Question about Samsung 52 in. LCD Flat-Panel HDTV
Samsung 52" LCD TV has a bar down the middle of the screen.
Its about 8 inches wide and goes from top to bottom. The bar itself is multi colored. Like a rainbow. Whats wrong? Can it be repaired and how much?
  • Samsung Master
  • 8,617 Answers
That can be either a tconn issue about 60.00 or a bad LCD panel which is not repairable. I would assume its the Tcon board. You can get replacement Tcon from www.tvcircuitboards.com
Posted on Dec 10, 2012
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 158 Answers
Your T-con board is defective.
Posted on Aug 21, 2015
  • 103 Answers
SOURCE: samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Posted on Mar 05, 2008
rlamkin
  • 44 Answers
SOURCE: Samsung plasma tv hp-r4262
The x drive board is bad in the area you see as black. OR the cable came loose.
Posted on Jul 04, 2008
Shuttle83
  • 1139 Answers
SOURCE: Rainbow color effect appears when Samsung LCD plays Wii or DVD
Hello, I have a question which video inputs are you using for your DVD and Wii connections? The reason I ask is because this sounds like video distortion cuased by noise. If possible can you send a picture of the screen when it has this problem and send which video ports are being used? If it is noise in the video you may have a saw filter problem, or a decoupling issue. In any event I'll know more once you send those pictures and which inputs you are using for your DVD and Wii. Thank you, Shuttle83 http://www.electron-age-technologies-llc.com service@electron-age-technologies-llc.com
Posted on Jun 10, 2009
  • 267 Answers
SOURCE: Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Posted on Jun 26, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Posted on Apr 18, 2010
How to fix Westinghouse WD32HD1390 tv when black vertical bar show up on display?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 19, 2017 | Westinghouse Televison & Video
Phillips flat screen has a vertical blue line, about 2inches wide, running from from the top to about a third down the 52 inch screen. What causes this
Take ur hand and pushes all around the tv frame bazel see if the veritical blue line react like flashes or lighter or darker,than this tv can not be repair at all because the LCD screen itself it is the caused,the LCD screen cost same as a new tv if it is require to be replace.If there are no reaction of the blue line at all than ur tv have a circuit board problem.The T-CON board is dying,this board sit in the middle bottom of the LCD screen,must be replaced will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-Con board for the replacement.
Aug 04, 2013 | Vizio Gallevia GV42LF 42 in. LCD...
White flare top left of screen sony bravia ldl-52W3000.
The capacitors at the main power supply regulator board should be checked and replaced. If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Jan 20, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
I HAVE A 50" PLASMA SAMSUNG TV HAS A 2" WIDE
Something is wrong with your logic board, you've got the option of returning this TV if it's still under warranty or buying a new one.
May 03, 2011 | Samsung Televison & Video
Sharp 26"hdtv started with a 1/16" color bar that
If you mean the bar goes top to bottom, there are circuitboards that feed the info in small sections top to bottom. But usually one section will be one inch wide. It can also be the screen panel itself. Try a trusted tv shop
Nov 25, 2010 | Sharp LC26DV20U 26 in. LCD HDTV/DVD Combo
Toshiba regza 52xf550u has a 6 inch multi colored line in the middle of the screen...what is the problem
If it flickers and changes colors like my 52" did, I removed the back panel cover, tore off the cheap foil on top and removed the t-con board. Used a head gun as I seem to fix alot of things with it now adays since lead free solder is cheap, heat the points up for about 2 minutes, replace it and throw some air circulation. I also noticed the top of my lcd has two main boards the are supposed to match up a platic pin and slide into place, the boards were warped and wouldn't stay down. I used a dremel polishing wheel, cut it in half and wedged them down and tv is running clean again.
May 15, 2010 | Toshiba 52HL167 52 in. LCD HDTV
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
May 11, 2010 | Televison & Video
Samsung 52 in. LCD Flat-Panel HDTV Logo
171 people viewed this question
Henry  Thomas
Henry Thomas
