Question about Haier HLP21E Top Load Washer
WASHER LEAKING ALL OVER THE PLACE
I STARTED MY WASHING MACHINE I WENT TO WORK AND MY NEIGHBER WENT TO TURN OFF THE WATER WHEN SHE GOT THERE I HAD A FLOOD ALL OVER MY KITCHEN FLOOR.
  • 4 Answers
Also make sure the hose connection on the washer is tight. This can cause a leak, too, though probably not enough to flood.
Posted on Jan 22, 2009
    Problem Solver:
  • 8 Answers
Your float system is malfunctioning. This is a system in place to tell the machine when to stop taking in water at whatever level you set it to. Its either a rubber hose system or sometimes an electrical float switch.
Posted on Jan 13, 2009
  • Emily Edgy Jan 24, 2012
    davidnpr... any hints as to how to fix this? Mine happens from time to time, but is getting more frequent, after flooding my apartment (and my downstairs neighbors) twice, I now always put the washer in the bathtub to do laundry... but I would still like it to function properly. I am afraid one of these times it will short itself out, with all that water running down the insides with the electrics. THANKS!!
    Can you explain how to fix this?
    Thanks!!
When I hook of the water hoses to the back of washing machine and turn on the water, water spews out of hose
Hello Ifox5858,
I understand that when you hook up the hose to the back of your washing machine that the water comes out of the hose. The problem that you are having may be because of washers are missing out of the hose ends. You need to take the hoses off and look and see if you have rubber washers in the side that is leaking. The washers are standard water hose washers you can buy at any hardware store.
1. Place washer in hose
2. Install hose hand tight
3. Turn a quarter turn with wrench
4. Turn water on check for leaks if leaking slowly turn tighter to leak stops
This should fix your problem.
Thank you for choosing FIxya.com
Justin
Mar 16, 2011 | Fisher and Paykel Washing Machines
Whirlpool Washer Model No. LXR-1564039, Serial No. CM-1564039, Type 107, Year 2006. Went using the extra large setting the washer leaks water from the bottom, however went filling for the rinse...
Although its difficult to say the problem may not be caused by the amount of water but the water temperature.
Most often rinse tempertaure is cold only, however the wash might be warm /hot. A great place to start would be when the machine is filling in wash watch the connectons from the taps to the machine for any leaks in the hoses or connections.
Hope it helps.
Nov 23, 2010 | Whirlpool Washing Machines
Leaking water
When your Maytag top load washing machine leaks water, you will need to check the following parts until you find where the leak is coming from.
The water valve: The first place you need to check is behind the washer. Check the two fill hoses and the water mixing valve.
Check for pinholes or cracks on the plastic body of water mixing valve.
Remove the front panel : The next thing you need to do, is to remove the front panel so you could see the tub and the hoses.
Set the washer on the regular cycle and turn it on so it could start filling.
Use a drop light and check all the hoses under the washer as the washer is filling.
Make sure to keep your hands away from any moving parts.
The pump : If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag washing machine to leak water.
The stem & seal : Another place that the washer could leak water from, is the stem & seal on the holding tank.
When washer leaks water from the stem & seal, the water will leak down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110.
Apr 19, 2010 | Maytag PAV2300 Top Load Washer
Water runnning out from bottom of washing machine
Barbarahaps,
I had a similiar problem with a Brand X washer. the problem may be your water pump. if so, it is an easy fix for someone who is mechanically inclined. you first must see where the water is leaking from. when i did this, i securly placed my washer on cinder blocks so that i could see underneath it, and let it fill with a little bit of water, then i could clearly see the water leaking out of the water pump. the key concern here is safety, make sure that the machine fills with only a little bit of water, and then cut the power off to the machine to ensure it doesn't start going through its cycle while up on the blocks, creating a potential hazard. If it is the waterpump, find a washer repair store, tell them the year and model machine you have, and get a water pump on order. the water pump is a pretty straight foward repair--you disconnect power from the machine, turn off and disconnect the water supply, disconnect the drain pipe, and tip over the washer to expose its under side. you disconnect the hoses going to the water pump, remove the attaching bolts, and install the new pump. then you hook everything back up and you should be good to go. hope this helps.
Nov 28, 2008 | Speed Queen AWS52NW Top Load Washer
Leaking
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
Aug 21, 2008 | Miele Novotronic Premier 500 Front Load...
Miele leak when switched on for wash, from filter unit front LHS bottom of machince
Aug 06, 2008 | Miele Novotronic Premier 500 Front Load...
Washer leaks on on the floor when using a large load setting.
Jul 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have purchased a Maytag washer mtw6300tqo and it leaked from the first day it arrived. It does not leak DURING the cycles but leaks profusely a few hours later. I have had service techs look at it and...
Is there water inside the tub after it starts leaking? If so the valve that lets the water into the machine could have a bad seal and overfilling the machine with water when it is not being used. Or one of your water hose seals could be leaking. Make sure the hoses are tight. Beyond that there is nothing to cause a profuse amount of water when the machine is not being used.
Apr 26, 2008 | Maytag Dependable Care LAT9206
Washer portion not working...?
wowwow...that's a sprung seal allright..have to turn it over, and remove the bottom, motor, etc..got a service person handy?
Feb 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dribbling water when trying to fill up
Turn off faucets for hoses to washer. disconnect hoses at washer, noting which one went where first.. Hold end of hose in washer tub and turn on faucet. If it comes out strong, check the filter screens in washer inlet valve where hoses connected. DO-NOT remove these screens. If you do it can cause flooding by allowing grit to hold open valve. Clean screens without removing them by scraping with small screwdriver and flushing with water.
Nov 21, 2007 | Washing Machines
Haier HLP21E Top Load Washer Logo
291 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
