I am getting pop-up msgs repreately abt syntax sandbox probs my macbook
I am not getting this problem with safari only firefox
    Champion:
  • 220 Answers
Spam
Posted on Mar 31, 2014
2 Suggested Answers
tedjames777
  • 1615 Answers
SOURCE: My 2001 MacBook Pro fans run almost constantly, while my previous 2009 MacBook Pro fans seldom ran. Why is that?
Your cooling fan is clogged with dust, not allowing enough air to circulate through it. Use compressed air and blow out the vents. The fan constantly runs because it isn't getting enough cooling.
Posted on Nov 19, 2013
Testimonial: "When I upgraded the RAM I used a vacuum to clean out dust, however that didn't fix the near constant fan use."
How do remove flash advertising while online with Apple's MacBook?
This page should help you out, it all depends on the browser you are using:
http://osxdaily.com/2011/05/10/ad-block-for-chrome-firefox-safari/
Hope this helps
Feb 27, 2015 | Apple MacBook Air
How do i enable popups in SurgeWeb?
Hi, not sure about this app, but if it is web based, I will assume it runs on Safari. Have you enabled popups in Safari? Also, I would try with another browser like Chrome or Firefox. Make sure you are not running any 3 rd party popup blockers!
For future reference, it help us to know a bit more about your Mac, like what OS X is running and Safari version, if it is updated, etc.
Regards,
Alex
Safari 6 OS Mountain Lion Block pop ups and unnecessary content
Aug 05, 2014 | Apple MacBook Pro Laptop Computer with...
Cannot view my own website. it reads: "Parse error: syntax error, unexpected $end..." in my index.php file. HELP
Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Locate the syntax error manually. Step through each section of your code. Most code will be sectioned off into groups or functions. Carefully proof your code. Be sure to pay close attention to how lines are grouped. A common syntax mistake is incorrect grouping.
For instance, if you have an If Else statement embedded in another If Else statement, be sure the embedded statement is surrounded by a separate set of parenthesis or brackets, depending on your language. Double-check notes sections. Notes are only for the developer to see. However, if the syntax isn't correct, the notes may become part of your application, which may not agree with existing code. Ensure the syntax around your notes is correct. Run a debugger if possible. This will make locating errors much easier. A debugger will be found under a menu such as Debug, Run or Tools or as part of your SDK's toolbar. Allow the debugger to run. Errors will be listed at the bottom or right side of your screen. Many debuggers will highlight possible errors in your code as well. A line number, along with the possible error, will be listed in the error message. Locate your syntax error if the debugger isn't correct. Sometimes a debugger will show you where your application stopped working correctly. The syntax error itself may be above or below the line listed in the debugger message. Check all syntax within the surrounding area, especially within the line's function. Run your application after correcting the syntax error. Check every possible function of your application to ensure it works correctly. If you find a problem, double-check the syntax in your code that surrounds the problem area. For instance, if your application has a log-in screen that isn't accepting passwords correctly, check the code for the log-in screen. Remove Syntax Error syntax error typically occurs when the Web page you are loading causes a script error in the browser. This is caused by incorrect code that displays an error message or results in a Web page that does not load correctly. You can remove a syntax error by making a change to the settings of your Web browser. Common Web browsers that can experience this type of error include Internet Explorer, Mozilla Firefox and Safari.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect.
b>
b>
Apr 06, 2013 | Computers & Internet
Mackbook version 10.8.2 keep getting a message "SyntaxError: JSON Parce error: Unexpected EDF" What is it & how can I get rid of it?
Check out this site
https://support.apple.com/en-za/HT201686
Syntax is the way a command or script is formatted.
JSON parse error is telling you that Javascript is not written in correct format.
EDF does not exist, but along with other faults reported, this is more likely EOF, meaning End Of File.
So the message is roughly:
"Whaat?? That's not true Java!! Conversation is terminated."
This could happen if your MAC's OS is corrupt or you recently installed a faulty OS.
As you describe starting Safari and initiating Bing, maybe the Bing app is not playing nicely with your Macbook.
Try remove it.
Nov 18, 2017 | Apple Computers & Internet
I keep getting a box on my screen every time i try to do anything. it says EvalInsandbox:SyntaxError:syntaxerror
Correct a Syntax Error Syntax errors are the most common problem for developers. A single syntax error can cripple even the best applications and websites. You can correct syntax errors easily once you find them. Typical errors include missing commas, semicolons and parenthesis. Debuggers are available in many software development kits to aid you in the location of syntax errors. However, you can find and correct syntax errors manually as well. Learning how to correct syntax errors is an essential part of being a software developer.
Double-click the "Internet Explorer" icon to open the program. Click the "Tools" drop-down menu and select "Internet Options." This will display the Internet Options window. Go to the "Advanced" tab and scroll down to the "Browsing" section. Remove the check from the box for "Disable script debugging (Internet Explorer)," "Disable script debugging (Other)" and "Display a notification about every script error." Click the "Apply" button to save the changes. Click the "OK" button to close the Internet Options window. Close and restart the Internet Explorer browser for the changes you made to take effect. b> Mozilla Firefox b> Double-click the "Mozilla Firefox" icon to open the program. Type "about:config" into the address bar and press the "Enter" key. Type "dom.max_script_run_time" into the Filter text box and press the "Enter" key. Double-click "dom.max_script_run_time" to display the Enter Integer Value dialog box. Enter a value of "10" or "15" into the text box and click the "OK" button to save the change. Close and then restart the Firefox browser for the change to take effect. b> Safari b> Click the "Safari" icon to open the Web browser. Select the option for "Preferences" from the menu bar. Go to the Advanced tab and click the option for "Show Develop menu in menu bar." Click the option for "Develop" from the menu bar. Click the option for "Disable Runaway JavaScript Timer." Close and re-open the browser for the change to take effect. Hope this helps.
b>
b>
Dec 06, 2012 | Mozilla Firefox
Why does safari doesn't support my community bar any more?
This solution is kind of a cop out, but FWIW (for what it's worth): 1. Make sure you have the latest version of Safari.
2.) You may want to consider using Firefox or Google's Chrome browser.
Firefox is available at www.getfirefox.com
Chrome is available at www.google.com/chrome
I don't even use Safari on my Macs. Firefox is more widely supported, in my experience.
Sep 16, 2010 | Apple MacBook Pro Notebook
I cant open you tube from my mac pro
try to use other web browser like mozilla firefox cuz maybe is your safari's problem
Nov 26, 2009 | Apple MacBook Pro Laptop Computer with...
When i open my cellphone only the welcome (the two hands) appears on my nokia 6280 and after that a blank screen and only the battery icon.
i had z same prob wiz my 6280. i had too many msg saved on my mob, abt 7000 in inbox n abt 3500 in sent items. i erased all z msgs, now its wrkin like new, maybe u got lots of fings saved on ur phone memory, try deleting some. hope zis helps.
Apr 24, 2009 | Nokia 6280 Cellular Phone
I am using a MacBook with Safari and Yahoo Mail. I would like to be able to send Links in my email but cannot do it from Safari. I am only able to do this using Mail. Is there a solution?
I dont believe there is a way directly in safari. I would try to download firefox for free and try that. I have a new Macbook Pro and an older MacBook and they are both running firefox. Its more stable and has a lot of features that safari does not.
Mar 06, 2009 | Yahoo Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
