Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525 I bought a replacement capacitor kit. Is there an easy way to get to the capacitor boards? Do I have to dis connect all the wires? I have the chassis out but not sure how to get to the boards. Any help would be greatly appreciated.
  • 7 more comments
  • rlt2025 Jan 13, 2009
    These are v26power pwb and v26 FMT pwb with upgraded capacitors.
    Thanks Daniel I'll start having fun.
    Yes on the service manual.
    electech1 I have that part removed but do I have to take everything apart to get to the boards? I want to change the capacitors.
    Thanks.
    Thanks electech1. I just wanted to make sure before I took everything apart.
  • rlt2025 Jan 14, 2009
    I replaced 2-3300uf 10v with 2 3300uf 16v these were both leaking. There 2- 1000uf 16v that are bulge a little, shoulld I replace with same or are they ok? These look like the only problem capacitor.
  • rlt2025 Jan 16, 2009
    electech1,
    I put everything back together and turn on the TV and I get no picture or sound. The green timer light is on and stays on. Any suggestions? Anyone?
  • rlt2025 Jan 22, 2009
    Electech 1,
    Ok i changed all the capacitors i was suppose to. The TV has a picture but it is not coming in clear. I tried changing the color, sharpness no help. Any suggestion? Please.
    Thank you
  • rlt2025 Jan 26, 2009
    I have the powerboard, dm and fmt working but the picture is shadowy kind of like a negative. Is this the signal board? Is there anything I can try. Help please.
    Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, it would be to your advantage to reference the service manual or at the very least a schematic diagram. To correctly diagnose your current problem, voltage checks at key testpoints must be performed.
Alternately, you can re-check the repair factoring the following:
  • capacitors have polarities. A reversal would cause them to fail as well as spillover the fault to other components;
  • plug-in boards can and may no seat correctly;
  • in most instances, diagnosis/voltage checks should start from the power supply's different output voltages;
  • in most Mitsubishi units, in their power supply section, there are fuses on the various secondary output before the diode.
Pls post back the chassis number as well as a detailed description of the current fault.
Good luck and thank you for using FixYa.
Posted on Jan 26, 2009
  • 10,594 Answers
I would recommend to have service manual of WD-62525 from Manual Zone. Service manual has all schematics and technical info about this TV and helpful info about repair.
    Brigadier General:
  • 8,619 Answers
Hi!
I think its a convergence circuit problem and you need to replace 2 STK ICs in order to get your TV picture clear and sharp.
  • Rylee Smith
    Rylee Smith Jan 26, 2009
    The convergence ICs are mounted on 2 x large aluminium heat sinks with fins on, The ICs will have STK 392 **** stamped on them.
    Thanks
    Rylee
    Genius:
  • 1,550 Answers
What is your problem now ?
What do you require ?
REpost your problem
  • SAM ANDERSON Jan 27, 2009
    You need to pull cover back off the Power Board and check the voltages at
    the test points. Meter must be referenced to chasis ground. You need to find
    voltages atTP12V, TP5V, and TP3.3V. I Assume that those should be 0v unless the TV is trying to turn on.
    Also you need to check connections are proper inside . You need to check the continuity of circuit .
    A service manual will be helpful . You can get one from the link below
    Click this link to get service manual
    If you still have problem you need to call technican to check the tv . And it sounds like you need to replace the DM board in tv . It is bit expense to do it .
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking timer light on my WD 62525 tv
That symptom is almost always caused by bad capacitors that are known to fail through ou the five circuits boards within the chassis. Usually the DM board and The Power Board caps fail which can cause the non stop blinking timer led. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps with repair instructions that will often repair that issue.
Oct 04, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My mitsubishi wd-62528 has a constant rapid green blinking light on timer and wont go out. had lamp replaced and reset but wont even come on.
Thats a common problem most likley caused by failed capacitors on the DM and the power board. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which contains the capacitors and the CD with instructions for the repair.
Jul 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My mitsubishi tv won't turn on
Bad capacitors that chassis is famous for numerous capacitors failing without notice.Every circuit board within the entire chasis will have numerous capacitors that will be swelled up and leaking which will require that they be replaced. You can get the repair kits for the V26 Chasis at www.tvrepairworld.com which contain instructions on the CDs along with the replacement parts.
Dec 04, 2009 | Mitsubishi WD-62525 62" Rear Projection...
5 year old mitsubishi wd-62525 with blinking timer light. This site says there aren't replacement boards available for it any more. Also to send it to a technician for repair. One suggestion was that it...
The WS62525 doesnt have an inverter board. The blinking led is usually caused by failed capacitors on the DM board. You can get the V26 Chassis dlp DM repair kit at the following link which contains the capacitors and the CD with detailed instructions. www.tvrepairworld.com
Aug 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
Aug 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv totally black, with the red light of lamp on.
sounds like the 34 error which is caused by the power board capacitors. you can get the repair kit that should repair that issue. The kit contains the replacement capacitors and step by step instructions. Heres a link to the repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jul 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Changed lamp where is reset button to get rid of red light?
if the lamp led is still red after replacing the lamp. The problem is the Capacitors on the power board have failed. You can get the V26 Power board repair kit which contains the replacement capacitors and has a cd with step by step instructions on how to do the repair. Heres a link to the correct kit for your model.
Jun 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
411 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
