Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Drain and spin problem please help
Model # wslp1100doww ser# lhooo548h i have a general elertic spacemaker and it will not spin out all the water so i am thinking it might aslo be a drain problem
  • 1 more comment
  • Anonymous Feb 13, 2009
    I'm having the same problem ! I even had a repair guy look at it and he couldn't figure out what was wrong with it !
  • Anonymous Mar 16, 2009
    can a faulty belt cause drain issues? smell of belt burning and tub won't drain. cause or effect? thanx.
  • Anonymous Apr 28, 2009
    same!
    Problem Solver:
  • 8 Answers
In the pump of these units, have a rubber flap that allows water to go out, but not come back in. Sort of like the rubber flap in your toilet. Often, these things get (through use or age) degraded and either come off or get twisted, especially when you have hard water. Its a very small round rubber part that can easily be replaced, but you must take the face off of the washer to gain access to the pump (situated on the bottom of the washer usually in front) and remove the drain hose. its a red flap. If this is not your problem (usually if this is the problem, your clothes would be all soak and wet as water is not being pumped out) then you may just want to take the face off the washer, and feel the belt around the motor pully. if this is loose, that could be why the clothes are not spinning with as much force as a tighter belt. Or your motor could be going..if it is an older unit that is not unheard of.
Posted on Jan 13, 2009
Ge wslp1100a0ww washer leaves clothes soaking wet, not spinning properly
You don't say whether agitation is normal. Improper spin can be slipping V belt (stretched or cracked), part #WH01X10081, or loss of transmission fluid. Is there oil on the ground under the washer (shouldn't be)? Let's start here. Motor, belt, and transmission are at the bottom of the washer.
Jun 04, 2014 | GE Spacemaker WSLP1100D Top Load Washer
Dishwasher not draining
I am not familiar with this model, but in general, dishwashers have a grill or trap at the bottom near the back usually and it's held down by screws. SHUT THE POWER AT THE BREAKER PANEL AND SHUT THE WATER SUPPLY OFF! Then check the type of fastener and remove the cover. If it is obstructed by food debris, you'll see it there. Good luck and let me know if this helped.
Mar 29, 2013 | GE Dishwashers
My spacemaker will not drain or function in spin cycle
Hello & Welcome to FixYa
When the unit is unable to drain it will not even work in spin cycle, the problem is with blocked drain/drain pump filter which should be cleaned. If after cleaning the problem comes back then the drain pump needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Spacemaker Washer and Dryer Electric...
Washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Jun 11, 2010 | GE Spacemaker Washer and Dryer Electric...
Water is not draining?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | GE WSM2480DWW Unitized Spacemaker Washer...
My GE spacemaker top loader will not drain, makes buzzing noise
May 29, 2010 | GE Spacemaker Washer and Dryer Electric...
Ge washer making a noise trying to pump water out its a wslp1100doww model. How do u change the belt on the washer? precise instruction in detail would be great
if the belt is not broken you dont need to change it remove hoses from pump and clean the pump out...shopvac the water out of the machine first so you dont unleash it all over your house...
Apr 16, 2010 | GE Spacemaker WSLP1100D Top Load Washer
Model 238322100 ser cm4768086 type 111
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 22, 2009 | Kenmore Washing Machines
Washer won't drain or spin
Probably a bad drain valve. As long as the tub is still full of water, the controls will not allow it spin, refill, etc. Have a service technician check the drain valve.
Jul 10, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Spin Cycle
you can check the direct drive coupling between the motor and the transmission, if the coupling is good and not broken then you have a transmission problem
Apr 30, 2008 | Washing Machines
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
432 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
