Question about Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP)
Flame has become very yellow and lazy. I installed a new regulator, but didn't help.
At maximum heat, flame comes out of mesh enclosure around burner and starts turning red, but am not getting very much heat out of heater.
  • Brinkmann Master
  • 2,514 Answers
Try cleaning the burners sounds like they are blocked ,yellow and lazy is lack of air to burn
Posted on Dec 10, 2012
  • 4736 Answers
SOURCE: Grill is not getting to maximum heating potential.
Here's the problem and solution. The LP tank has what's called an OPD Valve. It prevents overfilling. However, if you turn the tank valve ON as you would normally do, it shoots high pressure to the grill's regulator and locks it up.
Solution: Turn the tank valve OFF. Disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Now, turn the tank valve on VERY, VERY SLOWLY (slow motion, slow), until the valve is fully open. Turn ON and light the burner farthest from the tank first and turn it to the highest setting. Repeat that procedure with the remaining burners. Have the flames returned to a normal height? If so, you solved the problem. If not, repeat the procedure again, but this time leave the hose disconnected for 10 minutes. If both attempts fail, you will need to replace the grills hose and regulator, as the regular is locked an won't release itself. You can find the hose/regulator assembly at any home improvement store or hardware store.
Just remember to always turn the tank valve on VERY, VERY, SLOWLY,
Happy Grilling!!
Posted on Mar 13, 2011
SOURCE: Low flame
Solution #1 is correct. If your regulator is / was good, then you would most likely have a leak in a line or fitting - and the regulator has properly restricted or stopped gas flow as it's designed to do for obvious safety.
However a very common leak is the main plastic tank coupling which renders the whole regulator and hose assembly useless.
Quick fix, go to Wal-Mart and buy a $20 replacement regulator which comes pre-fitted with hoses and couplings. Get the dual or single hose depending on whether you have a side-burner or not.
Voila! Your good to go a few more years.
Posted on Feb 27, 2009
  • 60 Answers
SOURCE: Flame is low with new tank. Flame is reduced when
turn tank off disconnect from gill make sure all knobs are off reconnect tank make sure fitting is all the way on tank turn tank on and try again
Posted on Aug 16, 2009
  • 94 Answers
SOURCE: flame is very low
take your burner out, an make sure theres no spider webs or nothing blocking the passage way of propane getting to the burner, check for rust, shake it, see if anything comes out, or it mite be time for new burner..
Posted on Mar 31, 2010
  • 2514 Answers
SOURCE: Low flame burning on CharmGlow 4-burner gas grill,
check burners are not bolcked check orffice is not blocked also check reg is giving right pressure
Posted on May 17, 2010
Pilot flame seems too high. How can I adjust and how tall should flame be?
The pilot flame should be a firm blue color impinging directly on the thermocouple enough to turn it red hot after a few minutes. Generally, the pilot flame need not go past the thermocouple more than a 1/4 - 3/8" and should not be a lazy yellow color. As far as adjustment to the pilot flame, it depends on the heater brand you have. Look at the gas control for a small adjustment screw near where the silver pilot tubing connects from it (it connects to the pilot assembly on the other end). Adjusting it counter-clockwise will lower the flame size, if necessary. If the pilot has a lazy yellow flame, the pilot orifice may just be dirty. With the pilot flame off, use a can of compressed air (with attached straw) to blow out any debris/dust from inside the pilot assemble where the orifice is. Good luck.
Mar 18, 2015 | Heating & Cooling
I see to have too much gas pressure after converting my Neptune dryer from natural gas to LP
you should not try to adjust the flame. LP burns more yellow that NG. The gas pressure automatically regulates the airflow based on the dynamic pressure that goes through the burner chamber. If your flame is roaring and pushing forward, everything is Okay, if it is a "Lazy" and falling flame, you have a blockage of the airflow - venting system
Mar 03, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Unit takes a long time to heat up. Lazy flame. Not much of a difference between high and low setting
iddoog - You either have a problem with the venturi valves on the burners, that need to be cleaned or you have a partially locked up gas regulator.
If it's the regulator do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY, SLOWLY (Slow Motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and turn to HIGH. Has the
flame improved? Does it look correct for the HIGHEST setting? In so, light the remaining
burners the same way. Now, do all the flame heights look correct? If so, you solved the
problem. Remember to ALWAYS Open the gas tank valve very, very slowly.
If that didn't solve the problem and you removed the burners and cleaned them and their venturi valves, you will need to replace the grill's Hose/Regulator Assembly. They cost about $30.00 & you get one at any home center or hardware store that sells grills and accessories. Take your old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know & Happy Grilling!!
Jun 22, 2011 | Fire Magic Regal II (LP) 15-S1S1P-A...
Pilot light goes out when the burners shuts off
weak pilot flame: should wrap around therocouple.
blue flame with yellow tip not yellow and lazy.
if flame good replace thermocouple
Dec 19, 2010 | The Companion Group Kozy World Portable...
Pilet light goes out after water is heated and has to be relite how to fix
try tapping the pilot assembly when you have it lit to see if the flame gets straight the flame cannot be lazy like dancing around its gotta be dirrect if it still goes out get a new thermocouple
Aug 17, 2010 | Heating & Cooling
Pilot turns on but when I switch to turn it on,
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
May 13, 2010 | Coleman 5040-751 BackHome Open Flame Patio...
The pilot light on my kozy world ventless wall heater goes out after it burns for a while. Even quicker when the blower kicks on.
Oct 26, 2009 | The Companion Group Kozy World Portable...
Yellow flame from all carryover tubes. This grill is brand new
if the unit is running on natural gas, this is not unusual. if running off propane tank something is wrong with the regulator
Jul 05, 2009 | Char-Broil CharBroil Master Flame Gas...
Orange flame color
Blue with orange tips should be fine yellow is 02 starved need to vent [good air movement]
Please rate. Thank you. jj505
Mar 27, 2009 | Whirlpool Water Heaters
Propane Reddy Heater
AIR MIXTURE ADJUSTMENT IS CRITICAL ON ALL GAS BURNING HEATERS. SOUNDS LIKE YOU HAVE INSUFFICIANT CUMBUSTION AIR WHICH WILL CAUSE A WHITE AND LAZY FLAME .... FLAME SHOULD BE BRIGHT BLUE WITH NO WHITE OR YELLOW TIPS ON THE FLAME.
Apr 06, 2007 | Reddy Heater RLP100 Portable Forced Air...
Brinkmann Charmglow Stainless Steel LP Drop-In 4-Burner Grill 810-6805-0 (LP) Logo
107 people viewed this question
Top Brinkmann Grilling Experts
paulcarew
Dan Webster
Dan Webster
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
