Question about Hitachi Clu-577tsi Remote Control
Changed batteries, now won't control power
Batteries died, i changed them, and now the remote only half works. won't control power, up & right on joystick won't work, but volume, number keys & channel all work fine.
  • tr021370
    tr021370 Dec 10, 2012
    unit was working fine until the batteries were changed and there were no other remotes used with this TV. it's behaving like it wants to be programmed, but this is the original remote that came with this television and it is both pre-programmed for this particular television AND has "source wizard" technology to determine any codes necessary. I have changed the batteries in this unit before and have never had an issue. I am at a loss.
  • tr021370
    also - the only components on the remote that won't work are the power & the up/right arrows on the joystick. all else is working.
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
Posted on Dec 10, 2012
  • tr021370
    tried that. found another pair exactly like the ones that came out, but it's doing the exact same thing. Weird this is, it was actually working for a little while (after pulling the batteries & letting it sit for 5 minutes or so), but now it's not working again.
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
I have a 98 gmc Jimmy my remote lock battery died so we were unlocking the truck with the key and driving well that lasted only 2 days and the truck died we got a jump to get it home got a new battery...
Getting spark? Power coming from the battery I think you meant to say, if I am correct. If it won't jump start, sounds like a cable from battery to vehicle is not connected. Igniton switch connection or fuse maybe. Check the daisy chaining of the negative battery cable for clean contacts. Also a starter relay could be bad. Just some more suggestions to add. Don't drive to far from home until repaired. Towing cost too much as you know by now.
Never did like remote locks, We as humans seem to be getting more and more depended on convienances that cause us more inconvienances. Could try a positive cable to starter to check if it will turn over the starter. Voltage regulator could cause battery not to charge while driving. When car dies, do lights work or they dim from engine sucking battery dry. Just some suggestions.
Apr 05, 2013 | Cars & Trucks
My remote car starter from autostart on a grand am 03 won't start or locks won't work after it died for about a week then changed the batteries
Check to be sure the new battery is a good new one, they set on the shelves for some time ya know. Then make sure it goes in the correct direction.Then refer to your owners manual if it needs reprogrammed.
Feb 18, 2013 | Cars & Trucks
My remote control for my TV won't work. I changed
See my response to your other identical question.
Mar 14, 2012 | Philips Televison & Video
My remote won't work and I used to be able to change the channel on the TV but even that dosn't work. I checked the cords. Changed the batteries;
Hello
First check its battery contacts for any rust or dirt accumulated on it. If so, contacts of battery will not touch properly, and the unit will fail to work. The second reason for malfunction is due to the infrared sensor inside your tV. If it is faulty, the set won't respond to infrared signal generated by the remote control. If so, eventhough remote control works properly, the set won't work with it.
Remote sensor comes just behind the infrared window at the bottom front panel of your TV. It is a replacable part and not so costly too. It is a three terninal component will look brownish black in colour. It will looke like this.
gopakumarg43_77.jpgThe procedure to check the remote control for its perfect working is described at a tip I've given and published by Fixya on Google. Type "gopakumarg43" on google search box, and get into my profiles. There you can see 'Tips and How To's" line, click on it. You can read it there. OK.
Sep 23, 2011 | Philips Magnavox 20MT133S 20" TV
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
Jul 31, 2011 | Audio Players & Recorders
My 2000 licolin battery died the key won't open the door lock how do get in to the engin to put jumpers on the battery to give it enough power to work the locks ps i don't understand why the key...
The key has to open the drivers door
Raise the car up,support it,& put your battery
charger on the starter battery cable terminal
& ground the black clip
Try charging the battery for 4 hours or so
Jul 02, 2011 | 1998 Lincoln Continental
The remote won;t work
If it's a "Universal" remote and you've changed the batteries, you'll need to reprogram it according to the make/model of the remote. A remote that came with your receiver....
1. Check batteries, they may be dead or dying.
2. Is something blocking the remote receiving window on the receiver?
Remotes use infrared light to transmit to their matching devices and MUST have a line-of-sight path to work properly.
Apr 13, 2011 | Audio Players & Recorders
Hitachi Clu-577tsi Remote Control Logo
140 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
