Question about Jandy Aqualink RS8 Pool/Spa Combo Control System
The Date and Time change back to installation date and programs no longer work
I keep finding the filter pump turned off and the systems screen showing the pool in "Clean Mode" with the date and time reset to factory settings. I am able to reset the time and date and reprogram only to find it reset at random times. Occasionally the display shows a water temperature short, but after resetting works properly.
  • btmciver
    btmciver Dec 10, 2012
    I replaced the 9v battery but problem persists
    Top Expert:
  • Jandy Master
  • 8,502 Answers
If you have a 4 button spa side remote unplug and see if it continues its called ghosting if so replace controller
Posted on May 02, 2015
Sprite 2 GOTO mode not working. date keeps reverting back to the year 2036
you need to remove the cover with the power off. inside you will find to chips in caddes. remove the both. remebring where they went. un plug the hard drive/s and put power back on without the chips in should come on screen saying systerm error. turn off put avery thing back in and turn on now should start up and ask you time and date program it in and it will rest. should start up with the date and time you set now.
Jun 20, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
I want to restore my computor its a samsung v25 back to factory settings its an older model ive tried f10 f8 f11 but nothing working can u help please
Hi
The first thing you will do is to click on the "Start" menu in the lower left-hand corner of your computer screen. Click on the "All Programs" prompt. This will take you to another menu. In that menu, you will find an "Accessories" category. Go into "Accessories." Once you are in "Accessories," you will find another menu. In this menu you will find a "System Tools" category. Go into the "System Tools" category. Inside "System Tools," you will find a number of programs listed, among them "System Restore." Click on System Restore.
  • 2 Follow the program's prompts. The following program will lead you through a number of screens where you will need to navigate toward restoring your computer to its earlier setting. On the first screen, you are given a couple choices. Choose "Restore my computer to an earlier time," then click "next." The following screen will give you several choices on several days of which date and time you would like to restore your computer to. Choose one, and click "Next."
  • 3 Confirm and restore. The following screen will give you one last chance to confirm the date and time that you will restore your computer to. Make sure that this is the exact date and time that you want it restored to, and click "Next." The computer will turn itself off and automatically restart. When the computer restarts, the restoration should be complete. Your computer will be as it was exactly at the time of the restoration that you chose.
  • 4 Use preventative measures to ensure that you are prepared for the future. The best way to prevent problems with your hard drive in the future is to back up all of your information and programs. The most efficient way to back up all of your programs and data is by storing them on a separate external hard drive. These external hard drives are relatively inexpensive and can be purchased at any electronics store. They generally come with their own installation software and instructions on how to back up your data and computer programs.
  • Cheer
    Jun 12, 2011 | Computers & Internet
    How do i change the time
    The time and date are programmed through system programming. A 4015 phone cannot do this programming. A 4150 phone setup as a subattendant phone with the "attendant setup time/date" class of service option enabled for the 4150's class of service can change the system time and date. This is accessed through the LCD touch screen keys of the 4150. Scroll through the options in the screen until you find set time /date.
    Also an attendant console with the "attendant setup time/date" class of service option enabled for its class of service can change the time and date. Press the function button then choose attendant function.
    Choose set time. Enter the time in four digits as in 0800 for 8:00. Choose PM if needed. Choose set.
    Choose exit to finish.
    Dec 13, 2010 | Mitel Superset 4015 Corded Phone
    Program Group A is selected and the filter pump is programmed to start at 12 noon but does not turn on. If I start it manually, it runs fine and will turn off at the proper time. What could it be? ...
    Check to see if your nine volt battery is good. The aqualink will hold it's programs but lose time and date. At that point it goes back to factory set. You have to have a fresh battery to avoid this.
    Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
    System date error! Please check NDS system data. This has come up on screen, could you give any advice please
    Hi ya
    remove your R4 card. Go to the system setting and turn your date on the dsi back by a year!!
    Put your R41 back in and it should work.
    happened to my sons and the only way it would work was to turn the date back.
    Apr 18, 2010 | Nintendo DSi Black Console
    How do i change the time before my laptop screen goes blank on my eee pc and keep it open before it does that?
    Go to start - control panel - power options - and then go down to where it says turn monitor off and change the miniutes to the time you would like.
    Mar 19, 2010 | Dell Inspiron 8500 Notebook
    I need to change the time.
    Must be done on a MLX20-L
    Changing the time on a Avaya Merlin Magix system is accomplished from the system programming console. The date is change separately from the time.
    Changing the date:
    1. Press Menu
    2. Press System Program
    3. Press Exit or Start
    4. Press System
    5. Press Date
    6. Enter the date as: mmddyy where mm = month, dd = day, yy = year
    7. Press Enter
    8. Press Exit or Back
    9. Press Home or Exit
    Changing the time:
    1. Press Menu
    4. Press System
    5. Press Time
    6. Enter the date as: hhmm where hh = hours & mm = minutes
    7. Press Enter
    Nov 02, 2009 | Avaya MLX 5D Corded Phone
    AVAYA MERLIN ETR-18D TELEPHONE
    The following is from here.
    IF you have a Lenend or Magix system. IF SO, you will have a VERY LARGE display phone, ususally at the receptionist station. It will be either a MLX20L or a 4424LD+. If so....
    Changing the date:
    1. Press Menu
    4. Press System
    5. Press Date
    7. Press Enter
    Changing the time:
    1. Press Menu
    4. Press System
    5. Press Time
    7. Press Enter
    Aug 27, 2008 | Avaya MLX 5D Corded Phone
    Set time and date
    hit the feature button (gray, looks like a globe on it) under the display, under the 3 gray buttons in a row.
    then **8463
    password is 23646
    follow prompts :)
    hit the hang up (phone with arrow underneath) when fone.
    Jan 22, 2008 | Lands Phones
    Jandy Aqualink RS8 Pool/Spa Combo Control System Logo
    114 people viewed this question
    Top Jandy Pool & Spa Experts
    David Spradling
    David Spradling
    Craig Butler
    Craig Butler
    Jay Finke
    Jay Finke
    Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
