Question about Broan-NuTone RC515 Door Chime Remote Control
Broan door chime 973SB - Broan-NuTone RC515 Door Chime Remote Control
2 Suggested Answers
SOURCE: Broan door chime does not
Loss of range between bell and presser
Posted on Sep 17, 2009
How to install
its all very simple, just plug in the receiver, and make sure the battery for the button is good.
May 20, 2010 | Broan-NuTone RC515 Door Chime Remote...
I removed my nutone door chime transformer a while ago to work on an electrical problem. Now i want to reinstall it but don't have the instructions. The transformer reads nutone class 2 LR2982 10va 16v
I couldn't find a manual for the LR2982, so I'll give a general description of how to wire a door chime. Most chimes have 3 contacts. F (Front), R (Rear) and C (Common). Some have just two contacts. If your chime has more than 3 contacts do _not_ follow these instructions.
Inside the junction box on the wall where the chime will be mounted, you should have at least 2 cables (usually brown) each, with at least two wires (usually red and white) each. One of those cables goes to the transformer and the other cable goes to the door button.
The beauty of it is that since it's only 24 volts or less and _polarity_ doesn't matter, you don't need to know which cable goes where for a _single_ door button scenario.
For _single_ door button wiring, pick a wire (say the red) from one cable (doesn't matter which cable) and connect it to the "C" contact on the chime. Pick a wire (say the red) from the _other_ cable and connect it to the "F" contact on the chime (if the chime has 3 contacts). If the chime only has 2 contacts connect it to the only contact that is left.
Then all one needs to do is twist the 2 remaining wires together (both white) and cap them off with a wire nut.
If your junction box for the chime has 3 cables in it, the extra cable goes to a rear door button. In that case you _do_ need to know which cable goes to the _transformer_. You can pick up a cheapo voltmeter for about $10 just about anywhere. The cable that reads anywhere from 16 to 24 volts AC between the red and the white wires is the cable that goes to the transformer.
Make sure one of those wires from the transformer goes to the "C" contact (pick one, say the red). Now you know the 2 remaining cables go to the front and rear door buttons. For now, just connect a red from one of the remaining cables to the "F" and one red from the other remaining cable to the "R". Then just twist the 3 remaining white wires (including the white wire from the transformer) together and cap them with a wire nut.
If the rear chime sounds when the front door button is pushed, just swap the wires on "F" with the "R"contacts..
May 13, 2010 | Broan-NuTone Door Chime Kit by NuTone
We had a power surge a few months ago and every since the front and back door doorbell doesn't work. Model # CBP972 - 16 VAC. Can you assist me in getting it to function again?
Wireless units usually arent the problem, it is probaly you main unit that had blown the transmit, Have you unplugged or powered down the units and restarted them
Nov 30, 2009 | Broan-NuTone RC515 Door Chime Remote...
I need instructions on how to use and program a nutone door chime. Mine is a musical style for front door. I can change the chime to many different sounds, but have no instructions on how to use or program...
The 515N number is a transformer part number, do you have a photo of the chime you have? Is it wired or wireless? Is it a newer chime or and older model? Check Nutone's website to see what model you have, then search their site for the model you have. The model page will have an instruction sheet PDF file download of the instructions.
Oct 11, 2017 | Broan-NuTone Door Chime Kit by NuTone
I cant fix my door chime bell
If you cant fix it, just buy a new one, they are cheap $15.
Basically it's a magnetic coil that moves a metal bar that strikes a bell.
They run on 24 volts AC and are powered by a transformer. All parts are available at Lowes or Home Depot or even your local hardware store.
Sep 29, 2009 | Broan-NuTone Door Chime Kit by NuTone
Static through door bell can't turn off
Check all the ground wires to make sure they have a good ground
Aug 07, 2009 | Broan-NuTone RC515 Door Chime Remote...
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
Broan-NuTone RC515 Door Chime Remote Control Logo
128 people viewed this question
Top Broan-NuTone Televison & Video Experts
Are you a Broan-NuTone Televison and Video Expert? Answer questions, earn points and help others
