Question about PIONEERPOS 15 Inch M5 PENT-M/1.6 1GB XP SPKR 2.5 Inch HD 80GB WALLMOUNT VESA 75 [jm15xr10003z] PC Desktop
Water leaking at the bottom sides and middle - PIONEERPOS 15 Inch M5 PENT-M/1.6 1GB XP SPKR 2.5 Inch HD 80GB WALLMOUNT VESA 75 [jm15xr10003z] PC Desktop
  • 7,627 Answers
Of your PC Desktop? Unless your CPU is liquid cooled, you have serious problems.
Posted on Dec 10, 2012
We have a slow water leak in our fridge. The water pools under the bottom 2 produce drawers.
On most newer fridges, there is a very shallow 'V' shaped collection channel at the back of the fridge just above the bottom drawers, this is for condensate collection. In the middle of this channel there should be a hole, this quite often gets clogged, and over flows, hence the water at the bottom of the produce drawers, clear the hole and it should cure your leak, worth checking every couple of months.
Mar 22, 2011 | Samsung RM255LASH Side by Side...
It is leaking on the bottom when I do laundry. The hoses are fine. The water seems to be around the edges on the bottom of the washing machine. The machine is only 5 1/2 years old.
if you look at the front inside panel and the side panels nd if you see like black spots half way up the panel you have bad tub seals and that's what it sounds like you have.the tubs have to be separated and the middle seal has to be changed out.you need special tools to do this job.might be better replacing the washer if it's the problem.fill it with water,run it and look at the tranny part coming out the middle of the tub on the bottom of the tub,let it agitate and put it in spin,if you see water leaking out the middle of the tub it's the tub seal
Jan 19, 2011 | Amana Washing Machines
Refrigerator is leaking/dripping clear water, but the ice maker lines have no leaks and it appears to be coming for the middle of bottom of the box somewhere.
You may have a leak from the water supply line that is attached to the fridge from the house hold line near the bottom right corner of the fridge.
Jan 29, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Leaks water periodically onto floor bottom left corner freezer side
your freezer cabinet need to get all out and open the back wall
there is a drain hole in the bottom middle of it make sure it is
clean and if you pure water they go all the way
through the pip to the drain pan next to the compressor.
good luck 911servicetoday . com.
Jun 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
I have a Frigidaire side by side that pools water (ice) on the bottom of the freezer, then leaks on the floor. Any ideas? I'm very eletro/mechanical
take rear panel off inside freezer and you will see a drain tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Refrigerators
Leak in washing machine
can you tell where the water is hitting the belt from is it in the middle of the wash tub or from the outside of the wash tub please let me know if its from the middle of the tub its probably the seal that keeps the agitator from leaking, and if its from the side the in lines from the water spicket or the valve that controls hot and cold in the machine could be leaking, please look closely and try to see where the wateris dripping down from. thank you, then let me know
Dec 21, 2007 | Washing Machines
PIONEERPOS 15 Inch M5 PENT-M/1.6 1GB XP SPKR 2.5 Inch HD 80GB WALLMOUNT VESA 75 [jm15xr10003z] PC Desktop Logo
18 people viewed this question
Top PIONEERPOS Computers & Internet Experts
David Payne
David Payne
Are you a PIONEERPOS Computer and Internet Expert? Answer questions, earn points and help others
