Question about RCA F27665 27" TV
Strange audio problems
My tv has been functioning fine up until a couple of days ago. While watching it, the sound immediately went to static, only every channel went "staticy", except for channels 4 and 25. I have cable, so all the other 63 channels have a fuzzy sound. I went to the other 2 televisions I have in the other rooms, and they were fine. So I took one of them in the livingroom (where my "problem" tv was), and disconnected the cable/antannae, hooked it up to the other television, it worked fine. So I returned the connection back to the "problem" tv, and turned on my DVD player, and pressed play. The audio came out just fine. So what could possibly be the problem? I have excellent sound quality on channels 4, 25 and when I have my DVD, VCR or Sony Playstation hooked up. But not on any of my television stations, and it all happened suddenly without ever touching anything, and just all of the sudden. Please help me!!!
  • 1 more comment
  • Anonymous Nov 09, 2008
    The sound just all of the sudden goes off, what can be done about it?
    Sound just stoped, what could it be?
  • DENISE KING Mar 31, 2013
    EXCELENT!!! THANKS FOR THE ADVICE, IT WORKED 1st TRY!!
Called a tve repair man tha is a buddy of minr hr had me unplug the tv to reset the ic ship and it worked !!! thanx and good luck
Posted on Sep 05, 2007
    EXCELENT INFO.!! THANKS SOOOOOOOOOOOOOO MUCH!!!!!!!!!!!
I also did what sharkie suggested... It worked .. thank you and your buddy
Posted on Oct 29, 2008
    I HAVE A RCA F27665 TV THAT WAS WORKED FINE AND ALL THE SUDDEN THERE WAS PICTURE BUT ONLY STATIC
I did what sharkie suggested and it worked! Thanks
Posted on Oct 01, 2007
  • 934 Answers
AmySue, That unit is a ctc203 chassis with an LA7612N for an audio IC for an amp. That and possibly a couple caps need to be tested/replaced to get your TV back up and running without the static sound in the audio. It's a simple repair for a shop and not too expensive. I would suggest taking the unit into the shop yourself to save a few bucks. And if you're not sure where to begin your research for a reputable shop might I suggest NESDA at: http://www.nesda.com/locator/state_search.php which should help with finding a good tech in your area... Good Luck Bill
Posted on Jun 12, 2007
Main or power board TV failure?
Sounds like a mainboard/Digital board. Might be the panel too. Vizio makes substandard TVs and they tend to fail very easily. As much as I like to see devices repaired, this one may not be worth your hassle. Power problems caused by lightening can be the most damaging. You may even need both power and digital boards to repair it. I would buy boards from someone who will take them back in case the panel failed too.
Jul 11, 2018 | Vizio Televison & Video
No sound in television
Go to your menu.
go to sound or audio. look for any audio output options and disable them.
Does your audio go out while you watch antenna tv or when you watch a dvd/game?
Aug 06, 2008 | Televison & Video
My Volume and Channel button won't work and so I have bout 2 remotes, neither of them have worked, one is the RCR311BR remote which has been noted to work for this tv. What else can I do
I have a 2000 model RCA P52923 and I had the same problem occur a couple of days ago. The sound hasn't worked for a couple of years, but the TV is connected to an RCA surround sound to resolve that issue. Most recently, while watching TV, it began to start scanning channels by itself. I shut it off and unplugged it for a couple of days, but each time that I turn it on, it begins to immediately start scanning each channel. Neither the remote, nor the channel buttons on the set are able to stop the scanning, and neither of them will perform any functions, including turning the set on and off.
Any advice would be greatly appreciated.
Mar 11, 2011 | RCA P52926 52" Rear Projection Television
My tv has picture, but no sound (lots of hash sound)
should replace capacitor ( c 1010 marked on board if it is a M134C chasie also (c 1013) both capastors are 10 mfd at 16 volts. Also check (Q603) rca part number 266897 could be bad.
Jan 27, 2009 | RCA 32V420T 32" TV
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Panasonic TH-42px75u Audio went out
re program remote codes 018,016,007,049,067,074,076.
you have to take your remote settings to default
Sep 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Sansui tv
sounds like the tv is on the wrong sorce
Apr 12, 2008 | Televison & Video
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
Speakers have died?
Probaby the stereo decoder IC went bad or a supply voltage to it is too low or noisy. If it has audio output jacks on the back of the TV, connect it to an external amplifier and see what that sounds like. If it is ok in stereo or mono mode then the amplifier in the TV is bad. This will prove that the stereo decoder is ok.
Feb 01, 2007 | Zenith C27A24T 27" TV
RCA F27665 27" TV Logo
148 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
