I need RAM memory cards 2 Ghz for my Toshiba m70-131
I want to increase the memory from 504 MB to 2 Ghz
  • Computers & ... Master
  • 27,725 Answers
If you mean 504 mb to 2 gb of ram
Make sure ram modules are of the same brand any type
IE corsair ddr3 low density or hynix high density ddr2 you should always try to keep the same brand and type of ram
reason being the compatibility issue
and always place the largest ram module closest the CPU central processing unit
also check the ram sockets for dust and make sure the ram modules are securely seated you can do this by pressing the levers at either end of the ram sockets If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible Hope this helps.
Posted on Dec 10, 2012
  • 2,878 Answers
alocenar
  • 293 Answers
SOURCE: Increase performance on toshiba A215-7428
no upgrading the motherboard will not help.
try to change the hard disk , replace it with bigger capacity.
check with the service center guy if they can put 2.0 or 2.4ghz processor.
Posted on Apr 10, 2008
SOURCE: Toshiba flash cards " not Responding"
Dear Sear
First of all i aprechiat your willing to offer me a solution for the problem (flash cards are not responding).My laptop has thise model; Toshiba Satellite A200 - 1 GB - intel(R)Core(TM)2 CPU T5300 @ 1,7 MHz.
I solved the problem just with shuting down the mashin, that's all.
I thank you indeed for you respond and i'm looking forwards.
Best regards
Yours
Aweti.J
Posted on Aug 19, 2008
  • 124 Answers
SOURCE: Increase the graphics memory
Unfortunately, Dedicated video memory cannot be changed. Only the Allocated system memory. The dedicated video memory is onboard memory, like a video card in a desktop machine has it's own RAM. Your out of luck, unfortunately.
Posted on Dec 10, 2008
antiochpc
  • 1314 Answers
SOURCE: How to increase the video memory of my laptop
This is done in the BIOS screen. Upon startup of the computer, press the key or key combination the screen tells you to in order to enter the BIOS. Somwhere in there there will be a selection for video memory that you can change. Thanks and please don't forget to give this solution a fixya rating. :c)
Posted on Jan 08, 2009
joegoldman
  • 335 Answers
SOURCE: how to increase shared videocard memory on Aspire 4315-300512Mi
If there's nothing in the bios, then check the intel video driver/management software installed on the laptop. Also consider calling Acer support. They are excellent.
Posted on Aug 09, 2009
Is there a way the memory in a toshiba satellite 1005-s157 be increased to more than 512MB?
Yes you can, at least to 1 Gb maybe possibly to 2 Gb.
There will be two memory slots in your laptop. To increase the RAM to 1 Gb install another 512 Mb RAM module in the empty 2nd memory slot. Make sure you use the same make and speed RAM as the one that is installed.
If you have two 256 Mb RAM modules installed in your laptop then you need to replace the two 256 Mb RAM modules with two 512 Mb RAM modules to get a total of 1 Gb RAM.
Aug 04, 2012 | Toshiba Computers & Internet
I have been given a Toshiba MK 4025GAS laptop, it has 240 MB of RAM. How much more RAM can I put on it?
click start right click on my computer select properties you should how much ram you have installed and how much available it looks like it is capable of 4GB of ram remember when adding more ram try to keep the same brand/type as some motherboards will only work with the one type of ram together and always place the larger ram closest to the cpu central processing unit
Toshiba Mk4025gas Pm ... Shipping: FREE Total: $98.72 Memory Specifications Module Size(s): 2x4GB Type
CPU
Intel Celeron M 370 1.50GHz BIOS Phoenix BIOS. Press F2 to enter Chipset SiS 661 Memory 512MB PC2700 DDR SODIMM (2 memory slots. Max 2GB) ** Hard Drive 40GB Toshiba MK4025GAS CD Drive Philips DVD+-RW SDVD 8441 Screen 14" TFT (Native Res.1024x768) Video Card SiS 661FX (64MB shared) Sound Card Realtek AC'97 audio Network Card SiS 900 integrated fast ethernet
Atheros AR5BMB5 Wireless LAN * Modem Agere systems AC'97 modem Ports 1x Headphone
1x Microphone
1x PC Card
4x USB 2.0
1x Modem
1x LAN
1x VGA
1x S-Video (TV-Out) Touchpad Synaptics Touchpad Battery SQU-504 (11.1v 4400mAh) Dimensions 33 x 314 x 258 (HxWxD in mm) Weight 2.3kg Made By Quanta LE1D
The full system specs are:
CPU: AMD Sempron LV 3000+ (1.8 GHz.)
