Question about Woods Hardware & Accessories
Woods 50007 Indoor Digital Lamp Timer - Woods Hardware & Accessories
SOURCE: Woods Digital Timer TD 2200
See this website for links to instruction sheets in PDF format for Woods US timers:
http://www.woods.com/us-timer-instructions.asp
Posted on Nov 30, 2008
fgainer
  • 54 Answers
SOURCE: setting woods 1600 timer
you can get your instructions here and print them off.
http://www.woods.com/canada-timer-instructions.asp
There is a complete list just choose the one that you have. Please don't forget to rate me on this.
Thank you
Posted on Feb 02, 2009
SOURCE: how to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Posted on Oct 05, 2010
SOURCE: I need the instruction sheet
Here is the manual for Woods TD2200
http://waterheatertimer.org/pdf/Woods-49377-TD2200.pdf
Plug in timer.
Let rechargeable battery charge.
Once battery is charged, you can remove timer from plug so programming is easy.
If battery will not charge, then timer is no good.
Posted on Oct 24, 2010
SOURCE: Instructions to set Woods indoor timer 59377
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To set current time, press and hold clock button while pushing hour and minute buttons.
Then release clock button
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 12, 2011
What is the difference between Woods timers 50007 and 50027? Are they both polarized plug compatable?
Same timer.... choose 1-pack or 2-pack
http://waterheatertimer.org/Woods-timers-and-manuals.html#bar
The 2-pack means you get two timers.
Both these timers can fit on one duplex outlet... so you can control two different lights from same outlet,,, and each light can have different schedule
These are lightweight lamp timers.... choose Woods 50009 for heavy duty
They also make tabletop timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#tabletop
They make countdown timers that automatically go off later
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Gene
Water Heater Timers Save Money
Feb 10, 2015 | Woods Hardware & Accessories
I need instructions sheet for woods 5007? please help!!
Do you mean the Woods 50007 Indoor Digital Timer? If so you can find the online manual here: http://waterheatertimer.org/pdf/Woods-50007_Instruction-manual.pdf
You can also find it on Amazon if you need to replace it: http://www.amazon.com/dp/B005WQIDHY/?tag=waterheaterti-20
Oct 11, 2013 | Hardware & Accessories
I have a woods model 50007/50027 indoor 24 hour digital timer. I can not set it to automatically go on and off... it either says... auto on or auto off and does not indicate auto by itself. the timer...
Click to Auto Off. The system defaults to Auto Off when you complete the programming. The instructions do not cover the two 'auto' settings and it is confusing if you hit the power setting without knowing.
Aug 17, 2013 | Woods Hardware & Accessories
Lost instruction for operation of woods indoor digital 24 hour timer (59203)
1) Copy following link for possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
2) Don't forget to reset timer to clear traces of prior programming.
Timer has internal rechargeable battery that eventually gives out, rendering timer useless.
Timer has 1 year limited warranty through Coleman.
3) Suggested replacement timer: Woods 59009, 59008, 59007.
Two prong and 3-prong outlets, rated for CFL LED incandescent etc
http://waterheatertimer.org/Woods-timers-and-manuals.html#50009
4) Or buy timer locally for ez return if timer does not work.
5) Jan 2013: Best brands for warranty support are probably Woods, Intermatic, GE, Tork, Sylvania, Leviton.
Promotional-grade timers from First Alert, Timex, Brinks, Stanley-Westinghouse, Utilitec etc may not have clear on-line warranty support.
Jan 07, 2013 | Woods Indoor 24 Hour Digital Timer (59203)
I need the instruction sheet for the Woods indoor timer TD2200
Plug in timer.
Oct 24, 2010 | Sylvania SA130 Digital Lamp Timer
Lost the manual for my Woods 59377 Digital 7-Day Lamp/Appliance Timer. Is there one online which i can access?
Open link to identify timer for sure.
Each timer on page has manual
Jun 08, 2010 | Woods Industries 59377 Indoor Digital...
Hardware & Accessories Logo
2,240 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
