Question about Garden
Chainsaw Clutch I have pulled a lot of clutches off over the years and generally you can just use a socket or a punch, but with this one there does not seem to be anywhere to actually grip the clutch. The clutch is the same as on a Shindaiwa 377. Any help would be great,
2 Suggested Answers
m_barrell
SOURCE: clutch removal chain saw shindaiwa shindy
How do i remove this type of clutch? I have morked on a bunch of different saws but this shindaiwa is really annoying me. I can not find any way to remove it. any help would be great. thanks
Posted on Dec 10, 2012
How do you remove the clutch on a 025?
remove spark plug.
block ther piston with a piston stop.
remove clutch drum exposing the clutch
it has to be turned clockwise to remove it. 19m socket
Sep 02, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
How do you change the clutch?
Remove the side casing. (bar side)
Take off bar and chain.
Remove E-clip holding the clutch drum on.
Remove clutch drum and needle cage bearing.
This should expose the clutch.
Remove spark plug.
Use a piston stop to stop the piston rising, Sometimes a knotted piece of pull cord fed into the cylinder is just as good.
Turn the clutch clockwise with a socket to unscrew.
To put clutch back on turn anticlockwise till piston cycles back and hits the piston stop again and tighten. Replace spark plug and clutch drum, bearing, bar and chain and side casing.
Mar 15, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Cannot remove wornclutch
You need to block the cylinder to stop the piston rising.
I prefer to use a piece of pull cord with 3 or 4 knots along 4'' of it. Its safer than using plastic piston blocks that can break inside the cylinder.
1.Remove the spark plug.
2.Insert knotted pull cord into the cylinder (be careful it doesnt exit the exhaust port)
3.Turn clutch clockwise until piston is blosked by the cord.
4.Place a socket on the centre of the clutch and turn clockwise.
The clutch should just unbolt off the crank shaft. reverse the process when putting on the new one. :)
Jan 27, 2013 | Stihl Chainsaw 045 056 Clutch Chain Saw...
How to remove the clutch assembly on a stihl 015 AV
Remove spark plug.
Use a piston block to stop the piston rising.
Remove the chain sproclet cover.
Turn the clutch with a socket clockwise to undo.
Dec 11, 2012 | Stihl Chainsaw Hedge Trimmer Clutch 015 Av...
Instruction to remove and replace cage bearing on husqvarna 055 chainsaw.
I guess we are talking the bearing in the clutch drum, to replace this you need to remove the side cover nuts and remove the side cover/chainbrake, make sure the brake is de activated by pulling the hand guard fully back to the top handle before removing it, the clutch has a 15mm centre nut, jar the clutch off against the compression of the saw with a suitable socket and speed brace, if you have an impact wrench this will remove the clutch in seconds, the clutch is just spun onto the crank with a left hand thread, turn clockwise to remove, once off the drum and bearing will just come off the crank for replacment.
Oct 05, 2011 | Husqvarna Garden
Are there any serious problems with removing the brake and clutch assembly on a MACCAT435 Chainsaw.
There should be no problem removing the chain brake as long as you have de activated it by pull the handguard fully back to the top handle , there is a special tool to remove the clutch part no , 530031112 this fits into the cut a ways in the clutch and you jar it off with a 19mm socket.
Jun 14, 2011 | Garden
I need to change the oil pump in a stihl 026 chain saw but I am not sure how to access the pump. I believe it is beneath the armature but I am not sure how to take it off. Any advice or a...
Removing the Oil Pump
  • 1
    Pull off the spark plug's rubber boot. Unscrew the spark plug with the socket wrench. Remove the spark plug and insert the piston stop tool into the hole. Remove the starter cover and turn the flywheel by hand until the piston contacts the stop tool.
  • 2
    Unscrew the brake band's cover screws with the star Allen wrench. Remove the brake spring from its anchor pin with the end of the screwdriver. Caution: this spring is under a lot of pressure and may pop out unexpectedly. Remove the brake band from its seat on the crankshaft.
  • 3
    Remove the E-clip that holds the washer, sprocket and clutch drum to the crankcase. Pull them off the crankshaft. Unscrew the clutch's bolt with the socket wrench. Loosen the bolt clockwise and remove from the crankshaft. Pull off the washer. Remove the clutch shoes and the clutch spring.
  • 4
    Twist the worm and drive spring clockwise and remove them from the crankshaft. Unscrew the oil pump's mounting screws. Take the oil pump off its seat and remove from the crankshaft. Remove the bottom washer.
  • 5
    Disassemble the oil pump. Knock out the spring pin on the bottom with a punch. Pull the bottom control bolt from its hole and remove the O-rings. Pull the end plug off housing and remove the pump piston, spring and washer.
Read more: How to Repair the Oiler on a Stihl Chainsaw ' eHow.com http://www.ehow.com/how_6515266_repair-oiler-stihl-chainsaw.html#ixzz1H62BeTAW
Mar 19, 2011 | Stihl Chainsaw 024 026 Oil Pump
How to remove chainsaw clutch
hi
remove statrer cover assy
remove plug, rotate engine until piston @ bdc - insert a thick 6 mm nylon starter rope through plug hole and rotate piston so that it pushes rope in between piston and cylinder top this locks the crankshaft
its called a soft stop
take a punch and hammer and give the clutch 1 or 2 hits in and clockwise direction clutch should loosen
to refit clutch , remove soft stop and rotate engine counter clockwise fit the stop and jamb it again between piston and cyl head then spin on the clutch ( threads are left hand ) use punch and give 1 or 2 hits to tighten again - remove soft stop and refit plug and starter cover assy
clutch should tighten further when engine runs
cheers paul
hope it helps
Aug 02, 2010 | Garden
I need to change the clutch drum
Don't know about your particualr saw, but general instructions are : take the bar cover off, take the bar and chain off, put your piston stop in, remove the clutch nut by unscrewing it clockwise, remove the shoes and springs from inside the drum, and pouit them in the new one, replace it all. If you don't have a piston stop you can pull the starter cord all the way out and stuff some of it into the spark plug hole to stop the piston moving when you turn the clutch nut.
Apr 20, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Clutch cover wont go back on
Your cover probably won't go back on because the kickback/chain brake is on. Pull the handle on the cover back until you hear a click, the it will go on. As for removing the clutch, you need Poulan tool # 530031112 and an impact witha 3/4 socket. If you're just trying to reset chain break, removing clutch is not necessary, just pull back on handle as I said before.
May 30, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