RAM: 1 GB. DDR-333, Kingston
Chipset: ATI Radeon Xpress 200M (RS480M/SB450)
GPU: ATI Radeon Xpress 200M
HDD: Toshiba MK4025GAS (40 GB., IDE, 4200 RPM)
ODD: TSSTcorp Combo (DVD-ROM/CD-RW 8x24x24x24)
Other:
- Texas Instruments UltraMedia Card Reader PCI xx21/xx11
- Broadcom 802.11g Wireless LAN
OS: Windows 7 Ultimate (32 bits, obviously
as you can see there is a contradiction in how much ram but if its a windows 7 it will need a minimum of 2 gb of ram but it could use 4gb
hope this helps
Jun 17, 2011 | Toshiba MK4025GAS (c99529) 40 GB Hard...
No sounds installer for Microsoft Windows XP,Professional Version 2002 Intel (R) Celeron(R) M Processor 1.3 GHz 1.3 Ghz,504 MB of RAM
Use UniBlue Driver scanner which will scan for missing sound card drivers and will install the ones for your model of sound card
Jun 22, 2010 | Computers & Internet
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
Computer runs slow on some games HELP!!!!
In order to play RollerCoaster Tycoon® 3, you will need a PC running Windows with the following minimum requirements.
Minimum and recommended computer specifications are as follows:
Operating System: Windows® 98/Me/2000/XP (Windows® XP recommended)
Processor: Pentium® III 733 MHz or compatible (Pentium® 4 1.2 GHz or compatible recommended)
Memory: 128 MB RAM; 256 MB for XP (256 MB; 384 MB for XP recommended)
Hard Disk Space: 600 MB free CD-ROM Drive: 4X CD-ROM or faster (8X or faster recommended)
Video: Any ATI Radeon™ or GeForce™ 2 with 32MB or higher; or other video card with 32MB and hardware T&L (ATI Radeon™ 64 MB SDR or GeForce™ 2 Pro or other video card with 64 MB or more memory and hardware T&L recommended)*
Sound: Windows® 98/Me/2000/XP-compatible 16-bit sound card*
DirectX®: DirectX® version 9 (included) or higher
Apr 06, 2010 | Computers & Internet
Burned RAM
just remove the 256mb ram it is the main problem only insert equal memmory of rams in 2 slots, if u insert 1gb ram in one slot try to insert also 1gb ram in other slot, donot inser 2 unequal rams in one time
Sep 28, 2009 | Computers & Internet
Not enough memory
  • your Toshiba Satellite M35X-S311 has the following memory configuration
  • Configured with 512MB
  • The maximum memory you can have is 2048MB (Max),
  • 2 memory slots using 1024MB PC2700 DDR333 SDRAM 2.5V SODIMM Memory modules (Both slots may be occupied). Go to a store and request for this memory specification and you will have 2GB of memory for all the programs you have listed here. Good Luck!
Mar 30, 2009 | Toshiba Satellite M35X-S311 Notebook
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Increasing memory
    hi, the new RAM you inserted does'nt seem to support your system. Check out which type of RAM it support and use accordingly.
    Jun 28, 2008 | Toshiba Computers & Internet
    No gain
    happened to me too, I just fiddled with the phantom power button (wiggled it a little while it was pressed in) and my gain came back *shrug*
    Feb 21, 2008 | Lexicon Lambda Usb Desktop Recording...
    Computers & Internet Logo
    53 people viewed this question
    David Payne
    David Payne
