Question about Sony Cyber-shot DSC-N2 Digital Camera
Took a picture in cold snowy weather
My cyber-shot froze in the open position. Cannot get it to close or take a picture.
  • christina Bonfield Jan 16, 2009
    got new batteries, the power comes on for half a second the access lamp comes on as well. but the problem stays the same.
    Problem Solver:
  • 16 Answers
I have read that weather conditions do affect batteries. If you haven't already done so, might I suggest that you replace or recharge the batteries. Also ensure that you have got the correct batteries as per the camera's user manual.
Failing that, it could well need a visit to the repair shop.
Hope this helps
G
Posted on Jan 13, 2009
How to transfer internal memory pictures on a DSCW70
Unlike most brands/ models of cameras, the Sony CyberShot (DSC) cameras feature internal memories, (not enough to hold sufficient data). If you took a few shots before inserting the memory card, the pictures are stored in the internal memory. You can transfer/ delete those pictures by the following steps.
1. switch off the camera,
2 open the battery/ SD card slot cover and remove the SD card.
3. close the cover and switch on
4. press the display/ preview button and your picture should be visible on the screen.
You can now do whatever you want with your picture.
Does this help? Please provide some feed-back if my answers do help.
Sep 09, 2014 | Sony Cyber-shot DSC-W70 Digital Camera
My Sony Cyber-shot DSC-S600 stopped working. I press the power button and nothing happens. I tried changing batteries, but it shows no sign of life. It was left in the trunk of my car overnight, inside a...
Remove the batteries and SD card, leave the battery door open, and put the camera in a jar along with a dessicant bag or a small bag of uncooked rice that has been opened. Put the lid on the jar and let it sit for a day or so. This should absorb any condensation inside the camera that may be keeping it from working properly.
Jul 02, 2017 | Sony Cyber-shot DSC-S600 Digital Camera
Recently when I started my car and move my steering wheel I hear a squeaking noise. The weather has been cold and snowy. Does this noise happen because of the weather?
THIS IS CAUSED BYTHE PLASTIC COVERS RUBBING ON THE SHAFT, IF U SPRAY SOM LUBERCANT ,LIKE WD40 OR SPRAY WAX IN THE AREA THE NOISE WILL GO AWAY , YES ITS THE COLD CAUSING IT , TRY DIFFERENT POSITIONS FOR THE STERING WHEEL
Feb 16, 2010 | 2004 Hyundai Elantra
All of a sudden our garage door stopped working and the light flashes 10 times. Liftmaster Model 2265 1/2HP. Any ideas?
We just had the same problem this morning (cold weather can mess these things up). Not sure what you mean by "not working". Ours would open part-way and then stop (or close part-way and then stop), but could open/close all the way if we held the button on the wall down the entire time it was lifting. After much research online, we ended up checking the sensors at the bottom of the garage door tracks to make sure that the green light was solid (not flashing). Ours flashed a bit, so we cleaned the "eye" and tightened it in place. Once the green was solid, we thought we were done, but still had the problem.
Then we began adjusting the screws on the unit itself that show pictures of the door opening and closing. We thought we were adjusting the torque in the unit (because we read online that cold weather can make it more difficult for the motor to work), but in reality we were adjusting the opening and closing "distance". Apparently cold weather can also do something to the tracks, which can require adjustments to be made. Something to do with ground swelling...
Anyway, we also discovered that when we had closed the door manually (red pull-cord) the night before for lack of a better solution, it never properly locked back into position, which was adding to the problem.
So, first, try cleaning the sensors. You need a solid green light for them to function properly. Second, if you have used the manual cord, make sure the arm that it attaches to is locked back into position. You can accomplish this by pulling the manual cord, manually closing the garage, and then pushing the button on the wall. The door arm should lock into place. Third, try using a screwdriver to adjust the open/close distance. Start with a 1/4 turn for each position, and play with it until you find the right setting.
If these suggestions don't address your problem, this link worked for us...http://forum.doityourself.com/doors-windows/368278-garage-door-wont-go-down-cold-weather.html
Oct 10, 2009 | Electrical Supplies
Why does my cyber shot dsc-s750 has lines when i took pictures.?
Please follow the following steps or lookup page 14 and 16 of your user guide.
Jul 07, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
Sony Cyber-shot camera DSC-H10
it more than likely took a fall or impact. since its lens just floats on flexes one is probably out of position
Aug 19, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony cyber shot dsc-s90
i don't have one,
did you get sand in it? that's what happened to mine and i opened it up and took the sand out. piece of cake!
but ir sounds like you might have a motor problem... that different. good luck!
Aug 07, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Frozen camera
dont do anything. bring it to service center
Jul 14, 2008 | Sony Cyber-Shot DSC-P73 Digital Camera
Lost pictures in my cyber shot sony camera
Hey debsdevo,
That's great! I'm glad you found your images, and thanks for responding back.
Sincerely,
Allan
Go Ahead. Use Us.
Apr 14, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot  DSC-N2 Digital Camera Logo
44 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
