Question about Electrolux Centralux Vacuum
A Phllips Norelco Shaver FOR SIDEBURNS and nozes and beards
Well the small beard trimmer bit ACCIDENTALLY got sucked up into the hoze and now we can;t get it out
SOURCE: HELP!!!
You can put the hose over the exhaust of the central vacuum canister to try and blow it out, or you will need to use a long plumbers snake.
Bob
http://evacuumstore.com/
Posted on Mar 27, 2010
Got a small rubber squeezable ball stuck about 2-3 inches from opening Miele silver moon
Take a 3 inch drywall screw or deck screw and screw it into the ball. Make sure that you thread into the ball about at least a half inch. Slowly work Out the ball backwads
Dec 04, 2016 | Vacuums
My vacuum cleaner is dumping what it sucks up mostly on to the filter, I expected to find a blockage but not so far ? Can you advise ?.
Hi there, it's Jack at Dyson.
I'm confident I can resolve this issue - it sounds as if your machine may be missing the bin inner. The bin inner is the lower yellow section shown attached to the base of the clear bin in the image below:
It's possible you may have accidentally thrown this away when emptying the machine recently. To resolve the issue, you would just need to retrieve and refit the bin inner.
If you're unable to locate it, you can order a replacement by calling our freephone UK Helpline on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Dec 04, 2014 | Dyson DC05 Bagless Canister Cyclonic...
Vacuum brushes are turning but not picking up dirt and is blowing a lot of air out of the top air filter thing
Did you check carefully for splits? After sucking something up that big, you may have split something, like in a fold of the hose. When it is in a position where the split is somewhat sealed, it works. Move it just a bit and the split separates and it won't work.
Mar 29, 2014 | Vacuums
I think that I accidentally sucked up a child's
if you have a shop vac you can try blowing it out. for some reason this works better. You also might try a coat hanger with a U bend at the end.
Aug 09, 2011 | Electrolux EL6988E Bagged Canister Vacuum
O.k. this is the 3rd time I'm writing this...not even sure how many times I'm being charged.... Already aggravated and exhausted so Please, Please help me. I bought 2 Westek 1 outlet timers for...
There is no money indication on this one. I'm speaking for free, so I hope you're asking for free.
Oh yea, I already answered this question. You bought two bad timers!
Sorry.
Jun 04, 2011 | Vacuums
How do I register my new Philips shaver and get extra 1 year guarentee
I found a number for norelco phillips I am sure they can help you 1-800-243-3050
Mar 16, 2011 | Philips Vacuums
I sucked up a dusing cloth with my ducted vacuum cleaner and now it does not **** at all. Help can not afford a three hundred dollar bill. blocked
Turn off the power on the main vacuum unit. Then thread a plumber's snake or stiff small gauge wire from the outlet you were plugged into when the dust cloth got sucked up. With any luck, you'll be able to push it through a bit or with a small bend at the tip of the wire, you might catch hold of the rag and pull it out. You could also try sucking out the line with a shop vac by fitting it tightly into the outlet and turning on the vacuum.
hope it helps.
please rate this solution.
Thanks for using FixYa.
Feb 13, 2009 | Emerson Vacuums
HELP!!!
There is no secret to getting items out that are stuck in central vacuum hoses. If you can get something long like a garden hose to insert into the central vacuum hose and push it out or put something heavy down the hose like a screw driver and shake the hose to see if you can knock it loose.
Good luck! and for all of your central vacuum needs visit:
www.mountaincentralvac.com
Jan 13, 2009 | Electrolux Centralux Vacuum
Please elaborate on the problem in detail.. Your vacuum sucked up a 'dusting cloth" ? Your description of a 'ducted vacuum' implies it is a central vac system ...is that true? If not please explain what you are using? The more details the more likely I can help...
Sep 14, 2008 | Samsung Quiet Jet 9068 Bagged Canister...
Electrolux Centralux Vacuum Logo
Top Electrolux Vacuums Experts
Roger Potts
Mike Cairns
Mike Cairns
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
