you have to have adobe installed in the computer
Jul 01, 2017 | HP DeskJet F4280 All In One Printer InkJet
MCF 6490CW SCAN AS A PDF
I was trying to figure out how to scan multi-page documents to a single file and found this on the Brother website:
Double-click on the ControlCenter3 icon located in the Task Tray to launch the program window.
Click on CONFIGURATION -> SCAN.
Choose the type of scan you require. The choices are: IMAGE,
E-MAIL, and FILE.
The Scan to configuration window will appear.
The SOFTWARE BUTTON tab configures the Scan to button within theControlCenter3 software interface. The DEVICE BUTTON tab configures the Scan to key on the Brother machine. Choose the tab you want to configure.
Under FILE TYPE select an option that allows multi-page documents:
a) PDF (*.PDF)
b) Tiff Multi-Page # Uncompressed (*.tif)
c) Tiff Multi-Page # Compressed (*.tif)
Click OK.
Apr 28, 2009 | Brother MFC 6490CW InkJet Printer
Hi,I have got a Canon,smartbase MPC 400 printer/scanner. My question is: How can I scan a document straight to a PDF file,because it only gives me options for TIF,BMP and JPEG. I have downloaded a TIF to...
I'm using an MP780. Usually when I scan an image to jpeg I press START, CANON, SCANGEAR STARTER. This open a window to ScanGear MP. Since I use the Advance Tab I can set the DPI and whatever outputs. The DPI rsolution will determine the size of the file also. When it is finished scanning it goes to the next window which has Save As Type and Save Scanned Image to. Save As Type is where you can choose JPG or TIFF or BMP. Hope this helps.
Nov 13, 2008 | Canon Office Equipment & Supplies
Setting the format of the picture i scan
Ok I am not sure why ya scanner won't save in JPEG .. however converting the files to JPEG is relitively "Simple". After saving the Scanned picture.. Open it up in say MS Paint, Painshop etc, then simply choose "Save As.." from the File Menu, and save it as a NEW image file this time with a JPEG extension. IE: origional... picture.png or picture.bmp ... save as ...picture.jpg .. ya should be good to go. :)
Jun 14, 2007 | BenQ 5000U Scan to Web Scanner
Brother MFC-8370DN-8370DN 5 in 1 Laser MFC Flatbed Logo
29 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
