Question about Garden
Craftman snowblower bogging down
Older model 5 hp engine......runs great until its under a little load, then bogs down.......also will not throw snow but a couple feet
2 Suggested Answers
  • 75 Answers
SOURCE: engine runs great but as
Sounds like an engine that either isn't fully warmed up or the choke improperly set.
Posted on Jan 22, 2011
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
How do I improve the throwing ability of my MTD 5/20 2 stage snow blower? It bogs and jams with just a little snow on the 2nd stage thrower.
Do a google search for "Clarence Modification" You can buy the Rubber material yourself without buying the 'real' kit.
I have done this Mod to many machines of all makes and models. It has helped them all.
Mar 01, 2015 | Garden
Snowblower problems
Possible problems
Belt slipping ( too loose or worn out )
Snow too wet and plugs up.
Motor not powerful enough could be running too slow
Could be the gas screw on the carb set too rich and floods or too lean.
Could be trying to blow too much snow at a time.
Depending on the machines age could be just wore out
In saying this I don't know what type or age of your machine
Feb 22, 2014 | Garden
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
Snow blower losing power
Start with fuel. Unhook fuel line from carb. and see if fuel runs out.
Jan 03, 2014 | Garden
Why does my snowthrower engine bog down when throwing snow
It should slow down some as it is under a load. As long as it throws the snow far enough no problem. If not the speed governor may need adjusting. Make sure you have fresh fuel.
Jan 16, 2013 | Garden
Engine runs great but as soon as I attempt to move snow it's throws a very little bit, bogs down and "pulls" the engine down to off.
Jan 22, 2011 | Garden
I have a toro snowblower with a 2 cycle engine. When it's just running under no load it seems fine(maybe a little too high of rpm). When it starts throwing snow it gradually slows down until it quits...
It sounds like it is running lean. Back out your carbuerator adjustment screws a quarter turn counterclockwise. These settings should be 1 and a quarter on low speed (closest to engine block) and 1 and a half on high speed (farthest from engine block). These are starting points the adjustment may vary a little eigther way. Never adjust for max rpms that is too lean and will cause engine failure. Hope this helps ya.
Dec 22, 2010 | Toro Garden
My toro 1128 OE snow blower wont throw snow the auger turns but the thrower doesnt rotate. Does anybody have any suggestions
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Dec 26, 2009 | Toro Lawn Mower With Toro Power Tools
Snowblower seems weak for a 5HP
it will run at the speed you set at it may bog down a little when you hit the snow and the belt problem on the side there is a cover take it off there is an ajustment try to tighten the belt if that doesn't work you may have to replace it, thank you.
Sep 09, 2009 | Garden
Garden Logo
247 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
