Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer lights flashing, dryer does not work
The dryer has stopped heating several times lately and I have reset the trip fuse on the lower front of the unit. I have installed a complete new vent tube (rigid plastic ) and vacuumed the inside lint trap inside the drum and under the bottom of the tub while the front panel was off. Now all the lights are flashing in a sequence from side to side in sequensial order and will not stop. I have turned off the circuit breaker and waited for 60 seconds but no cigar. I am stumped.
SOURCE: Dryer won't heat
Since I just had a repair man out to look at mine, there are two screws--one at the front of each side just under the lid. When you remove them you can pop the top up. That exposes two more screws, one at the top of each side of the front assembly. Remove them, and pull the front off.
Posted on Dec 15, 2007
RescueTech
  • 145 Answers
SOURCE: Dryer tumbles, no heat
Fist thing to check is if the manual reset on the heater box has tripped. That dryer can be serviced from the front. Also, there is a heater upgrade kit that can be purchased from Fisher Paykel Parts that has several updated parts in it for the top load electric dryers.
There are several things that can cause the reset to pop out. You may have a lint build up behind the shroud where the lint bucket fits.
This is a complicated appliance. You may wish to obtain a service manual for it.
Link to factory service manual:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=39
Link to heater upgrade kit:
http://fisherpaykelparts.net/index.php?categoryid=112&productid=32
Posted on Dec 18, 2008
  • 10 Answers
SOURCE: Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
Posted on May 12, 2009
canbruce75
  • 1776 Answers
SOURCE: First the dryer stopped heating, then when the
This is a situation that you need to be very careful with. It sounds like you have a grounded heating element. If this is the case, then the current can be running through the dryer's frame and can cause electrical shock. Keep the dryer unplugged and check the heating element for continuity. If it has none, replace the heating element. BE CAREFUL. Hope this helped and best wishes.
Posted on Aug 03, 2009
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Posted on Nov 08, 2009
Can u help me
follow this steps and fix it, use the multimeter . Merry Christmas
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Dec 17, 2013 | Hoover VHC391 T-80 Dryer
Runs but does not heat up and does not dry. The service man showed me the reset button. It was tripped for him but does not appear tripped now. We have had this problem intermittently for a year. Every...
HI,
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 11, 2008 | Asko Dryers
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
The dryer works but no heat.
Check the following to address this issue.
2. Heating element
3. Thermal fuse
Jun 18, 2009 | Whirlpool GEW9250 Electric Dryer
Calypso Senseon electric, No beeps, no lights, nothing,
If your dryer doesn't work at all, it could be because of problems with:
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
May 20, 2009 | Whirlpool GEW9868K Electric Dryer
Kenore Senor Smart 27-inch dryer control panel not working
May 20, 2009 | Kenmore 72062 Gas Dryer
Dec 17, 2008 | Fisher and Paykel DEIX2 Electric Dryer
This is the 2nd time my dryer in 1 year just stopped working and last time it cost me $100
http://www.repairclinic.com/0088_8_1.asp#Level1_1
Door switch
Thermal fuse
Wiring
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Frigidaire Dryers
Not heating
The reset button needs to be replaced.  Once it has tripped, it loses it's setting and will trip at a much lower temperature.  This is a standard procedure that LG is telling all their techs to do.
Mar 24, 2008 | LG DLE2532W Electric Dryer
No heat in dryer and can't find reset button
Unplug the dryer. Disconnect the vent hose from the wall and clear any lint etc. from the opening. Anything clogged with lint will continue to cause the heating element to "trip" for safety reasons.
Open the top by pressing in on the hidden metal clips on the right and left front (there is a small gap below the top section) Use a putty knife or screw driver to press in on the clips. Lift up like a car hood and then prop it up while you're working. Next open the dryer door. Remove the two screws on either side of the lower opening. Now lift the front up and out, set off to the left side as it is still connected by a wire. Look into the lower right side of the dryer with a flashlight. The reset button is located between the two wires that attach to the outside of the cylindrical drum at the 7 o'clock position. You need to be lying on the floor so you can reach your hand in. It is about halfway into the dryer. Press the button. Now reassemble the dryer before you start it up again. For a gas dryer - let it run and you should hear it "fire" up within a minute and the heating will begin.
Oct 10, 2007 | LG DLE2532W Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
71 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
