Question about Mattel GirlTech Password Journal 6
Password journal drawer won't open
Justice password journal low batteries
I used a set of cutting pliers and lifted the back two rivets off. Then i gently peeled the paper up and slid a knife under the strap that was glued down. Replaced the batteries, put the rivets back in and used a small screw driver to mesh the strap back on the rivets. Lightly re-glued the strap and scotch taped the paper back on. Back in business, made one girl happy!
Dec 26, 2013 | Justice Girls Electronic Password Journal
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
I have a Minolta CSPro 3050.. legal paper drawer won't close..and it won't copy
To the rear cover located one hole before waste toner box.Introduction one long screwdriver and push the unlock button.
Jan 18, 2013 | Konica Minolta Copier Toner EP6001 CS Pro...
Computer shows ddo &won't finish the wash
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
Dec 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
Cd player won't open with the push of the button
Mechanical or electronical drawer?
Is the button stuck?
Oct 25, 2012 | Acer Aspire T135 PC Desktop
HI. My Acer Aspire 3500 DVD drawer was I guess off track. The drawer wouldn't open so I pried it open. Now it won't stay shut and when it is shut I can't open it unless I use a paper clip.
There is very little you can, these items in general cannot be repaired. Go to www.ebay.com Type make and model of laptop, refine search to cd/dvd driver.
Jun 12, 2012 | Computers & Internet
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
CAN'T OPEN DRAWER
Hello
There is a motor along with belt to control the disc tray for every DVD player. If this belt or motor [loading motor] has trouble, the tray won't come out or get into. Check these for perfectness.
Dec 12, 2011 | Philips DVP642 DVD Player
Mattel GirlTech Password Journal 6 Logo
Top Mattel Toys Experts
thegtw
Tracy E
Level 1 Expert
Tom Chichester
Are you a Mattel Toy Expert? Answer questions, earn points and help others
