Question about Samsung LN40B530 40 in. LCD HDTV
MY Samsung when you turn it on it have red line going down the side
The tv have to stay on for about 30min before the picture will play right
    Top Expert:
  • Samsung Master
  • 14,553 Answers
A bad connection (solder) or a loose plug or cable someplace---problem with this set is the issue could be inside the front screen or Display Panel as it is called where it cannot be got at--replacing the Display is not cost effective if it is the cause as it costs more than a new set.
Posted on Dec 10, 2012
  • 579 Answers
SOURCE: 40 inch lcd blue line vertical
The display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Hope ya fix it!
Posted on Jan 06, 2008
heavyice
  • 374 Answers
SOURCE: hpr4262 samsung plasma picture problem
You need to call a technician.The problem lies in the board [internal].
Posted on Jun 25, 2009
SOURCE: Insignia(samsung) 50" plasma Vertical red lines
I would take it back. I know from purchasing an Insignia LCD from them a while back, the TV just died after about 4 or 5 months. They ended up offering me another TV or with store credit. I took the store credit and chose another TV. I also did not have a warranty. I was told since it was Insignia (which is a Best Buy house brand) that replacing it was not a problem. Good luck.
Posted on Jun 30, 2009
  • 304 Answers
SOURCE: samsung lns4095dx/xaa after 30min the screen goes
The first place to start is with the Main bd. The second cause would be the T-con bd. Have a trained Samsung tech troubleshoot to find out and repair the set.
Posted on Jul 17, 2009
  • 610 Answers
SOURCE: Vertical lines in picture
The machine is still under warranty from samsung so I would call 1-800-samsung to find the nearest service center. Problem could be caused by a bad main board, bad lvds cable or a defective t/con board or lcd panel.
Posted on Jan 22, 2010
Testimonial: "Thank you so much for the prompt reply, it was very helpful! "
I have a Samsung UN55ES6500FXZA TV with several picture issues.
Sounds like the Y buffer board upper and/or lower are going bad
Feb 12, 2018 | Samsung Televison & Video
What is up with my 360 when ever i play it for about 30min it shows green fuzzy lines down the screen of my tv and purple fuzzy lines down my tv screen and after those two happen sometimes it will have red...
well definitely video issues of some sort. if you have a second video cable (or hdmi cable if your unit supports that) give that a try.
*assuming that doesn't work Unfortunately it sounds more likely that it's an issue with the video card inside the xbox. this may be repairable by a professional.
if you have it under warranty i would contact microsoft for a replacement/repair https://myservice.xbox.com/en-US/Pages/Welcome.aspx or call Toll free: (800) 4MY-XBOX
~best of luck!
Mar 13, 2011 | Microsoft Xbox 360 Console
Red lines on Sony KP51HW40 Rear projection TV
Yeah, seen that more times than I shoulda in the last 4 years. The red picture tube has a cathode to heater short. That means it's no good. That red picture tube is no longer availible. But all is not lost. There is a company that rebuilds those tubes reasonably. Most reputable tv shops will know this. The ones I've done cost around $450 out the door. One minor hitch is that with all the shipping involved the job usually takes about three weeks. That can be expidited but then the price goes up.
May 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Red line down right side of screen
I would have a tech come out and look at it. Sometimes the ribbon connectors from the upper or lower buffer boards have poor or corroded contacts. Should'nt be a major deal since it comes and goes.
Apr 21, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Samsung 52" rear projection tv convergence problem?
THE PROBLEM IN YOUR TV. IT'S THE CONVERGENCE. YOU NEED REPLACE THE CONVERGENCE STK'S AND AFTER THAT YOU NEED DO ADJUSTMENTS.
Jan 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Samsung HCN4226WX/XAA Rear Projection 42" TV Wont Turn On
take off the back there is a board at the top right with two black stk-392-040 chips on it unplug the red connector at the left side of the board then plug set up and see if it comes on if so the chips on the board are bad or replace the board about $100.00
Aug 02, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung LN40B530 40 in. LCD HDTV Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
