Question about Digital Spectrum El-101 Picture Frame
Digital Spectrum EL-101
My digital picture frame doesn't turn on or do anything when I plug it in, other than make a humming noise. Please advise. Digital Spectrum EL-101 Thank you, Sallie Brigance 214-789-1651
  • salliebrigan
    salliebrigan Dec 12, 2012
    So I took it apart and nothing seems to be loose. Any suggestions on any troubleshooting? It's a 7" digital photo frame that was touchscreen. It only plugs in to charge, but it doesn't even power on when plugged in. There is not a way to put batteries in it. I can't tell if there is an internal battery when I took it apart, just a big circuit.
My 10" digital not working it comes on but not reponding the icon dont come up its not doing anything please help
hi
try to see if you have a reset hole in the back or sides if not then try to reconect the battary or to empty the battary .
May 17, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
Help w/ quantaray 10.4 digital picture frame
pls backup ur data & reformat ur sd card to fat 32 using ur pc
Jan 05, 2014 | Quantaray Photography
Do you need software to have slide show on frame
What make and model digital picture frame?
Jul 05, 2013 | Photography
I'm getting an error when trying to install the driver for the NuVue 561 digital picture viewer. This is the first time it has been used. Any assistance is appreciated. Thanks!
Can you please tell me what kind of error is occuring? What does it say? I suggest you, without knowing the problem, to reinstall the driver and then, to restart the computer.
May 12, 2011 | Spectrum NuVue 561 (U30333) Digital...
I have no instructions for use
Pandigital doesn't have a manual on their website. However, the FAQ (frequently asked questions) may solve your issue: http://pandigital.net/default.asp?PageID=266&Preview=True . If this direct link doesn't work, start at http://www.pandigital.net/ then click on Support, FAQ and then Additional Pandigital FAQ.
I hope this helps.
Apr 15, 2011 | PANDIGITAL 7-Inch Digital Photo Frame with...
I broke the glass on the digial picture frame how do I get a replacement for MemoryVue MV-800
I'm afraid that Pacific Digital went our of business some time ago, though they are still be sold by Digital Spectrum and others. You can buy a complete replacement for your frame from Adorama Camera through Amazon for under $60, which is certainly less than a repair would cost (http://www.amazon.com/Digital-Spectrum-MemoryVue-MV-800-8-Inch/dp/B000BP8AMY)
There are also nicer, more modern units from many other manufacturers for similar or slightly higher amounts.
Jan 30, 2011 | Pacific Digital MemoryVue MV-800 Digital...
Digital Spectrum El-101 Picture Frame Logo
83 people viewed this question
Top Digital Spectrum Home Security Experts
Lawrence Oravetz
Are you a Digital Spectrum Home Security Expert? Answer questions, earn points and help others
