Question about Maytag Atlantis MAV6000 Top Load Washer
My Maytag model # LAT8504AAE WILL NOT do anything
The machine will not fill up when you turn the knob and pull out to start it. It had been unbalanced before it quit working, but no other problems. It does nothing!
  • sberry912 Jan 13, 2009
    Thanks for the suggestion. It was actually the fuse burned out. I replaced it this morning and it is working.
    New Friend:
  • 88 Answers
Check your lid switch you should hear it click when you open and close the lid. take off the screws to the back of the console 3 philips and 2 1/4in screws, I think, anyway when you get it open the lid switch is the white box that is kinda set into the frame . remove it and push it manually. let me know what you find good luck.
Posted on Jan 13, 2009
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
When I turn the knob and set the type of wash I want. I then pull the knob (which starts the cycle). It should start filling with water. It does nothing at all.It's a pretty new machine.
Your inlet water solenoid could be faulty or you can take off the inlet hose and see if the gauze filter is blocked with something coming through the water line. PS dont forget to turn off the water first!!!
Mar 28, 2010 | Maytag LAT3600A Top Load Washer
Machine fills up with water then when its suppose to agitate it just stops working will turn timer & push knob in & out & reset then it will work
How long do you let it sit after the water fills up, somtimes the timer will take a little extra time to get to the point that starts the agitation cycle.
When it dose this, without pulling the knob out, turn the disk on the timer clockwise 1 click and see if it starts up agitating, if it dose dont worry about it it is normal
Nov 09, 2009 | Maytag PAV2300 Top Load Washer
Washer didnt fill when turned on, but filled when holding "reset"
sounds like your water level switch is bad OR the small hose that goes from the waterlevel switch to the bottom of the tank has a hole in it.Try replacing this small hose first.you can go to an auto parts store and match it up.it's usually about 3' long and about 1/4" inside diameter and about 99cents a foot.
Aug 26, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer won't act right
Most likely this is a problem with the main cycle knob, if for some reason the knob is not fully pulled
out, it just won't work, only fills with water, and the timer is the responsible one for the draining, but
the timer itself is not at fault, have your main knob selector switch checked.
Nov 02, 2008 | Maytag Performa PAV2200
Maytag washer
the timer might be broke, well let me explain more the prongs on the back of the timer might not be making contact so the washer will not start.
Feb 12, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Jul 20, 2007 | Maytag MAT12CS Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
270 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
