Question about Horizon T91 Treadmill
Turn on, belt moves and turns right off quickly
I oiled it, but once I turn it on the belts barely moves then shuts off.
    Top Expert:
  • Horizon Master
  • 12,223 Answers
See the video and do the same with the rollers bearings.
test the drive motor , if there are voltage the motor need repair, see my personal TIPS for motor help
test the output voltage board , for input voltage motor, if there are NOT the board is faulty. God bless you
Posted on Dec 11, 2012
The traction belt came off while I was mowing.
6 hours and it is probably still in warranty. Consider taking it back.
May 04, 2015 | Toro TimeCutter MX5060 50" 23HP Kawasaki...
Tread mill turns on, belts barely moves the shuts off
see the video and proceed according. God bless you
LUBE the rollers bearings too.
3) Test the drive motor, if there are voltage the motor need repair, see my personal TIPS for motor help
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the b.diagram attached
God bless you
Dec 10, 2012 | Exercise & Fitness
Driving to work this morning, all the sudden my wheel tightened up (barely moves), and right before I got to my destination there was a bad knocking sound under the hood (front right-ish). When I went...
sounds like something lock up take belt off and you should be able to turn all pulleys by hand except bottom crank pulley the one that does not turn is your problem
Feb 18, 2010 | 1997 Ford Explorer AWD
Had no oil in engine yestarday, put a qt. in it
maybe she just need oil in her? dip her stick again and find out! ooow!
ok then??? why should the cam belt have any thing to do with low oil???? and right now what makes you think its broken?
ok then! if the cam sharft seized up then it could brake the timeing belt,
oh!!! back to that lack of oil in it then?
Oct 23, 2009 | 2000 Kia Sportage
The drum has stopped turning in the dryer. How
well with no other information i would have to say its A belt
a very easy reapir
Oct 08, 2009 | Dryers
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
John Deere F620 zero turn mower
you probably have the belt on wrong, check your manual to see if you have it on right.
Jun 20, 2009 | Garden
I bought a 99 zx2 with broken timing belt replaced it with new belt tensioners etc.But can not get timing to line up properly.I KNOW TIMING THE CAMS WITH A FLAT BAR AT THE BACK BUT CAN NOT GET IN TIME WITH...
take no 1 spark out and using a long thin screwdriver bring piston up to top then you have tdc,you will have to move cams to get it to come up but iam sure you will have the valves bent from when the belt broke ,remember to turn it over with a ratchet before you use the starter motor ,once timed up the belts hold the cams in place
May 17, 2009 | 1999 Ford Escort
R200 jammed carriage Grinding belt
Hi-
Normally it will not allow you to move carriage manually. Belt is broke. have it service or purchased a new one.
Hope this helps
Nov 08, 2008 | Epson Stylus Photo R200 InkJet Printer
1968 kenmore sewing machine
belts and oil it in any point that has metal to metal
Oct 02, 2017 | Sewing Machines
Horizon T91 Treadmill Logo
111 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
