Question about Nikon D70s Digital Camera
Cant get remote to work on my nikon d70 camera
I have an infrared rc n1se for my nikon d70 and cannot figure out how to get it to work..
Did you try you shooting mode button and then rotate your command dial until the remote shows up on you for me!
Posted on Jan 17, 2009
How do I set up Vivitar remote for Nikon D5300
Set the camera to one of the two remote modes. The quick-response remote mode fires the camera when you press the button. The delayed remote mode gives you two seconds to hide the remote behind your back before firing.
See "Remote Control Photography" beginning on page 70 of the manual: . Just pretend you have the Nikon ML-L3.
Jul 14, 2014 | Vivitar RC-6 Infrared Shutter Release for...
The RC-LTL remote for the Olevia 226T does not power on or off?
There is an easy way to check if the problem is the remote or the receiver of the TV. Take your phone and use the camera feature to look at the remote control infrared light. When you press the power button you should see the infrared light blinking the same way it should blink when you press the channel button. If there is no blinking when you press the power button then the control is faulty. You will need to use a camera of some type because we cannot see infrared with our own eyes unless looking through a camera.
Dec 01, 2013 | Olevia RC-LTL Remote Control
Does nikon D5000 work with infrared
If you're asking about an infrared remote control then yes. It will work with the ML-L3 remote or equivalent. You will have to set the shooting mode to one of the two remote modes to do so.
If you're asking about taking infrared pictures then not so well. The camera has an infrared filter that masks out most infrared light from reaching the sensor. There are companies such as LifePixel which will remove the infrared filter to convert your camera into an infrared camera.
Apr 16, 2013 | Jjc Wireless Infrared Control For Nikon...
My Nikon D80 infrared sensor is not working. Wondering if I can fix, or do I need to take to someone?
Just to be sure, you are setting the camera to one of the remote modes? If you're not, the camera will ignore the infrared remote.
Jan 18, 2013 | Nikon D80 Digital Camera
Vivitar RC6 - NIK
You need to set the camera's release mode to one of the available remote modes. As a minimum there should be a remote mode which fires the shutter when you push the button on the remote and a delayed remote mode which gives you two seconds to hide the remote behind your back. Since you neglected to specify the model of your Nikon dSLR I can't tell you exactly how to change the release mode. Refer to your camera's manual, or else reply to this post and specify the model.
Jul 30, 2012 | Vivitar RC-6 Infrared Shutter Release for...
ML-L3 remote was working then it wasn't. Not sure if I have changed a setting on the camera (Nikon D70) or the remote has failed. Have changed battery on remote but still not working. How can I test the...
Set the camera's shooting mode to one of the two remote modes. The quick-response remote mode fires the shutter when you push the button on the remote. The delayed remote mode gives you two seconds to hide the remote behind your back before firing the shutter. Now point the remote at the infrared sensor on the front of the camera and push the button. If the camera fires, then everything is working.
You might also try wiping both the infrared sensor on the camera and the emitter on the remote with a soft clean cloth.
Jan 03, 2011 | Nikon ML-L3 Remote Control
Is this flash to use on a nikon D70 camera. It works on a F70 but on a d70 its not functioning
The Achiever Flash 630AF is for Film Cameras and will not work properly on the Digital D70 camera.
Nov 29, 2010 | Achiever 630AF for Nikon TTL Flash
Nikon D70 On/Off switch will not turn the camera off.
Hi, The problem with your camera is the power switch under the top cover needs to be repaired Or replaced by a camera repair tec, I have repaired this problem many times, Not a quick fix.
Feb 25, 2009 | Nikon D70 Body Only Digital Camera
The higher the ISO setting the more grain in the photo. Have you somehow set the ISO to say, 1600? Select ISO setting this way: Are you shooting in low-light situations (typically indoor)? Try shooting bright scenes and Auto mode, or manually set ISO to 100 or 200 and see if noise persists.
Apr 02, 2007 | Nikon D70s Digital Camera
Nikon D70s Digital Camera Logo
129 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
