Why does my dyna-glo tank top heater flare up
SOLVED! in short, replace rivets, or bolt the front cowling to the back cowling. the rivets that attach the front cowling wore loose on mine. i thought, at first it was the back cage shorting out the thermocouple, by touching it. i took this whole thing apart to fix it. I resoldered lines, cleaned thermocoule, and soldered an alligator clamp on to the actually thermocouple, since solder will just melt. This must have been tig welded onto the thermocouple. if you remove that ground wire, it won't stay lit, after you stop pushing the lighting button in. I made it through a tank, after doing all this stuff, including putting new rivets in. switched tanks, then more flare ups, after about 10 minutes on new tank. i noticed the back of cowling getting red this last time, before it flared and shut off, so i looked and 3 of my new rivets had melted, because i used aluminum replacements. now i put steel rivets in, the back of cowling is tight, and air can't get in from the top to make the metal hot. which is what i believe causes the unit to shut off. If these rivets don't last, i'll just bolt the two pieces together.
Posted on Jan 15, 2015
  • Scosmical
    Scosmical Jan 15, 2015
    i threw one of these away. and just bought another one. i wish i had figured this out a couple years ago.
Buffalo12980
  • 625 Answers
SOURCE: dyna-glo
try this site - they have dyna glo parts
http://www.robinrents.com/heaterparts.htm
Posted on Dec 11, 2007
SOURCE: Dyna-Glo RMC95C6 Kerosene Heater
I have uploaded the manual for all to use here.
Posted on Nov 22, 2008
steve_lima
  • 181 Answers
SOURCE: dyna glo torpedo heater has e 1 error code and shuts down
you either have too much air pressure or you don't have enough pressure.do you know what your pressure is set at.
Posted on Feb 17, 2009
steve_lima
  • 181 Answers
SOURCE: were can i get a 16oz to 20lb propane tank conversion kit for a
try this http://www.portableheaterparts.com/ they carry parts for these units
Posted on Mar 23, 2009
SOURCE: dyna glo workhorse heater
you need to pull top cover off. And bend the igniter in to the spray of fuel and check the gap of the ignighter to 3.5 mm and bingo should work i just bought one and had to do this to it
Posted on May 06, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Where can I buy a regulator for 2 burner tank top heater
Our "old fashioned" local hardware store carries a line of several regulators. So, you might try all of your local hardware and/or building supply stores.
Jan 09, 2015 | Dyna Glo 18,000 - 30,000-BTU Liquid...
Dyna-Glo Heater using a whole tank of propane in like 5 or 6 hours.
Unless you have a leak, or to small of a tank, it is using a lot of BTU's
Dec 31, 2014 | Dyna-Glo Heating & Cooling
Dyna-glo rmc tt30dgp wont turn on
Your regulator has failed, just like mine did. Contact GHP Group Inc, (877) 447-4768 to order a replacement regulator - MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Replacement cost including shipping is a couple bits over $21.
When talking to the technician on the phone, he cautioned me against rapidly opening the tank valve, which hammers the regulator (the replacement one is more robust than the original), kinda' like how water-hammer can cause damage to water pipes and/or water appliances. Open the tank valve gently, don't just whip it open (like I used to), your regulator will last a lot longer that way.
Because of the press-fit and pins used in the regulator construction & assembly, self-repair is not possible or recommended since the regulator may not seal correctly afterwards.
Feb 28, 2009 | Dyna-Glo RMC-8001SS Heater
Filters for dyna-glo pro
You can make your own filters out of felt and I have also found that with some minor modifications most of the parts from Mr. Heater will work with Dyna Glo. I have a 170btu kerosene heater and just installed an ignition, a high limit control and a flame sensor from Mr. Heater and it works like new.
Nov 03, 2008 | Desa International ALL-PRO® SPC-85 Utility...
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
