Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Removing paddle from 325 artisan - KitchenAid KSM150PS Artisan Series Stand Mixer
  • KitchenAid Master
  • 1,251 Answers
Get some CRC around it, wriggle and grunt for a while and it will release. Clean the shaft and the beater hole. Flour builds up in there and grabs on tight.
Posted on Dec 01, 2013
My artisan mixer will not turn back on
Make sure it's unplugged, remove and inspect the carbon brushes one at a time under those black screws on the side. They are keyed with one corner of the square ground off so will only go in properly one way so eyes open when you take them out. If they are less than 10mm long replace them. Next would be look under the back cover for a broken wire to the black square speed control plate. Broken wires are only likely to be one of the bottom 2 on either side. Any more testing is going to require a multimeter.
Dec 20, 2015 | KitchenAid KSM150PSGA Model KSM150PS...
Head does not lock but when adjusted whisk touches bowl
The screw is purely for adjusting the head height and that is with the flat paddle. If the head is not locking when the paddle is at the correct height then the locking mechanism needs to be adjusted. If you take it to a Kitchen Aid authorised service person they will sort it for you, they will have done heaps of them. Often the solution is with a file, if you go too far there is no going back so best left to the experts.
Jan 21, 2014 | KitchenAid Artisan Stand Mixer KSM150PS -...
How much does it cause for me to buy this mixer?
After looking at several sites the mixer ranges from around the 300.00 range some have it for 240.00 this link has it advertised on Ebay for 185.00 http://www.ebay.com/ctg/KitchenAid-Artisan-KSM150PS-325-Watts-Stand-Mixer-/69779042 . If you were to buy the mixer new from a store it would run you around 340.00. if you have any further questions message me back Thanks
Rick
Sep 10, 2011 | KitchenAid KSM150PS Artisan Series Stand...
What is the difference between the Kitchen Aid "KSM150PSMC" and the KSM150 ?? thanks
The KSM150 is the line of mixers with similar features. It is in the Artisan series, tilt head, 325 watts. All mixers in the KSM150 line have the same features.
The one that you asked about, the KSM150PSMC is done in metallic chrome.
Best regards, --W/D--
Feb 01, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
My 325 Watt Artisan mixer's adapter won't come off? How do I get it unstuck?
To remove the mixer attachment I belive you must press up on the attachment to lock the inside gear into place. Once it is locked into position you can now twist to the left to remove the attachment. once removed you can pull the shaft back down to unlock the gear.Hope this helps.
Thanks.
Nov 15, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Unable to turn mixer on
you have to have the bowl installed correctly and all the schields in place before the unit will work
May 20, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Mixer switch is locked
If this is a 325 watt Artisan, there is no safety switch I know of unless its in the circuit board. Your mixer is broke.
Mar 01, 2009 | KitchenAid KSM150PS Artisan Series Stand...
The pasta/meat grinder attachment stops turning
Its a 325 watt mixer. If you grind or mix dough often you may consider getting something stronger or turn it off every ten minutes or so and let it cool down. We burned a 325 and got the 575 watt "600" series and no problems ever since. I know these things are expensive. The 325 is more mixer than grinder. The attachements fit ANY size mixer but some are not recommended for use in all mixers.
If its quiting see my posts on "doesn't run at sitr" and "Removing the motor cover" To get inside and clean those contacts.
Feb 08, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
119 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
