D link router no power
My router will not come on. there is no power.
  • 32,281 Answers
Check power adapter's DC plug that connects into the router power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Posted on Dec 10, 2012
Tp-link system light off
i think , you should replace your router , electricity problem
Feb 01, 2014 | TP-LINK Computers & Internet
What will happen if inserted the 110v input d-link wireless router power supply to a 220v outlet? does my router busted or just the power supply?
Most likely you have damaged not only the power supply but also the D-Link wireless router unless the power adapter is a multi-voltage power adapter. Check the label on the power adapter and if the input voltage is a fixed 110 volt power supply you are in trouble.
You can try getting a 110v power adapter and connect it into the D-Link and if it works then you are lucky.
Dec 29, 2012 | D-Link DIR-615 Wireless Router
What is the inside of a d-link power supply?
I mistakenly plugged in 9V power to my D-Link DIR615 router?
Most likely you have damaged the D-Link router.
Connect a correct power adapter to the D-Link to see if it works properly, if it doesn't work then you need to purchasr a new wireless router.
Feb 26, 2012 | D-Link DGL-4500 Wireless Router
I plug it in and there is no power the light is not on
Hi stella_bella,
I see that your D-link Router will not turn on or power up as you mentioned.
If I may ask Have you tried a different power source / Outlet?
also try ti find a different adapter with the same wattage on it and see if the Router will power ON using a different Power Adapter.
When did you notice your D-link not powering ON? was there any power surges lately, that can cause Router or Modem to get busted or damaged if ever you were either online or if the Router was turned on during the power surge.
The only thing you can basically do is try a different Power outlet or power source and a different Power Adapter of the same wattage to avoid damaging the Router more.
I hop that this helps.
Have a nice day,
mvincentc
May 08, 2011 | D-Link AirPlus DI-524 Wireless Router
D-Link DIR-615 (wireless router) no power light on ???
If the power pack is good then the router is dead and needs to be replaced. It's generally cheaper than trying to fix it.
Dec 12, 2009 | D-Link DIR-615 Wireless Router
What is the d-link part number for power adapter for D-link Di-634M router?
what is the d-link part number for power adapter for D-link Di-634M router? How can I get this?
Mar 28, 2009 | D-Link DI-634M Wireless Router (DI634M)
Has my router gone bad?
If no power lights come on... it looks bad, but try another power adapter on the router before tossing it... could be that.
Jan 09, 2009 | D-Link AirPlus DI-614+ Wireless Router
Configuring D-Link DI-524 router with airtel beetel 110bx1
Make sure you can go online directly to the airtel broadband. If internet works fine, connect the D-Link router to the Beetle. That should be going to the Internet port or WAN port of the D-link. Then your PC to port 1. Try to power cycle both devices now. Unplug the power to the router first then to the modem. Wait for 30 seconds. Power on modem first, wait for the lights to go solid, then power on the router. Check if the internet works fine hardwired. If it is, wireless should work as well. Just connect to the signal coming from the D-link.
Oct 31, 2008 | D-Link DI-524/DWL-G630 (di524dwlg630kit)...
D-link airplus Xtreme DWL-G650 - hang up
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
Apr 23, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
