The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cook-top. Here is the part to order.
SOURCE: power failier
beleive it or not set the clock,I work at an apartment complex and the cleaner always unplugs my stoves to clean behind ,everytime I plug back in PF,Just set the clock hours and minutes,Its just telling you you lost power incase you had something cooking in the oven,you wont think that your oven is broken,and also so it doesnt start automatically by it self please rate this solution thanks
SOURCE: Code e2 f3 appears, oven goes to self clean mode,
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(*&^%
SOURCE: What does E2 - F3 - code mean on a Whirlpool Accubake Gold??
F3 - E2 Oven too hot Replace oven temperature sensor
SOURCE: stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
SOURCE: kenmore gas stove
It sounds like you have some condensation in your gas lines.
The fact that it only does this when preheating kind of reinforces that suspicion.
By the time the oven has reached temperature setting, the bit of moisture has been either blown or baked out of the system.
Steam clouding the window would confirm this or if don't have one, you clould put a shiny pot into the oven and check it for condensation after a few minutes while the popping is taking place.
