Question about Exercise & Fitness
Tread mill turns on, belts barely moves the shuts off
Shuts off quickly
    Top Expert:
  • 12,223 Answers
See the video and proceed according. God bless you
LUBE the rollers bearings too.
3) Test the drive motor, if there are voltage the motor need repair, see my personal TIPS for motor help
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the b.diagram attached
God bless you
Tread mill turns on, belts barely moves the shuts  - 12_11_2012_2_53_35_pm.gif
Posted on Dec 11, 2012
  • 6 Answers
SOURCE: Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Posted on Mar 17, 2009
  • 33 Answers
SOURCE: the belt on the tread mill slips while operating
hai ,check the walking belt and motor belt tension
Posted on Oct 01, 2009
SOURCE: walking belt on image 10.0 tread mill slips,
There are adjustment screws on the very back of the deck… one on each side.
1. You will need a hex wrench that came with your unit (look on the side of the deck) sometimes it is attached to a bracket or look in your plastic bag with your instruction manual. If you cannot find it, do not worry, it is a common “hex” size. Purchase a "multi size” hex wrench at the hardware store"
2. Locate the screws on the back of the treadmill on the deck "where you walk" You will see one on each side.
3. With your wrench in hand, start your treadmill on a low speed and take note of which side the belt is "creeping" to the left or right.
4. If the belt is not centered and over to the left side take your tool and adjust the screw on the left side slowly a few turns until you notice the belt creeping back to the center....usually it does not take much adjustment.
5. Once you start getting the hang of what adjusting each particular screw does to the belt....You will be a pro in no time.
6. Once the belt centered, turn off the treadmill and unplug it. Take your hand and slide it under the belt about midway. The belt should feel "snug" against the deck. If it feels too loose...use your new found adjusting skills to tighten the belt adjusting each side a few turns…unplug…checking for tightness until you feel good about it.
7. Last suggestion: Some treadmills decks need lube to help it run smooth. Without it your deck will get worn and the belt will "stick" to the deck....not good. Buy the lube a sporting goods store or at a place that sells treadmills. If you cannot find any buy some spray on graphite.
Posted on Feb 27, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tread mill looses speed during my workout. the
If you haven't adjusted the belt refer to your owners manual for the proper procedure if you still have the same results then it could be caused by a lack of lubrication under belt or a worn belt.
Posted on Apr 11, 2010
SOURCE: looking for instructions to remove belt from J8 pro-form treadmil
I have a proform j8li treadmill. What size allen wrench to I need to adjust the belts?
Danielg@jcnj.org
Thanks
Posted on Apr 28, 2011
How do I tighten a slipping belt
My tread mill has a bolt on each side at the rear end that I put a hex key in and turn to tighten. Do both sides the same to keep the tread even on the track. Don't over tighten. I have a different make but most operate the same.
Oct 14, 2014 | Sportcraft Tx 4.9 Model 4041 B Walking...
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
STAR TRAC 3500 SERIES ERROR EL4
1) Run the software calibration for easy diagnose and troubleshooting and fix. it
2) tight very well all connectors, and clean
3) Adjust the REED switch, see the diagram , clean and tight the connector very well.
God bless you
Jun 19, 2012 | Startrac Fitness Products StarTrac 3500...
The tread belt moved to one side how do I fix ir
HI,
Check the following video to know how to align the treadmill belt which is going to one side. All trad mills have the same procedure to align the belt.
Ajin
Jan 18, 2012 | Epic View 550 Treadmill
Treadmill only hums when turned on, tread does not work
Hello, it seem there could be something jamming the tread mill belt or the transmission gears coult be broken. There is a very good possiblity that the electric motor has goine south, it doesn't work, or seeze up might have to be replaced.
GB...stewbison
Oct 19, 2011 | Cars & Trucks
My tread mill looses speed during my workout. the
Apr 10, 2010 | Proform Exercise & Fitness
Title: Treadmill Belt Problem
determine which side is off centered
If the tread is migrating from the left you need to adjust the tension adjustment on the right and side of the roller and make it tighter
Most adjustments are made by turning a set screw that moves the idler roller ( the roller that is at the end of the tread mill which is where you first get on)
TO ADJUST:
1 TURN THE POWER OFF AND UNPLUG AT WALL OUTLET
2 Locate the adjustment screw( remember you will adjust the side opposite the migration to tighten the roller)
3 manually force the treadmill belt over toward the proper path( I do this by taking my hand and sliding my fingers under the belt and lift the belt as I hand roll it
4 Turn the adjustment screw counter clockwise one revolution
5 plug in then turn on and see if it stays in place
6 Keep repeating the process ( steps 1,2,3,and 4 )
Jan 06, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
56 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
