Question about Canon PowerShot A620 Digital Camera
Canon A620 The power on/off button is stuck in the on position and will not turn off. Any ideas??? Thanks in advance.
  • Linda Day Jun 20, 2007
    Already tried the battery thingy. Good thinking but didn't work.
    Thanks again.
Yes it's still stuck, it's a push switch and did try flexing the casing. Sent it in to Canon and they estimated $107 for repair.
Posted on Jun 27, 2007
    Genius:
  • 2,985 Answers
Remove batteries Try gently rocking it side to side back and forth. Then in the area around the switch try flexing the casing whilst rocking- It may just pop up.
Posted on Jun 11, 2007
  • john ash
    john ash Jun 20, 2007
    Is the Switch is still stuck ?
    Is this a 'Press 'switch or a 'Slide 'switch?
    Did you really try the'Press the switch whilst flexing the casing?
The viewer of my canon A620 is blank when I turn on the camera to take a picture
Press the DICP button 2 - 3 time and see the LCD turning on or not. Let me know.
Aug 07, 2012 | Canon PowerShot A620 Digital Camera
Canon a620. no image on display and pictures turn out black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 24, 2010 | Canon PowerShot A620 Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
My Canon PowerShot A620 has a black screen, any ideas on how I can fix this? I can't even take pictures, all of them come out black
My A620 JUST started doing the same exact thing last night. LCD works, lens works... but something possibly wrong w/the shutter so it won't open.. everything black.
Jan 05, 2010 | Canon PowerShot A620 Digital Camera
Power Shot A620 Canon 7.1 mega pixel 3 years
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A620 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Hello the lcd screen on the back of my canon a620 is completely black and will not show what i am taking a picture of. any suggestions?
If the camera shows the menu, it can be two faults - dead CCD or stuck shutter. You should contact local Canon service center.
Tom
Jul 28, 2009 | Canon PowerShot A620 Digital Camera
Lens Shutter Don't Close
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. The A620 is more complex, but still similar enough. As recommended in the post, try the simpler fixes first before attempting:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Dec 26, 2008 | Canon PowerShot A620 Digital Camera
Canon IP2000 printer. The power switch is flashing intermittantly green and orange and as a result it seems to be stuck as anything I do has any effect - any ideas?? Many thanks in advance for your...
this may work for you
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Nov 29, 2008 | Office Equipment & Supplies
Camera will not power up correctly
Again the same old compact camera zoom lens problems - sand in lens, stuck AF motor, chewed up plastic gears...you only have to look at them wrong and they will die... (A very cynical camera repairer that has tried to repair these damn things soo often!!) Even cameras with internal lenses like the old Nikon 950/990/4500 still have troubles with stuck motors and broken lens parts. I despair - these things are just made to last the guarantee out (if that long) and die horribly afterwards!!
Nov 08, 2007 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 Digital Camera Logo
94 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
