Te error code wf328aaw
Thermistor sensor
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
It is part of the heater assembly that you need to replace. Here is the part to order.
Posted on Dec 10, 2012
4 Suggested Answers
  • 291 Answers
SOURCE: trouble code!!!!!!!!!!!!where and how do i get to
Simple, Unplug washer, lean it back against the wall, brace it so it won't fall while you crawl under it. The thermistor is on the bottom front of the tub, some units twist out. Some you have to unscrew one or two screws. Download this, http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf and look at page 28. The thermistor is to the right of the heating element. Make sure the connections are tight. Replace if you are still getting an error codefor a thermistor problem. Good Luck, Appliance Specialists
Posted on Jan 26, 2010
  • 4 Answers
SOURCE: te error code
btw...the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing. I removed mine after getting a "tE" error and cleaned it and replaced...no problems since!
Posted on Jun 02, 2009
SOURCE: LG WM2277HW Thermistor (tE) issue
To be more specific, unplug unit. Behind the machine are two plastic kick plates, remove to slide off the top. Once off, two top self tap metal screws and one screw behind panel wall, remove. Remove two detergent screws. Lift electrical panel and set on top of machine. Remove four top screws. Bottom drain has one screw in front, take out plastic cover and one screw in back. Take off rubber by opening door. With a screw driver, prey and lift up the brass spring ring and remove. Then the front panel should slide up and out. Be careful because electric wire is still connected, move to the side of unit. You will then be able to find the thermostat. Unplug and replace, you will need to use the same rubber bushing. Took me an hour, I’m not an appliance repair guy.
Posted on Feb 09, 2010
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Have a error,not LE, but looks like an upside down 7 with a line thru the middle, then E???
often referred to as an 'le' code. looks kinda like an upside down 'F', correct. replace motor position sensor--the hall sensor.
Mar 22, 2015 | LG Washing Machines
I'm getting error code tE on samsung silvercare WF316LAS/XAA
tE is mostly related to
temperature sensor wire and connection problem. Look for a broken or loose wire.
Dec 07, 2012 | Washing Machines
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
I get a te code all the time and a he code from time to time.
from Lg this is the meaning of the codes.
  • The heater circuit has failed if "HE" is displayed. Discontinue use and contact a service technician. The dishwasher requires servicing.
TE
  • "TE" means the thermistor has failed or the temperature of the water entering the dishwasher is over 194 degrees Fahrenheit. Turn the temperature down on the hot water heater in the home. If the error code reappears, replace the thermistor.
    By the sound of this your heating system is malfunctioning and needs service.
    If you need more on this let me know, but it is either your temperature sensor or your heating element or control board.
Oct 02, 2011 | LG 24 in. LD-12BW5 Free-standing...
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Jan 05, 2011 | LG WM2487H Front Load Washer
Code error te
According to the manual, this is a control error, more than likely a sensor such as a thermistor. Call for service.
Jul 06, 2010 | LG WM2688H Front Load Washer
Receiving a TE error code which leaves the washer unable to operate
TE is a thermister error. (temperture sensor) Located at the water heater element.
Supposedly can't be serviced by untrained individuals (thus the directions to call for service) but the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing.
thermistor is a small, round, black rubber grommet with the metal sensor pushed through the center.It easily pops back into place.
Apr 07, 2010 | LG WM-2277HW Front Load Washer
LG Tromm washer WM2688HWM tE error code. Very easy to remove and replaced the thermistor, BUT still, it's not working, tE error code still there. ????????????
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Jul 17, 2009 | LG WM2688HWM TROMM SteamWasher
Te error code
Oct 29, 2007 | LG WM2688H Front Load Washer
Open Questions:
Maytag Bravos MVWX700XL2 won't spin the clothes and is making a weird whining/whirling noise when attempting to do so. Hi, I have a Maytag Bravos MVWX700XL2. It's about five years old. For about a year now, it would occaisinally make a weird noise while washing that seemed to come from the agitator working. I know this sounds funny, but the noise sounded like a chittering squirrel. It didn't do it all of the time, just mostly when I would wash smaller loads. Today I noticed while doing the weekly laundry, that the agitator wasn't fully agitating. It was turning back and forth, but very slowly and not "mixing" the clothes like it usually does. I went though two loads like that, and on the third load, when it was time for the washer to rinse and spin, it started to make a whining/whirling noise and it would not spin out the clothes (but it did drain). The control panel is not giving an error code. I removed the wet clothes and tried to have it just rinse and spin or drain and spin empty and the strange noise continued w/o any success. I have a video of it making that noise that I can post/send if someone can tell me how. I paid over $500 for the washer, and I really don't want to have to replace it this soon, nor do I want a $300 repair bill. My husband is very handy and could fix it if we knew how to properly diagnose the problem so we get the correct part. Based on what I've read, could it be the shift actuator or a broken motor coupler?
Jul 16, 2018 | Maytag Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
