Lg wm1815cs error code le
Error code le
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
Posted on Dec 10, 2012
4 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: LG WM2277HW - ERROR CODE "LE"
Hello remrama,
Please use this link to access the service manual on your display code message ( page 18 ) elaborates on the cause of that message. You should be able to determine which of the few causes may be the culpret,... http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Hope this helps you..
Regards,
Rick
Posted on Feb 22, 2009
SOURCE: Error code LE on LG Wm1815cs
Error OE appears after about 10 minutes into a cycle. "OE" in the manual says filter clogged....we have checked & cleaned all of the lines/filter. Now we hear a light humming instead and the washer isn't doing anything...
Posted on Dec 13, 2009
aquatom
  • 108 Answers
SOURCE: LG TROMM WM1815CS GIVES AN ERROR CODE LE
Hey Amber first unplug the unit then remove the top panel by removing the two rear screws then slide the panel to the rear and remove. You should find the tech sheets inside this will show you the codes and how to find the problem let me know if you need further help.
Posted on Oct 05, 2011
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
LG Tromm wm1815cs front loader washer error message 1e. Have cleaned filters, checked hoses,and supply source, I still get message,
R u sure it is not an (LE) error code. Kinda looks like an upside down (F)? Very common on older LG washers. Indicates a hall sensor/ motor position sensor error.
Mar 22, 2015 | LG Washing Machines
My LG wm1815cs turns itself off 10-20 minutes into a load of towels. I think it may be weight related but I am not getting any error code
Certain machines have specification, which the user must follow, if you do not adhere to, the machine will not work. if load is one of them, stick to regulated weight it can handle.
Feb 22, 2015 | LG WM1815CS Front Load Washer
Oct 04, 2011 | Washing Machines
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
I have an LE code on my washer. I tried resetting machine by unplugging. I still get the code. I also tried running the machine without anything in it. It still stops and give LE code. What should I do?
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | LG WM1815CS Front Load Washer
LE - overload in motor displayed
LE is error code for hall sensor, replace sensor
Sep 07, 2010 | LG WM1815CS Front Load Washer
Lg 1815cs error code oe, will not drain, makes wierd noise during cycle
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 31, 2010 | LG WM1815CS Front Load Washer
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
