Question about Refrigerators
Re: Lights and fan problems for Sub Zero 532 Side by side refrigerator.
This unit is getting old at about 19 years. Recently, we had a power outage and after the power was restored, the lights no longer worked on the fridge side only. The freezer lights do work. Also the condenser fan motor is slow and not creating much (if any) airflow. Sometimes the fan does not operate at all when the compressor comes on. Both the fridge and the freezer appear to be cooling acceptably. All light bulbs and door activated light switches are not at fault as I have interchanged them with the freezer side and they all work on that side. 'Resetting the automatic light shut-off' by leaving door closed for 30 minutes (per the manual) does not reactivate fridge light. I suspect there is no power to the fridge light switch. Is this related to a worn-out fan motor, or any fan motor circuits? Would a bad fan motor be the cause of failure to reset the fridge light? What else could cause these problems at the same time?
    New Friend:
  • 26 Answers
First of all if you're condensor motor is controlled by electronic control board varyable speed type you might want to think about looking at replacing the control board. But first I would take a voltmeter test to see if the fan motor is getting enough voltage. If the voltage varies with the temperature inside the box then you have a controller. If the voltage remaind constant (120) and the motor still slows down yoy have a bad fan motor. As far as you're like the problem goes the only thing I can think of besides loose wires or bad switch.would be if it operated off the same control board.
Posted on Dec 10, 2012
  • Jaeger Jensen Dec 10, 2012
    Thanks. I think this sounds like the right track since the lights are now malfunctioning also. Must be some sort of broad control center. Have any idea here would I find the control board & what it looks like? Another strange thing going on (that may be related) is my electric bill last month was huge - about an 85% increase over same period last year. This year is milder in temp and only my second year with a new geo-thermal heat system & HW tank. That was the whole reason I started checking major power consumption sources! I can't believe this refer could gobble an additional 1000 KWH power in one month and still appear to operate fairly normal. I mean it still cycles on & off every 45 min or so. Something strange must have happened here recently.
  • 56 Answers
SOURCE: SubZero 532 frig lights out
There are two door switches one for fan and the other for the lights. With the compressor running, there are two so yu need to make sure it is the refrigerator and not the freezer, open the door and press the right switch and listen for a fan. The left should be your light switch and the problem is generally in the switch, on rare occasions there is a failure of bi-metal safety switch part number 4200850. One very rare occasions you may have a wiring proble.If you go to www.subzero.com there is a showroom locator tab on the top right corner, click it and you will go to a locator page which will get you to your local parts didtributor.
Posted on Dec 03, 2008
peyton32034
  • 410 Answers
SOURCE: Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Posted on Feb 07, 2009
  • 7 Answers
SOURCE: Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Posted on Dec 11, 2009
kapishtech
  • 2272 Answers
SOURCE: During a recent thunder storm,
The bulb is controlled by light switch only. The switch is bad or there is loose connection on the light switch.replace the left light switch with Sub Zero Part # 3060140.Remove the light switch out and then properly reconnect the wires to their respective position and recheck if still same problem then it has to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 01, 2010
heatman101
  • 43501 Answers
SOURCE: Fridge side is getting warm.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 17, 2011
Is it normal for warm air to blow out of the fan at the top of a side by side sub zero. Its over 20 years old and we recently had the compressor replaced on the freezer side.
warm air will blow out from the condenser fan which is in the same area as the compressor.
There should be no warm air inside the freezer of fridge.
Jul 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero model 532 side-by-side icing on inside panel
I would get in touch with SUB-Z customer service, they are the only company that still cares about customers
800.222.7820
They will be able to get it fixed
Jun 08, 2010 | Refrigerators
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
Power requirement sub zero 532
115 volts on a 15 amp circuit
May 19, 2009 | Sub-Zero 632 / S
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
Nov 30, 2008 | Sub-Zero 561 / F
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Jun 26, 2008 | Sub-Zero 632 / S
Sub-zero 532 problem
you have a Freon Leak @ the Evaporator.. Ice ball on back wall.. left side....
Apr 15, 2008 | Sub-Zero 632 / S
WHATS THAT NOISE??!!
more likely a bad compressor, which is more sensitive to temperature extremes...may be cheaper to replace the frig.
Jun 10, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
