Question about Nordic Track NordicTrack T7 si Treadmill
Front console not working
Front panel touch screen functionality doesn't work anymore. It was working fine , the next morning I started using it and now I cant select anything on the console as the touchscreen(weight loss workout etc.) doesnt work anymore.Panel still shows reading and everything, but can't select/change anything through the console. The entire functions are inaccessible now.
  • solostream19
    solostream19 Dec 10, 2012
    contacted cust. service, they recommend replacing console for $690, I bought this item for $800.
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
Try this first: 1) Replace the batteries by new ones, clean the contacts batteries very well with c. cleaners.
2) adjust the REED swtich, test for open or faulty, clean it, and tigh the connector very well.
3) tight the ribbon cables inside, clean it, and tight very w.
4) see the diagram attached and try again.
God bless you
Posted on Dec 12, 2012
  • 218 Answers
SOURCE: i have a norditrack exp 1000x, on the lower
The overlay is bad. You will need to replace the whole console because nordic track does not sell just the overlays. you can get the console at iconservice.com or check on ebay
Posted on Aug 11, 2010
  • 4 Answers
SOURCE: The digital touch screen display is not showing
What your seeing is a common problem which I encountered on 3 separate displays. I have since diagnosed the problem and am currently life-testing a working solution. The real problem is very poor design of the negative voltage generator circuit for the display contrast. Everything else is working fine except that circuit. I have designed and installed in my treadmill a replacement circuit that is much stronger and am currently testing it. zubatcha@gmail.com for more information
Posted on Nov 01, 2010
roadtech7
  • 297 Answers
SOURCE: nordictrac 2500 problem: when dead man key is
You have it in DEMO mode, your manual will show you how to disable this feature.
Have a good new year!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Jan 02, 2011
  • 1833 Answers
SOURCE: Nordic Track C2270 Console Problems I
You can try with this solutions : first remove the console and remove the back of trademill. remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console reattach the console, now With the key off press the speed + and stop buttons at the same time and hold, place the key on and release the buttons, press the stop key once, press the speed up til it reaches 85. If it doesn't work then you have to replace your console.
Here are some web links where you can find diagram of console : http://nordictrackparts.com/diagram/7187,
http://www.searspartsdirect.com/partsdirect/part-model/nordictrack-parts/treadmill-parts/Model-NTL12952/3016/1307600.
Posted on Apr 04, 2011
SOURCE: Just purchased a new Nordic
nordic tractx7i
Posted on Dec 08, 2011
Korg Triton Studio LCD malfunction! Please need help badly! :(
Where can i purchasea lcd for my korg triton studio
May 28, 2012 | Music
My mouse broke my usb port in the front of my computer and when I removed it my computer wont recognize my mouse or keyboard anymore but it recognizes my speakers
I had to unplug everything from the motherboard and remove the usb port in the front that was causing the problem, then my operating system started again, I then had to reinsert my supplemental recovery disk and repair my system, then I had to restore to the previous day before the problem started.
May 22, 2012 | Computers & Internet
1996 Nissan Sentra won't start.
I had this same problem and for me my main fuse was blown. Try checking that
Jan 17, 2018 | 1996 Nissan Sentra
EPIC MODEL MHWZ600TW00...no display, no power up. Have tested outlet and electricity is fine. Would love to have an error code to help, however, without display I am lost.
diagnostic test -- the washer must be empty and the control must be in the OFF state before pressing the touch-pad sequence to start the test. 1) close the door 2) select any one key (except PAUSE/CANCEL) and follow the steps below, using the same key): a) press/hold 4 sec b) release for 4 sec c) press/hold 4 sec d) release for 4 sec e) press/hold 4 sec 3) upon release, all console LED lights will turn on for 5 sec 4) if there are any failure codes, they will be displayed in the Estimated Time Remaining display. NOTE: This program recalls the most recent failure code first. 1) press the same key to advance to the next failure code. (if the console doesn't change then the same failure code was stored multiple times.) 2) if there aren't any more failure codes all the lights on the console will turn on for 5 sec 3) next the washer begins the diagnostic test 4) to cancel out of service mode press PAUSE/CANCEL. this exits you out of the program. **Hope this helps; got it off the manual for service technicians.... most likely you'll get an F28 code (Serial Communication Error -- the communication between the central control unit (CCU) and the motor control unit (MCU) cannot be sent correctly). We are having this problem now and just replaced the CCU to a tune of around $300 ($120-$150 for CCU part & repairman labor cost + call/diagnostic cost)... it still is not working so I guess we'll replace the MCU next. If that doesn't work then we'll have to get a new washer that's not a frontload. What a nightmare; wished we had done research on frontloaders. Good luck!
Oct 02, 2011 | Maytag EPIC MFW9700S Front Load Washer
My gigabyte g41 combo doesn't detect front port jack . So i'm having problem in using headphones from when i bought this mother board.I tried both XP & 7 .My front port sounds only when i...
1. check if your front panel is connected to your motherboard at proper port2. check "expert mode" on your via hd audio deck, click "advanced options" and check "redirected headphone" (THIS WILL UNCHECK "INDEPENDENT HEADPHONE") and uncheck "enable front panel jack detection"
this should solve your problem.
Sep 22, 2011 | Gigabyte GA-G41M-Combo Motherboard
My Honda Accord 1995 will not start. One day the engine decided to only sluggishly turn (wouldn't crank) - then suddenly took off, turned over quickly and started straight away. I charged the...
When the alternator doesn't supply current, the battery light on the dash would light up. (assuming the battery lightbulb is working) Next would be to doubt the voltage regulator not doing a proper job, but usually its either dead or working.
Ghost consumers can be tracked when the engine is off and removing / attaching the battery lead causes quite a bit of spark. Measure the Amps with a multimeter when turned off. When it's in the 2 Amps and upwards region - remove one fuse group after the other to see where most of it goes. Then go through all the separate consumers in that group.
If it's a low current preferably below the 1 Amp - the battery might not be as healthy anymore as suspected.
Jul 01, 2011 | 1995 Honda Accord
Hitachi 55" plasma Director's Series
Replacing the front glass entails completely disassembling the entire TV. Your best bet is to look for a broken TV with a good front glass.
May 28, 2017 | Hitachi 55HDX62 55 in. Plasma HDTV
I have a dsi xl and my touch screen does not work anymore. used all day befor and started it up next day and now touching it does nothing. everything else seems to work fine.
Sounds like a hardware problem, in which case there really are no recommendable do-it-yourself solutions. Contact the store you bought the system from, if the DSi XL is still under warranty, or take it to a repair shop.
Mar 22, 2011 | Video Game Consoles & Games
Buttons on front console no longer work.
time to upgrade not even worth it or to find parts sound like bad controller old ok samsung upconverting one 89 bucks circuit city k betifull picture thx nick
Feb 08, 2008 | Memorex MVD2027 DVD Player
Nordic Track NordicTrack T7 si Treadmill Logo
224 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
