Question about Frigidaire Gallery GLHS66EJSB Stainless Steel Side by Side Refrigerator
Water dispensor light stays on, shuts off when you open the freezer door
Determine if door switches are magnetic or mechanical and if light is a/c or d/c powered This makes a huge difference I suspect it is d/c and that some fault lies within that circuitry eg control board or if it is a/c power to the light check for possible short in switch
PS Is that your only symptom?
Posted on Dec 10, 2012
3 Suggested Answers
mumma_1
  • 903 Answers
SOURCE: upright freezer door won't stay shut
the door maybe disaligned. Look at the the door side on to see if it has dropped a little. It may just need adjusting.
Posted on Oct 25, 2008
Controlfrk
  • 304 Answers
SOURCE: frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Posted on Aug 24, 2009
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Water won't come out of the dispenser. I Checked to the door and the water works to the door, but won't come from the dispenser.
open the door, place a blanket over the opening to keep yopur food cold, and use a blowdryer on medium to warm up the inside of the door in the area where the water comes out. It should thaw the line.
I had the same problem yesterday, and the water was flowing normally in about 10 minutes.
if you dont have a dryer, it will thaw on it's own, but may take a little longer
Dec 10, 2009 | GE Profile PFS22 33" Artica French Door...
Ice maker door stays open. How do I take off front panel to revel parts?
Remove the top freezer door hinge cover and disconnect the plug there . This removes power to the door only . Between the dispensor grate and the dispensor cover , inside at the bottom inside dispensor , insert a butter knife and push down and inward , to pop the bottom of dispensor cover outward , on each inner side . This will pop the 2 plastic clips on the cover off . Lift the cover , to pass the plastic retainer tabs . Disconnect the plug to the dispensor . There are 2 screws holding the white housing which has the switches mounted onto it . Remove these screws , and slide the housing foreward and lift . You should be able to see the complete flap door and the spring and pin , to decide what is causing the door to stay open . If you come back with the found problem , and the model number , I would be able to give you the part number(s) needed .
Sep 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser door flap will not close completely. I'm sure something has sprung or broke inside the door. How do I get the face off to look at the mechanism that opens and closes the door?
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser suddenly not dispensing water
Remove the bottom kick plate . Follow the plastic line about 6" and you'll find a connector . Push in on one end of the connector and at the same time , pull the line out . Close the door and press for water . If no water comes out of the disconnented line , the water valve is probably bad . If water does come out , the line inside the freezer door is frozen . If this turns out to be so , you can lower the freezer temp for maybe days , or , put the food on the door, inside the freezer , tape the light switch down ( to keep the lite off and fan running ) and tape plastic over the freezer door opening so the freezer will continue to work . Reinstall the line back into the connector by pushing the hose firmly into place . Leave the freezer door open for maybe 1 or 2 days for thawing out , going by ocassionally and pressing the water dispensor . Important : lower the freezer temperature slightly to keep line from freezing again . ONLY CHANGE THE FILTER WHEN WATER FLOW SLOWS OR ICE CUBES GET SMALL . The change filter lite comes on by the amount of times water dispensor is used and to make money for the vendor .
Aug 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispensor quit working
the water line that runs from the bottom of the freezer door up to the water dispenser is probably frozen. I have run across this problem several times. you can take the line out of the freezer door, thaw it out and re-insert it, but chances are it will happen again. usually when you have that issue, there is a problem with the insulation in the freezer door and you will need to have the whole freezer door replaced. Joe
Dec 03, 2008 | Whirlpool GS6SHEXNS Side by Side...
My Whirlpool model DE22RQ or DQ water dispensor does not work. The ice maker is working. I hear a humming sound from the back when the dispensor is pressed but no water comes out.
checked for a clog in the inlet side of the valve where the water comes in there is a small screen that maybe blocked also check on the back wall of the freezer where the fill tube goes into the units icemaker it could have frozen up due to low water pressure
Jun 08, 2008 | Whirlpool Refrigerators
Water Dispensor
The water line is frozen inside the freezer door. Open the freezer door and take a hair dryer to warm the inside of the feezer door. Check the water dispenser every 5 minutes to see if the line is unfrozen. Water line is ran from the bottom to the waterr dispense unit. Usally take 10-20 minutes to unthaw water line inside of freezer door. Good luck.
Nov 07, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Frigidaire Gallery GLHS66EJSB Stainless Steel  Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
