Question about Acer Aspire 7520-5185 Laptop
Where can I get an acer aspire 7520-5773 recovery disk
SOURCE: acer aspire 4315 recovery cd file...
all you need to do is go to Acer Empowering Technology (the e on the left side of keyboard) and then go to Acer Recovery Management
Posted on Jan 29, 2009
  • 65 Answers
SOURCE: Acer Aspire 5315 No Recovery Disk - Restart
yes you can use the recovery partition which should be built into the hard drive. press f2 on the bios screen and follow the on board instructions. this will return the laptop to its original factory state. Keep in mind that this is a destructive reinstall of windows and you will lose all data and programs.
make sure you do a recovery and NOT a system restore to earlier date.
hope this helps.
Posted on Dec 10, 2009
drifterK
  • 4924 Answers
SOURCE: acer aspire one 1640Z XP BIOS RECOVERY WON'T READ USB WITH BIOS
if I understood correctly you have the recovery software loaded on a stick flash drive and you want to boot from usb to restore the pc .....There are a few things that you have to know about to do that ...
first you have to go to bios and enable boot from another device ....other than hdd /cd or flopy ... for some elder bios this isnt even a choice ..or ..if it is ,,it will be as a sub options into the hdd...choice ..
another thing that you have to keep in mind ..is that you have to disable the other options to force it boot from this one ...or ....to press f8 on boot and manually choose the usm or the stick name that will appear on boot devices...
the most important thing is that if you already formatted the hdd it does notr have a usb driver loaded and that why willl not see the device ...also the device you are using to boot ...has to be specially formatted to be bootable ....this is made ussualy with a hp format tool ...and it is explained in more than one places on the net ...just look for making a boot-able stick (usb device)
in short ...make sure the sticvk is boot-able ...second the pc ha s teh capability to boot from another device ...and this is a feature that you already enabled like first boot device ...
than things will be easy ...it will ask you to press any key to boot from the usb ...and continue like an installation from the cd ...
if you cannot do it ...I recommend using a cd ..or an image that you will ***** in a virtual cd ...for those that do not have cd drive ( use daemon tool )
Posted on Dec 21, 2009
eldhobabyk
  • 63 Answers
SOURCE: I don't have the Recovery Disk for my Acer Aspire
Select models have the ability to have the operating system reinstalled from a hidden drive built into the computer.
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
  5. Select ' completely restore to factory defaults '
Posted on Oct 23, 2010
  • 236 Answers
SOURCE: I need a acer aspire
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Posted on Feb 11, 2011
Acer aspire 5552g recovery disk
Hi , not sure if you need one, there will be a revovery partition on your hard disk.
see link below
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
recovery disks should be available through Ebay
Jan 21, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
How to delete all my files and restore my acer 5336 aspire
Restoring from the Acer Aspire System Recovery partition is easy Most Aspires will have a second partition that can be used to restore if you do not have CD It is recommended that you make those CD when you first buy the laptop If you don t you run the risk of not being able to install Windows again if that second partition fails Restoring From The Acer Aspire System Recovery Partition Keep in mind that running the recovery will restore the computer to the way it was when you first brought it home Anything you added will be lost so make sure you have program disks passwords favorite websites photos, documents and anything else you need backed up before proceeding with the recovery of your Acer Aspire.Hard Disk Recovery should be enabled by default If it is not you may need to go into your system s BIOS by hitting F2 at boot and enable it under the Advanced tab Once Hard Disk Recovery is enabled, restart the system and hit ALT F10 This will begin restoring from the Aspire system recovery partition. You will be prompted to type six zeros as a security step Type 000000 to proceed You will then see a screen to select your Operating System. Do this and hit enter and the recovery process will begin You Cannot Use The Acer Aspire System Recovery Partition The process for restoring from the Acer Aspire System Recovery partition is similar with all major brand names The most important thing to remember is to always have backups of your data and take a few minutes to burn recovery DVDs using Acer s built in utility. Creating these backup DVD is vital If the hard drive fails you will not be able to perform a recovery from the Acer Aspire system recovery partition Create the media and store it in a safe place along with the rest of your software and computer documentation
Nov 04, 2011 | Acer Aspire AS5336-2524 Laptop
I NEED A ACER ASPIRE RECOVERY DISK MODEL 5640..DISK THAT WILL BRING THE COMPUTER TO FACTORY SETTINGS
try hitting alt-F10 at startup... should access the recovery partition and then just follow the prompts. hope that helps!
Sep 15, 2011 | Acer Aspire m5640 PC Desktop
Hello,my brother repormatted my laptop acer aspire 5732z,and also deleted the recovery.how can i take the recover of this model
Once you delete the recovery partition there isn't any way to get it back. Depending on the model they might have sent you a recovery disk - that should reset the system.
Mar 06, 2011 | Acer Computers & Internet
I need a acer aspire one happy recovery disk
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Error code 204 - acer recovery disk
need acer Recovery cd? or cannot doing recovery?
when you the ACER logo dring start up press ALT+F10 together recovery is going to start if it doesn have any corrupt file.
May 31, 2009 | Acer Aspire 4930-6862 Laptop
Cannot load recovery cd on my acer aspire 5100
First check the BIOS options whether u had selected CD/DVD drive as first boot device.and try.....If still the recovery disk doesnt load...u have to determine that the disks are corrupted ......Order for new disks from ACER.
May 10, 2009 | Acer Aspire 5100 Notebook
Acer aspire 4315 recovery cd file...
Dec 26, 2008 | Acer Aspire 4315 Notebook
Recovery Disk for Acer Aspire 5315
No, Acer no longer supplies the recovery discette off the bat. However if you call their customer service they can send you one.
Sep 04, 2008 | Computers & Internet
Acer Aspire 7520-5185 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
