Light blinks 6-1 code soft lockout how to fix it
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
It might be better to know the brand and model number of the set and what it is doing or not doing.
Posted on Dec 10, 2012
How do i reset the lockout
Push and hold the button for 60 seconds. It is in customer lockout because it was pressed more then 3 times.
Apr 25, 2014 | Honeywell R7184A1026 Electric Oil Primary...
Richmond powervent model 6G40PV-40F Lockout 4-2 blink. What's wrong. What do I replace to fix?
1) Rheem-Richmond does not post service manuals:
Copy following link to identify service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) For lockout, the air intake might be clogged or combustion parts dirty, causing overheating which will break TRD glass vial. Gas control may need to be replaced. Reset gas control by rotating knob to lowest temp for at least 6 seconds.
3) Call Rheem or local service tech.
Mar 10, 2013 | Water Heaters
Heil gas furnace soft lockout how to fix it
bad pressure switch, or control board
Dec 13, 2011 | Heating & Cooling
The red light and the tv screen flash simultaneously
How To Disable The NES Lockout Chip/How To Fix The NES Blinking Red Light Problem youtube.
Oct 15, 2011 | Nintendo NES Console
Turned my furnace off while going away on vacation. When I came back, the furnace would not turn back on. Lockout light is blinking.
with some thermostats you must cycle the power after a lockout relay energizes, so turn the stat off and back on and then check operations to see what caused it to lockout, often the lockouts are on low and hi pressure safeties, so you may have a refrigerant charge problem
Jul 12, 2011 | Heating & Cooling
What does it mean when my goodman furnace is flashing a red light and will not work.
It is in Lockout mode. Something has happened to make it go into lockout.
It could be an easy fix. Look of cobwebs in the tubing between the proving switch and the draft inducer motor. Look for air restrictions in the chimney flue. Rusty burners (if applicable). Tripped rollout switches. Some times there could be up to 2 roll out switches on the burner and another in the flue and 2 others in between stuff. . Most times it is a dirty flame sensor. Over the summer the flame sensor gets dusty and the sensitivity gets off. The control fails to FEEL the probe and locks out the gas valve. Most times the failure will be defines by the amount of blinks the red light emits. The sub panel has a guide on it that tells what the blinks mean.
Oct 19, 2010 | Goodman Heating & Cooling
The power button and the screen flashes when i try to turn my nes on. Why, and how do i fix this?
Well there is a segment I see on youtube that has NES lockout chip removal
the red blinking light of death means the lockout chip is malfuncting and needs to be disabled.
Jun 12, 2010 | Nintendo NES Console
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
My nintendo keeps reseting its self wat do i do to fix
How To Disable The NES Lockout Chip/How To Fix The NES Blinking Red Light Problem. Youtube.com might be the last solution to the problem then the red flashing light of death.
Oct 11, 2009 | Nintendo NES Console
Car almost didnt start then s light blinked the
The 'S' light is also your diagnostic indicator....so, the answer lies in the 'sequence' which the S light blinks.
Codes:
Long blinks: 1st digit
short blinks: 2nd digit
e.g.1 - if there are 6 short blinks (followed by long pause) then repeats 6 blinks again, the code = 6.
e.g.2 - if there is 1 long blink, then 4 short blinks (followed by long pause) then repeats again, the code = 14.
The ECU may show more more than one code.
Once you determine the correct code/s, post them here so someone can assist you further.
Cheers,
Aug 12, 2009 | 1991 Honda Accord
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
