Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Apple tv has no sound on my toshiba 46h83 tv - Toshiba 46H83 46" Rear Projection HDTV-Ready Television
  • dave rempe Dec 10, 2012
    what do you mean component? I have picture just no sound. .tried to put it thru cable box .no go
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
How are you connected and in what way? You should be able to rule the set in or out:
First: does the set have sound with only a DVD player connected to a rear input?
Second: are the speakers turned to OFF in the main menu?
give as much information as you can so I may be able to help.
Posted on Dec 10, 2012
  • 4 more comments
    I am connected with hdmi cable .yes it has sound with dvd player. speaker are not turned off. the apple tv is the new version
  • SD Tech
    SD Tech Dec 10, 2012
    HDMI is prone to sound issues--since DVD works it is not going to be the set. HDMI for starters does not like connections being made with units powered up or on----I would remove power from set and a box if being used, wait several minutes then make the HDMI connection and then power all back up--may or may not help but worth a try. If you fail is it possible for you to hookup with component?
    what do you mean component? have picture just no sound. tried to run it thru cable box
    but no go
    hdmi has adapter
  • Christine Witt
    Christine Witt Sep 20, 2014
    Hi! Did you ever resolved this issue? I just got an Apple TV and have a Toshiba 46H83. No sound can be heard.
SOURCE: toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Posted on Jul 30, 2007
  • 7 Answers
SOURCE: Toshiba 46H83 won't turn on...replace bulb???
this sounds like a power supply, or a fault convergence board.
did you notice any problems before it stopped working?
Posted on Nov 14, 2008
  • 10 Answers
SOURCE: Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Posted on Apr 19, 2009
  • 151 Answers
Anthing could have happened from a blown fuse to a transformer. Dont tinker with it from the the outside get a repairman out there asap.
Posted on May 13, 2009
tlm931
  • 273 Answers
SOURCE: the toshiba 46h83 46in rear projection tv comes
the red flash you are talking about im assuming is the screen going red
that usualy means a red picture tube they break down
one way to tell turn the red screen control counter clockwise and see if you can control the tube gain
and then you can lightly tap on crt neck and i do mean carfuly and see if it flashes it most likely will and you would need to change the crt and reset it up
Posted on Nov 02, 2009
Have vertical lines across the tv. Started as something that happened right when I turned the tv on (for 5 mins or so). Now it's all the time. Toshiba 46H83
you more than likely have a bad panel inside of your tv. you can have someone repair it but it's not recommended as it's pretty expensive. You should just invest in a new tv.
Jul 23, 2010 | Toshiba 46H83 46" Rear Projection...
TOSHIBA TV NO PICTURE
Sounds like blown invertor board that powers the backlights (if it is LCD or PLASMA). If your lucky and its just the invertor board blown it could cost anywhere between £50-£150 for new board (without labour).. if you are UN-Lucky, then the backlights themselfs may have blown which is *usually* an un-economic repair.
Apr 05, 2010 | Toshiba 46H83 46" Rear Projection...
The toshiba 46h83 46in rear projection tv comes
Nov 02, 2009 | Toshiba 46H83 46" Rear Projection...
Turned on tv have sound but no picture. toshiba 46h83
Most likely your convergence IC's are bad along with the two 5 amp pico fuses on the board to the left up front.
Oct 03, 2009 | Toshiba 46H83 46" Rear Projection...
Can you connect macbook to Toshiba 46H83 projection TV
"This TV is not intended for connection to and should not be used with a PC (personal computer)". This statement should say it all.
Dec 19, 2017 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83
May 13, 2009 | Toshiba 46H83 46" Rear Projection...
Apr 19, 2009 | Toshiba 46H83 46" Rear Projection...
Nov 14, 2008 | Toshiba 46H83 46" Rear Projection...
Picture is Dark on all stations
It sounds like a bulb. I would call toshiba and ask them what the replacement part is for that. I briefly googled for it but couldn't find the matching bulb for the 46H83
Dec 12, 2007 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
