MY TV DOES NOT WORK ...THE STAND BY LIGHT BLINKS AND SHUTS OFF AFTER FEW MINUTES
I CHANGED THE LAMP AND NOW I DONT GET ANY PICTURE
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If you got one before replacing the lamp, put the old one back.
If not let me know what the model and brand are of your set.
Posted on Dec 10, 2012
  • 395 Answers
SOURCE: JVC TV lamp indicator light blinking new lamp
if you purcased a LTI lamp then the possibilty of a bad lamp may be the case. LTI lamps are cheap and are poorly manufactured. if it is a JVC lamp then you may have further problems such as lamp balast, or thermal sensor. clean the fans and filtersfor better air flow. keeping the lanp cool is important for the life of the lamp.
Posted on Apr 19, 2008
SOURCE: Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Posted on May 11, 2008
  • 126 Answers
SOURCE: TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Posted on May 01, 2009
  • 4234 Answers
SOURCE: tv problem
The wner's manual should indicate what the flashing light code means, but the nmoise you hear is the lamp attempting to fire. This could be a bad lamp or ballast. I would first attempt to change the lamp as that is the least expensive option. Next, would be the ballast. These sets have many problem detection circuits designed to shutdown the set if any problem is detected at all. This is in an attempt to prevent additional damage. Check the ownner's manual for the code and try the lamp.
Update this with the results of those actions and we'll continue from there.
Thanks,
Dan
Posted on Sep 15, 2009
  • 280 Answers
SOURCE: just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
Posted on Oct 23, 2009
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
Mar 12, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
I have a 50V715 purchased in 2004 no picture.
U used this tv alots?About 4 or 5 hours a day?It time to change the projection bulb,the live span of the bulb are over.
Apr 28, 2010 | Hitachi 50V715 50" Rear Projection...
Sony 53" rear projection tv picture comes on scrambled and small with the stand by light blinking then the lamps go out. Whenever the channel is changed stand by light blinks again lamps come on for a few...
There are 2 types of Sony rear projection TVs, one that has 3 picture tubes inside and other has one lamp to produce light.
Model number is important to identify what TV do you have so let me know exact model number written at back of TV to find problem reason and suggest its solution.
Thanks.
Nov 30, 2009 | Sony DAV-C770 System
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Tv plays for a few minutes then shuts down. the red light blinks.
You need reset the lamp timer after
replace the new lamp.In the remote control pres menu------setup------lamp timer----message do you replace a lamp appear----press yes----and ok.
Feb 14, 2009 | Sony KDF42E2000 42" HDTV
Picture cycles off and on
I replaced a burned out xl-2000u bulb with an after-market Philips bulb on my Sony KF60XBR800. After a fews weeks, I started experiencing intermittent black-outs with the "stand by" red light appearing. After a couple weeks it became intolerable. I then purchased an OEM Sony lamp and the problem has been gone for months. I read somewhere that the Sony circuitry monitors either resistance or watts and shuts the thing down for board protection. It was said that it is so sensitive it can can use only the Sony bulb. I'm a believer. If the bulb is going bad, i wouldn't doubt the protection circuit can kick in.
,,,,Pat
Nov 21, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
