Question about Mitsubishi VS-45605 50" Rear Projection Television
Repair when i turn the tv on it is fine for like the first 1/2 hour then it seems to get a double image in the screen.when i change the channel it stops on some channels but after a while all channels will do it .i got a can of dust off and whenever i spray it in it stops for about a half an hour.then starts up again
    New Friend:
  • 129 Answers
The convergence ics ,are already over heated an they need to be replaced 100.oo to 150.00 labor plus. depending on the tech. parts around 70.00 please let me know if you need more help
Posted on Jun 12, 2007
  • Luis Amado Jun 13, 2007
    If, you need more help ,please let me know
    thanks
My toshiba 57H82 tv has double image blue and yellow
This is a known issue with the model that you have listed. The repair kit is here: http://www.tvrepairkits.com/xcart/57h82/ You should be able to solder, the kit comes with diagrams, photos, parts and support.
Mar 07, 2014 | Televison & Video
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Jan 29, 2011 | Samsung LN46A550 LCD TV
Burned image on comp 1 chanel
When an image is burnt in to screen it is always there you just dont see it when you watch tv because of the changing video. On some sets you can burn the image out by using a all white screen, from a signal generator or from the service menu, turning the brightness all the way up and letting it play for 24 hours. Here are some websites that have software that is supposed to erase burn-in images, but you would have to hook tv to a computer, unless it can be copied to a dvd and played through a DVD player. Have not used it myself so not sure how or if it works. Be careful not to cause any more damage to screen. A new screen can cost a few hundred to over a thousand dollars to replace. Set should be taken to a panasonic repair shop to try burning it out with white screen approach, so if they damage it they have to fix it.
http://www.sharewareplaza.com/JScreenFix-download_44365.html
http://www.top-shareware.net/lcd.html
http://www.fast-download.info/screen-fix.html
Nov 03, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Olevia LT27HVX 27 just blue screen
I just had this same problem over the weekend. Is your TV hooked up via HDMI?? Mine was and i've been having problems with the tv image shrinking whenever i turn on the tv, so i would have to change the channel 1 or 2 times for the image to come up normally. On Saturday I went to change the channel and then all of a sudden I hearld this loud pop and when the image came on it was just a sky blue screen, I couldnt see anything, but I could hear the channel. So I disconnected the HDMI and hooked up the tv with component cables I had and now it works fine. I ordered a new HDMI cable just to see if it will work again. If not, i'm calling Olevia.
Feb 18, 2008 | Olevia LT27HVX 27 in. LCD Television
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Red Shadow
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Feb 01, 2008 | Sony KP-51WS510 51" Rear Projection...
Double image - not covergence
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 21, 2007 | Toshiba 42H83 42" Rear Projection...
Getting a yellow to blue double image on the items in the picture and when you change chanels the chanel information displayed on the screen is doubled. Was working fine 24 hours ago.
Convergance ic are bad.
there are some resisters that should be checked
heres some diy sites.
http://www.hometheatershack.com/forums/manufacturers-service-support/5600-crt-based-rptv-convergence-repairs.html#post43725
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Nov 01, 2007 | Philips 60PP9202 60" Rear Projection...
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
